Crowtail- Strain Gauge sensor
A strain gauge is a device used to measure strain on an object. This strain gauge module uses the strain gauge BF350-3AA to detect the strain, with the amplifier and potentiometer on the board to adjust the measured results, users can easily get the result with any microcontroller such as Arduino. This module can be positively used in measuring deformation (for example, across a bridge by loading positions and effects) in engineering and in physical distortions proportional to loading or thermal environments. In everyday, this module can be used to applications such as gating a traffic light into a new sequence when a car on a lightly traveled side-street enters a Tee-intersection. For better using on our crowduino, we add a crowtail port so that you can plug and use directly.
Model: CT0070SGS Crowtail-strain gauge sensor.png
Alt text
  • Working Voltage: 5VDC
  • Analog Output: 0~3.5VDC
  • Potentiometer to adjust the zero point
  • Dimension: 32mm X 17mm
Interface
Platforms Supported
Usage
Hardware
Crowduino Uno Base Shield Crowtail- Strain Gauge Sensor
Get one now Get one now Get one now
STEP2 Plug Crowtail-Base Shield into Crowduino Uno;STEP3 Plug Crowtail-Strain Gauge Sensor to A0 slot of Crowtail-Base Shield via 4 pin Crowtail Cable;STEP4 Connect Crowduino Uno to PC via a Mini USB cable.
NOTE
If we don't have Crowtail Base Shield, We also can directly connect this module to Crowduino Uno as below.
Crowduino Uno Crowtail- Strain Gauge Sensor
ANALOG 0 SIG
5V VCC
GND GND
Software
STEP1 Download program files Strain_gauge_sensor.zip
STEP3 Open the program in the Arduino IDE
const int sensor=A5;
int sensorValue = 0;
  sensorValue = analogRead(sensor);
   Serial.print("sensor value= " );
  Serial.println(sensorValue);
  delay(500);
STEP4 Click the Upload.png to upload the code to the Crowduino board
STEP5 After the program is burned, open the serial monitor of Arduino IDE. Adjust the sliding rheostat until the serial monitor prints about 300. Then gently bend the strain gauge and you will see the serial monitor output changes from 0 to 700.
FAQS
Resources
Crowtail-_Strain_Gauge_sensor_v2.0-Eagle.zip
datasheet
