Crowtail- Temperature& Humidity Sensor
This module can help you detect the temperature and humidity of the environment of your house. The module contains a DHT11 temperature & humidity senorthat is a complex sensor with a calibrated digital signal out.It use digital module acquisition technology and the temperature&humidity sensor technology.Sensor consists of a resistance type moisture element and a NTC temperature measuring element. Because of single wire serial interface, it is easy to use the module.
Model: CT0010TH
  • Work Voltage: 3.3V ~ 5V
  • Measuring Range:
  Humidity: 20% - 90% RH
  Temperature: 0 ~ 50 °C
  • Accuracy:
  Humidity: ±5% RH
  Temperature: ±2°C
  • Sensitivity:
  Humidity: ±1% RH
  Temperature: 1°C
  • Signal Collecting Period: 2S
  • Dimensions(mm):40.0(L)x20.0(W)x7.6(H)
Usage
This demo is going to show you how to read temperature and humidity information from this Crowtail - Temperature and Humidity Sensor.
1.Hardware Connection The Temperature and Humidity sensor is connecting to digital port D5 of Crowtail - Base Shield.
2.Download Temperature_humidity_sensor library for Arduino boards with 16MHz XTAL; Unzip and put it in the libraries file of Arduino IDE by the path: ..\arduino-1.0\libraries;
3.Open “DHTtester” example via the path: File --> Examples --> Humidity_Temperature_Sensor --> DHTtester.
// Example testing sketch for various DHT humidity/temperature sensors
#include "DHT.h"
#define DHTPIN 5     // what pin we're connected to
// Uncomment whatever type you're using!
#define DHTTYPE DHT11   // DHT 11
//#define DHTTYPE DHT22   // DHT 22  (AM2302)
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
DHT dht(DHTPIN, DHTTYPE);
  Serial.println("DHTxx test!");
  dht.begin();
 // Reading temperature or humidity takes about 250 milliseconds!
 // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
 float h = dht.readHumidity();
 float t = dht.readTemperature();
 // check if returns are valid, if they are NaN (not a number) then something went wrong!
 if (isnan(t) || isnan(h)) {
   Serial.println("Failed to read from DHT");
 } else {
   Serial.print("Humidity: ");
   Serial.print(h);
   Serial.print(" %\t");
   Serial.print(t);
   Serial.println(" *C");
4.Upload it into your Arduino board and open the serial monitor to observe the temperature and relative humidity information of the environment.
Resource
