ESP32_Miner_LCD-2.8_inch_IDF¶
Overview¶
In this tutorial, we will show you how to design the UI with SquareLine Studio, and show you how to upload the code with ESP-IDF.
Hardware Preparation¶
| CrowPanel ESP32 2.8'' HMI | Crowtail-DHT20 | Crowtail-LED | Dupont-wire |
Open the SquareLine Studio and create a project.
Note:
Set the name of the project, set the screen resolution to 320*240, set the color depth to 16bit, and keep other default settings. After setting, click CREATE to create the project.
Please click
Add background.
You can set the font colour and other attributes in STYLE SETTING→STYLE(MAIN).
Add events to buttons.
Select "clicked" as the trigger condition, select a trigger event in "Action". It will be modified in the generated program to achieve the LED control function.
Export UI files.
Then click "APPLY CHANGES".
Build the Project with ESP-IDF¶
Get Started with ESP-IDF¶
Please click the card below to learn how to install ESP-IDF. Create a blank project according to the "Get Started with ESP-IDF".
You can click
to download the complete project we provided. This project can be used directly. You can also create the project by following the tutorial.
Add Libraries¶
Create a new folder and name the folder 'components'. Add the libraries we provided to this folder.
Setup UI file¶
Add the UI file we exported earlier in Squareline.
The CMakeList.txt file in the UI file needs to be modified as follows:
Setup main file¶
The CMakeList.txt file contains the Settings for the library. All required libraries should be included by directory address. The CPP file of DHT20 has an additional column.
The main program is written in CrowPanel_ESP32_2.4_2.8.cpp file.
Library introduction¶
#include <lvgl.h>: Library for UI interaction.#include <DHT20.h>: The library of temperature and humidity sensors.#include <TFT_eSPI.h>: Screen driven library.#include <Arduino.h>: This is the core Arduino header file. It must be included when using the Arduino framework.#include "ui.h": is a custom header file that contain UI-related functions or definitions.
Code Explanation¶
Basic Definition
- Set the screen cache
#define SCREEN_WIDTH 320
#define SCREEN_HEIGHT 240
#define LVGL_TICK_PERIOD 5
uint16_t calData[5] = {189, 3416, 359, 3439, 1};
TFT_eSPI lcd = TFT_eSPI();
DHT20 dht20;
// Screen buffer (suggested to be 1/10 to 1/4 of the screen size)
#define DRAW_BUF_SIZE (SCREEN_WIDTH * SCREEN_HEIGHT / 10)
lv_color_t draw_buf[DRAW_BUF_SIZE];
// LVGL display and input devices
static lv_display_t *disp;
static lv_indev_t *indev;
- Automatically refresh temperature and humidity data in real time.
// Real-time temperature and humidity label objects
lv_obj_t *temp_label;
lv_obj_t *humi_label;
// Sensor update
void update_sensor_values() {
int temperature = dht20.getTemperature();
int humidity = dht20.getHumidity();
// If you have corresponding labels in ui.h, you can uncomment the following lines to update the UI:
lv_label_set_text_fmt(temp_label, "%d", temperature);
lv_label_set_text_fmt(humi_label, "%d", humidity);
Serial.print(temperature);
Serial.println(" °C");
Serial.print("Humidity: ");
Serial.print(humidity);
Serial.println(" %");
- Touch reading function
// Touch reading
uint16_t touchX, touchY;
void my_touchpad_read(lv_indev_t *indev, lv_indev_data_t *data) {
if (lcd.getTouch(&touchX, &touchY)) {
// data->point.x = SCREEN_WIDTH - touchX; // 2.4 inch screen use this line instead
data->point.x = touchX; // 2.8 inch screen use this line instead
data->point.y = touchY;
Serial.printf("Touch X:%d Y:%d\n", data->point.x, data->point.y);
} else {
- Refresh function
// Refresh function
void my_disp_flush(lv_display_t *disp, const lv_area_t *area, uint8_t *px_map) {
uint32_t w = lv_area_get_width(area);
uint32_t h = lv_area_get_height(area);
lcd.pushImage(area->x1, area->y1, w, h, (uint16_t *)px_map);
lv_display_flush_ready(disp);
- Obtain the tick time
Set Up Part
Serial.begin(115200);
pinMode(4, INPUT);
// IO pin setup
pinMode(25, OUTPUT);
digitalWrite(25, LOW);
// Initialize I2C
Wire.setPins(22, 21);
Wire.begin();
dht20.begin();
// Initialize LCD
lcd.begin();
lcd.setRotation(1); // Adjust screen orientation as needed
lcd.setSwapBytes(true); // Swap RGB and BGR data
lcd.fillScreen(TFT_BLACK);
delay(300);
// Backlight control
pinMode(27, OUTPUT);
digitalWrite(27, HIGH);
SPI.begin(14, 4 , 13, 33);
lcd.setTouch(calData);
// Initialize LVGL
lv_init();
lv_tick_set_cb(my_tick);
// Create display driver
disp = lv_display_create(SCREEN_WIDTH, SCREEN_HEIGHT);
lv_display_set_flush_cb(disp, my_disp_flush);
lv_display_set_buffers(disp, draw_buf, NULL, sizeof(draw_buf), LV_DISPLAY_RENDER_MODE_PARTIAL);
// Register touch input device
indev = lv_indev_create();
lv_indev_set_type(indev, LV_INDEV_TYPE_POINTER);
lv_indev_set_read_cb(indev, my_touchpad_read);
// Initialize UI
ui_init();
// Create temperature label
temp_label = lv_label_create(lv_screen_active());
lv_obj_set_style_text_font(temp_label, &lv_font_montserrat_14, 0); // Can be replaced with a larger font
lv_obj_align(temp_label, LV_ALIGN_CENTER, -20, -50); // Centered and offset upward
lv_label_set_text(temp_label, "--");
// Create humidity label
humi_label = lv_label_create(lv_screen_active());
lv_obj_set_style_text_font(humi_label, &lv_font_montserrat_14, 0);
lv_obj_align(humi_label, LV_ALIGN_CENTER, -20, 25); // Centered and offset downward
lv_label_set_text(humi_label, "--");
Main Program Part
static unsigned long last_update = 0;
if (millis() - last_update > 2000) {
update_sensor_values();
last_update = millis();
lv_timer_handler(); // Handle LVGL tasks
delay(5);
// Entry point for ESP-IDF
extern "C" void app_main() {
setup();
while (true) {
loop();
Setup board¶
Download the program¶
Connect the ESP32 Display to the PC and compile the program.
After confirming the serial port, select the UART mode. Then you can burn your code.
After the program is successfully downloaded, connect the DHT20 sensor to the IIC port and the LED to GPIO_D (IO25), the temperature and humidity values will be displayed on the screen. Click the ON button on the screen and the LED will turn on. Click the OFF button and the LED will turn off.
