Crowbits-Electromagnet
The electromagnet is a digital output module, it is a type of magnet in which the magnetic field is produced by an electric current. Equipped with this feature, you can make a mini device for picking up and moving magnetic material.
- Easy to use
- Operating Voltage: 3.3V DC
1. You also need to prepare a power module, such as Crowbits-Power Supply, and an input module, such as Crowbits-Switch.
3. Turn on the power. When you press the button of the self-locking switch, the LED of Crowbits-Electromagnet board will light up.
4. Then let it absorb the magnetic screw, and you'll see that the screw attaches to the electromagnet. When you release the self-locking switch, the screw on the electromagnet will fall off.
