Elecrow Wiki
AI Panda ChatBot
Initializing search
Elecrow Wiki
Home
Products
Products
Crowduino
Crowduino Uno-SD
Crowduino M0- SD
Crowduino Mega2560
ESP8266 IOT Board(Arduino IDE or NodeMCU Lua Programming)
32u4 with A7 GPRS/GSM
32u4 with A9G GPRS/GSM/GPS
Smart Pump Shield
Screw Shield
Crowduino Leonardo
Crowduino-Nano-V3.1
Elecrow SIMduino UNO+SIM808 GPRS/GSM Board
32u4 with A6 GPRS/GSM
Leonardo GPRS/GSM IOT Board v1.1
Nano 168(Arduino Compatible)
Easy Module Shield for Arduino UNO
IO Shield For Arduino Nano
Arduino CNC Shield
Larduino Mini
Crowduino Pro Mini
Elecrow ESPduino UNO+ESP8266 Wifi Board
ESP32 WIFI/BLE Board v1.0
32u4 with Lora RFM95 IOT Board-868MHz
RFM69 Shield
2.4 inch TFT Touch Shield for Arduino
3.5 Inch TFT Color Screen Module 320 X 480 Support Arduino UNO Mega2560
TEXT
Shield
Shield
GPRS/GSM Shield v1.0
Ehternet Shield
WiFi Shield
GPS shield
2.8'' TFT Touch Shield
Dual Channel H-Bridge Motor Shield
Relay Shield
CC3000 WiFi Shield
USB Host Shield for Arduino
Lipower Shield v1.1
Mini solar Lipo Charger v1.0
USB Hub&Powermanager for RPI Zero v1.0
Current/Voltage/Power Monitor HAT for Raspberry Pi
Breakout Board for micro:bit IO Expansion Board
Rainbow Shield
Bluetooth Shield v1.0
NFC Shield
Motor Shield v1.0
Wireless SDshield
Motor&Stepper Shield
EM Shield
CAN-BUS Shield
Joystick Shield
SIM5360E 3G Shield
Speech Interaction board for Raspberry Pi
Power over Internet(POE) Hat for Raspberry Pi
Uninterruptible Power Supply UPS HAT For Raspberry Pi
4 Channel I2C Motor Shield v1.1
XBee shield
LCD Keypad Shield
Arduino Motor/Stepper/Servo Shield
8-Channel EL Shield
SIM808 GPRS/GSM+GPS Shield
RTC Data Logger Shield v1.1
Capacitive Touch Shield
VS1053 MP3 Shield
AVR ISP Shield
Solderless Protoboard for raspberry pi v1.0
IMX219-83 Stereo Camera
Binocular Stereo Vision Expansion Board for Raspberry Pi
Mbits
Pico Shield
Crowtail
Crowtail
Crowtail- Base Shield
Crowtail- Linear Potentiometer
Crowtail- Sound Sensor
Crowtail- UV Sensor
Crowtail- Thumb Joystick
Crowtail- Button
Crowtail- LED
Crowtail- Buzzer
Crowtail- Touch Sensor
Crowtail- Tilt Switch
Crowtail- I2C LCD
Crowtail- Infrared Temperature Sensor
Crowtail- Digital Light Sensor
Crowtail- GPS
Crowtail- One Wire Waterproof Temperature Sensor
Crowtail- Dust Sensor
Crowtail- Gas Sensor(MQ2)
Crowtail- ES08A Mini Servo
Crowtail- PIR Motion Sensor
Crowtail- 3-Axis Digital Compass
Crowtail- SIM808
Crowtail- Microwave sensor
Crowtail- Dry-Reed Relay
Crowtail- Pulse Sensor
Crowtail- Air Quality Sensor
Crowtail- AM2302 Humidity&Temperature Sensor
Crowtail- Solid-State Relay
Crowtail- I2C Motor Driver
Crowtail- LED Bar
Crowtail- Protoboard
Crowtail- SPDT Relay
Crowtail- Super Bright
Crowtail-Rotation Angle Sensor
Crowtail- Haptic Motor
Crowtail- TPL5111 Reset Enable Timer
Crowtail- MEMS Microphone
Crowtail- LiPo Fuel Gauge
Crowtail- Mini PIR Motion Sensor
Crowtail- BMP280 Barometer Sensor
Crowtail- Strain Gauge sensor
Crowtail- VL53L0X Laser Ranging Sensor
Crowtail-Digital-Programmable-Potentiometer
Crowtail-Weight Sensor
Crowtail- MPU6050 Accelerometer & Gyro
Crowtail- Vibration Motor
Crowtail- Relay
Crowtail- Moisture Sensor
Crowtail- Light Sensor
Crowtail- Hall Sensor
Crowtail- Encoder
Crowtail- IR Reflective Sensor
Crowtail- Temperature& Humidity Sensor
Crowtail- Analog Gyro
Crowtail- MOSFET
Crowtail- Flame Sensor
Crowtail- Rotary Angle Sensor
Crowtail-Nano Base Board
Crowtail- Fingerprint Sensor
Crowtail- Gas Sensor(MQ5)
Crowtail- Adjustable Infrared Sensor
Crowtail- 3-Axis Digital Gyro
Crowtail- Gas Sensor(MQ9)
Crowtail- I2C Color Sensor
Crowtail- Collision Sensor
Crowtail- 9G Servo
Crowtail- Magnetic Switch
Crowtail- Electromagnet
Crowtail- Vibration Sensor
Crowtail- Analog Grayscale Sensor
Crowtail- Switch
Crowtail- I2C EEPROM
Crowtail- Recorder
Crowtail- Speaker
Crowtail- MP3
Crowtail- Screw Terminal
Crowtail- I2C Hub
Crowtail- UV sensor(GUVA- S12SD 2.0
Crowtail- PH Sensor
Crowtail- NFC
Crowtail- Logic Block
Crowtail- 1.3 Inch OLED v1.0
Crowtail- CurrentPower Sensor
Crowtail-LED Matrix
Crowtail- DHT20
Crowtail- IMU 10DOF
Crowtail- HTU21D Humidity& Temperature Sensor
Crowtail-Knock Sensor
Crowtail-GP02
Crowtail- BMP180 Barometer
Crowtail- Blutooth Low Energy Module
Crowtail- Thermistor Temperaturen Sensor
Crowtail- RTC
Crowtail- Serial Wifi
Crowtail- IR Emitter
Crowtail- IR Receiver
Crowtail- Current Sensor
Crowtail- RGB-LED
Crowtail- OLED
Crowtail- Gas Sensor(MQ3)
Crowtail- Water Sensor
Crowtail- 3-Axis Digital Accelerometer
Crowtail- Laser Pointer
Crowtail- Ultrasonic Ranging Sensor
Crowtail- 80cm Infrared Proximity Sensor
Crowtail- 4-Digit Display
Crowtail- Current Sensor Kit
Crowtail- Extend board for Connection
Crowtail- Photo Electric Counter
Crowtail- Electricity Sensor
Crowtail- Voltage Sensor
Crowtail- thermocouple Sensor
Crowtail- Gesture
Crowtail- G1/4" Water Flow Sensor
Crowtail- G1/2" Water Flow Sensor
Crowtail- G3/4" Water Flow Sensor
Crowtail- G1" Water Flow Sensor
Crowtail- Non-contact liquid level sensor
Crowtail- Serial Camera
Crowtail- Luminance sensor
Crowtail- Dual Channel Latching Module
Crowtail- Temperature Sensor TMP102
Crowtail- 315Mhz RF Receiver with Transmitter
Crowtail- MAX30105 Particle Sensor
Crowtail-Capacitive Moisture V2.0
Crowtail- Stackable Shield for Raspberry Pi 2.0
Crowtail- Motor Base Shield
Crowtail- A6 GPRS/GSM Module
Crowtail- WIFI Module
Crowtail- LoRa RA-08H
Crowtail- DWM1000 UWB(Ultra Wide Band
Crowtail- 4G SIM-A7670E
Crowbits
Crowbits
Crowbits-LED (Red Green Yellow)
Crowbits-Buzzer
Crowbits-Relay
Crowbits-Bright LED
Crowbits-Vibration Motor
Crowbits-Electromagnet
Crowbits-DC Motor
Crowbits-MOSFET
Crowbits-MP3
Crowbits-Recorder
Crowbits-TPL5111 Timer
Crowbits-Vibration Sensor
Crowbits-Magnetic Switch
Crowbits-Water Sensor
Crowbits-Reaction
Crowbits-Touch Sensor
Crowbits-PIR Sensor
Crowbits-Tilt Switch
Crowbits-Button
Crowbits-Switch
Crowbits-Flame Sensor
Crowbits-Collision Sensor
Crowbits-IR Reflective Sensor
Crowbits-Photo Electric Counter
Crowbits-Hall Sensor
Crowbits-Microphone
Crowbits-Potentiometer
Crowbits-Light Sensor
Crowbits-Pressure Sensor
Crowbits-Servo Control
Crowbits-Linear Potentiometer
Crowbits-Terminal
Crowbits-315Mhz Emitter
Crowbits-Expansion
Crowbits-Protoboard
Crowbits-Power Supply(S
Crowbits-Trigger Delay
Crowbits-Logic AND
Crowbits-Logic OR
Crowbits-Logic NOT
Crowbits-Logic Input
Crowbits-315MHz Controller
Crowbits-IR Emitter
Crowbits-RGB LED
Crowbits-LED Bar
Crowbits-315Mhz Receiver
Crowbits-IR Receiver
Crowbits-DHT11 Sensor
Crowbits-Gas Sensor
Crowbits-Encoder
Crowbits-Pulse Sensor
Crowbits-Air Quality Sensor
Crowbits-Grayscale Sensor
Crowbits-UV Sensor
Crowbits-Ultrasonic Ranging Sensor
Crowbits-Thumb Joystick
Crowbits-Digital Potentiometer
Crowbits-Keyboard
Crowbits-Voltage Sensor
Crowbits-CurrentPower Sensor
Crowbits-IR Temperature Sensor
Crowbits-NFC
Crowbits-Barometer Sensor
Crowbits-Digital Light Sensor
Crowbits-LED Matrix
Crowbits-RGB Matrix
Crowbits-HTU21D Humiture Sensor
Crowbits-Laser Ranging Sensor
Crowbits-Color Sensor
Crowbits-RTC
Crowbits-Gesture Sensor
Crowbits-OLED
Crowbits-EEPROM
Crowbits-Digital Display
Crowbits-WiFi
Crowbits-GPS
Crowbits-2G Module
Crowbits-Microbit Compatible
Crowbits-UNO
Crowbits-80cm Infrared Proximity Sensor
Crowbits-Adjustable Infrared Sensor
Crowbits-9G Servo
Crowbits-G1-4 Water Flow Sensor
Crowbits-Non-Contact Liquid Level Sensor
Crowbits-One Wire Waterproof Temperature Sensor
Crowbits-Moisture Sensor
Crowbits-DHT20
Sensors
Sensors
Temperature & Humidity Sensor
PIR Motion Sensor
Tiny RTC
Adjustable Infrared Sensor Switch
Triple Axis Magnetometer Breakout
Ultrasonic Ranging Sensor Module
ACS712 Current Sensor- 5A
1-Axis Analog Gyro Module-ENC03
2-Axis Analog Gyro Module-ENC03
Strain Gauge Module
4MM Inductive Metal Proximity Sensor
Fingerprint Sensor
Infrared Thermometer MLX90614 Breakout Board
Luminosity Sensor- TSL2561 Breakout
HC-SR505 Mini PIR Motion Sensor
Digital light Sensor
Photosensor- Short Range
Photosensor- Long Range
Accelerometer Breakout-MMA7361
MPU-6050
3-Axis Analog Gyro Module-ENC03
Weight Sensor Scales Kit- 20KG
Non-invasive AC Current Sensor-100A
TCS3200 Colour Sensor Module
Analog CO/Combustible Gas Sensor(MQ9
UV Sensor ML8511
Barometer Sensor
IMU 10DOF LSM303D+L3GD20 +BMP180
Encoder Gear Motor-25MM 95RPM
Weight Sensor Amplifier-HX711
DHT11
Tiny Adjustable Infrared Sensor Switch
Serial JPG Camera
Dust Sensor- DSM501A
Dust Sensor- GP2Y1010AU0F
Pulse Sensor
Sound Recorder- ISD1760
80cm Infrared Proximity Sensor-GP2Y0A21YK0F
Analog Smoke/LPG/CO Gas Sensor(MQ2
ENC28J60 Ethernet Module
UV Sensor Module-UVM30A
APM2.5 Airspeed Breakout Board MPXV7002DP
Soil Moisture Sensor
Rectangle capacitive fingerprint scanner breathing light fingerprint AS608 sensor
1019DRound fingerprint recognition sensor module ID809
Wireless
Wireless
315/433Mhz RF Link Kit
NRF24L01+PA+LNA Wireless Module
Smart car with ESP32-CAM Board
2.4G Wireless nRF24L01
Serial Port Bluetooth Module
Wireless Charger& Receiver
433MHz RF Transceiver CC1101 Module
Serial WIFI Transceiver Module ESP8266
ESP32S WIFI BLE Board
CrowBot-BOLT Programmable Smart Robot Car STEAM Robot Kit
Lora RFM95 IOT Board for RPI
SIM7670 4G Module with Mini PCIe Interface
Wireless Module for Wi-Fi HaLow
Display
Display
0.96" OLED 128x64-Blue
I2C 0.96" OLED 128x64-Blue
1.44'' 128x128 TFT LCD with SPI Interface
3.5 Inch 480x320 TFT Display with Touch Screen for Raspberry Pi
3.95 Inch TFT Display for Raspberry Pi
RC070M 7 inch 1024 X 600 Touch Screen Display with 720P Camera for Raspberry Pi/ MacBook Pro./ Windows 10
RR070 7 Inch 1024x600 HDMI/VGA/AV Display for Raspberry Pi B/B+/2B/3B
SF101C 10.1 inch 1280*800 IPS HDMI LCD Display(with case) for Raspberry Pi
SF116 11.6 Inch 1920x1080 HDMI 1080P LED Display for Raspberry Pi
2.9 inch e-Paper Module Three Color-Red Black White
1.3 inch IPS TFT LCD Display ST7789
Elecrow 10.1 inch Display IPS 1280x800 Acrylic Case Touch Screen Compatible with Raspberry Pi Jetson Nano PC
5.0 Inch HDMI-Compatible Display for Raspberry Pi Compatible with Jetson Nano, Beaglebone
I2C LCD2004(Yellow
I2C LCD1602(Blue)
WS2812 RGB LED Ring
HDMI Interface 5 Inch 800x480 TFT Display
4 Inch HD 480x320 TFT Display with Touch Screen for Rapberry Pi
RC050 5 inch HDMI 800 x 480 Capacitive Touch LCD Display for Raspberry Pi/ PC/ SONY PS4
ELECROW 11.6 Inch 1080P IPS 1920x1080 Monitor with Built-in Speaker for Raspberry Pi PS4 XBOX Windows without touch function
ELECROW 11.6 Inch 1080P IPS 1920x1080 Monitor with Built-in Speaker for Raspberry Pi PS4 XBOX Windows with touch function
SF101 10.1 Inch 1920x1080 Display HDMI VGA IPS PS3 PS4 Gaming Screen
SF101R 10.1 Inch Portable HD Display for Raspberry Pi 3
SF133 13.3 Inch IPS 1920X1080 Monitor Dual HDMI PortablePS3 PS4 Gaming Screen
3.5inch 480x320 MCU SPI Serial TFT LCD Module Display
Meteor Screen 10.1" IPS Touch Screen (with RGB Animated light)
1602 LCD Display Module
16x16 LED Display Module
7 Inch 1024*600 HDMI LCD Display with Touch Screen
7 Inch 1024x600 TFT Display for Raspberry Pi B+ Pcduino Banana Pi
Elecrow RR040I 4 inch HD 800x480 Resolution IPS TFT Touch Screen Display for Raspberry Pi
7 Inch TFT Display for Raspberry Pi B+ Banana Pi BB BLACK
SF133M 13.3 inch 1920 x 1080 HDMI Portable Display for Raspberry Pi/ PS4/ XBOX/ NS
GC1016 10.1" TFT-LCD Monitor 1280*800 Color Screen with AV1 VGA HDMI BNC USB Input Built-in Speaker
2 inch IPS Module
Elecrow 10.1 Inch Touchscreen 1280x800 IPS TFT LCD Monitor Kit
8 inch Touchscreen IPS Display 1280x800 Small Portable Monitor Compatible with Raspberry Pi 540043 Win 111087 Jetson Nano
2.4 inch 320x240 SPI Serial TFT LCD Module Display With Driver IC ILI9341|With Touch Function
2.8 inch 320x240 SPI Serial TFT LCD Module Display With Driver IC ILI9341|With Touch Function
3.5 Inch 480*320 SPI TFT LCD Module with ILI9488 Driver|With Touch Function
4.0 Inch 480*320 SPI TFT LCD Module with ST7796 Driver|With Touch Function
2.8” 240x320 ESP32 LCD Touch Display | With WiFi and BT/BLE
3.2” 240x320 ESP32 LCD Touch Display | With WiFi and BT/BLE
3.5” 320x480 ESP32 LCD Touch Display | With WiFi and BT/BLE
2.8-inch IPS SPI LCD Capacitive Touch Display Module With ILI9341 Driver - 240x320 Resolution, Arduino Compatible
3.5-inch IPS SPI LCD Capacitive Touch Display Module With ST7796 Driver - 320x480 Resolution, Arduino Compatible
4.0-inch Capacitive Touch SPI LCD Display Module With ST7796 Driver - 320x480 Resolution, Arduino Compatible
4.3” 800*480 IPS Display 16BIT Parallel LCD Module| SSD1963 Driver |Capacitive Touch
5.0” 800*480 IPS Display 16BIT Parallel LCD Module| SSD1963 Driver |Capacitive Touch
7.0” 800*480 Display 16BIT Parallel LCD Module| SSD1963 Driver |Capacitive Touch
2.8inch TFT Screen 320*240 Touch Display for Arduino, Mega|ILI9341 Driver|Plug & Play
3.95 inch TFT Screen 480*320 Touch Display for Arduino, Mega | ST7796S Driver | Plug & Play
5inch IPS HD Display-C 1024*600 Touch Screen Compatible with Raspberry Pi/BB Black, etc
5inch HD Touch Display-D 1024*600 IPS Screen Compatible with Raspberry Pi/BB Black, etc
7inch IPS HD Touch Screen-D 1024*600 HD Monitor Compatible with Raspberry Pi/BB Black, etc
HMI Display
HMI Display
Wizee HMI touch display
CrowPanel HMI Display Wiki Content
CrowPanel ESP32 HMI Wiki Content
ESP Terminal with 3.5inch RGB Capacitive Touch Display
ESP Terminal with 3.5inch SPI Capacitive Touch Display
CrowPanel ESP32 HMI 2.4-inch Display
CrowPanel ESP32 HMI 2.8-inch Display
CrowPanel ESP32 HMI 3.5-inch Display
CrowPanel ESP32 HMI 4.3-inch Display
CrowPanel ESP32 HMI 5.0-inch Display
CrowPanel ESP32 HMI 7.0-inch Display
2 PACK 2.4-inch ESP32 Solo Miner LCD Display
2 PACK 2.8-inch ESP32 Solo Miner LCD Display
CrowPanel PICO HMI 2.4'' Display
CrowPanel PICO HMI 2.8'' Display
CrowPanel PICO HMI 3.5'' Display
CrowPanel PICO HMI 4.3'' Display
CrowPanel ESP32 1.28-inch Round Display
Pi Terminal
CrowPanel ESP32 E-Paper HMI 1.54-inch Display
CrowPanel ESP32 E-Paper HMI 2.13-inch Display
CrowPanel ESP32 E-Paper HMI 2.9-inch Display
CrowPanel ESP32 E-Paper HMI 3.7-inch Display
CrowPanel ESP32 E-Paper HMI 4.2-inch Display
CrowPanel ESP32 E-Paper HMI 5.79-inch Display
CrowPanel Advance 2.4-HMI ESP32 AI Display
CrowPanel Advance 2.8-HMI ESP32 AI Display
CrowPanel Advance 3.5-HMI ESP32 AI Display
CrowPanel Advance 4.3-HMI ESP32 AI Display
CrowPanel Advance 5.0-HMI ESP32 AI Display
CrowPanel Advance 7.0-HMI ESP32 AI Display
CrowPanel 1.28inch-HMI ESP32 Rotary Display 240*240 IPS Round Touch Knob Screen
CrowPanel 2.1inch-HMI ESP32 Rotary Display 480*480 IPS Round Touch Knob Screen
CrowPanel Advanced 5inch ESP32-P4 HMI AI Display 1024x600 IPS Touch Screen with WiFi 6
CrowPanel Advanced 7inch |ESP32-P4 HMI AI Display 1024x600 IPS Touch Screen with WiFi 6 Compatible with Arduino/LVGL
CrowPanel Advanced 9inch |ESP32-P4 HMI AI Display 1024x600 IPS Touch Screen with WiFi 6 Compatible with Arduino/LVGL
CrowPanel Advanced 10.1inch |ESP32-P4 HMI AI Display 1024x600 IPS Touch Screen with WiFi 6 Compatible with Arduino/LVGL
CrowVision
CrowVision
CrowVision 11.6'' Capacitive Touch Screen Portable HD 1366*768 IPS LCD Display
CrowVision 7.0" Touch Screen Capacitive Portable HDMI-compatible 1024*600 IPS LCD Monitor
CrowView
CrowView
CrowView Yoga 15.6" Dual Screen Portable Monitor |360° Foldable IPS Laptop Extender for Gaming and Mobile Office
CrowView Note 15.6"
Mechanical Keyboard
Mechanical Keyboard
Mechanical_Keyboard_ESP32-S3
Elecrow Services
Elecrow Services
Elecrow Services
PCB Fabricate Service Overview
Q&A for PCB service
Export gerber files from Eagle
Export gerber files from Proteus_ARES
Modules for Prototyping
Breadboard Power Supply
ULN2003 Stepper Motor Driver
Lipo Charger v1.0
LED matrix kit
RTD2556 Driver Board/Controller Board Kit
devDuino Sensor Node V1.3 (ATmega 328)
Adjustable Integrated DC-DC Module- LM2596S
Accessories
Accessories
Transparent Acrylic Switches Tester Collection
Application Kits
Application Kits
Crazepony MINI Quadcopter
Elecrow Cooperator/Partner
Cooperator Designer
Drop Shipping
Products Wiki
Raspberry Pi
Raspberry Pi
CrowPi
CrowPi-2
CrowPi-L
CrowPi-3
PICO W5 RP2040 Dev Board
Elecrow RP2350 Pico W5 Board
Mini PC Case With 1.3” OLED Screen For Raspberry Pi 5/Jetson Orin Nano
Pi Power M.2 NVMe&PoE+ Hat for Raspberry Pi 5 Support M.2 NVMe SSDs 2230/2242/2260/2280
Image Burning Method
Arduino Kit
Arduino Kit
GrowCube
Lora
Lora
Lora RA-08H Development Board
Lora RA-08H Node Board
Lora Basic Gateway Module
LR1302 LoRaWAN Gateway Module
LR1302 LoRaWAN HAT for RPI_PRD
LR1262 LoRaWAN Node Module
LR1262 Node Board LoRaWan Node Module for Long Range Communication
LoRaWAN LR1262 Development Board Integrated RP2040 with 1.8" LCD for Long Range Communication
Nrf52840 AT Instruction Description Documentation
Elecrow nRFLR1110 Wireless Transceiver Module
Elecrow nRFLR1121 Wireless Transceiver Module
Elecrow nRFLR1262 Wireless Transceiver Module
Elecrow nRFLRCC68 Wireless Transceiver Module
ThinkNode M1 Meshtastic (LoRa) Signal Transceiver Powered By nRF52840 with 1.54" Screen Support GPS-With Case-868 MHz
ThinkNode M2 Meshtastic (LoRa) Signal Transceiver Powered By ESP32-S3 with 1.3” OLED Display-Without Case
LR1262 Long-Range LoRa Wireless Transceiver Module | Ultra-Low Power | IoT/Industrial
LRCC68 Long-Range LoRa Wireless Transceiver Module | Ultra-Low Power | IoT/Industrial
ThinkNode G1 Indoor 8 Channels LoRaWAN Gateway Powered By SX1302 Chip
ThinkNode G3-Single Channel LoRaWAN Gateway ESP32-S3 Chip Smart Home, Smart IoT Solutions
ThinkNode M3 Meshtastic Tracker With GPS/WiFi/BLE function For Indoor and Outdoor Positioning
ThinkNode-M4 Power Bank LoRa Device with Meshtastic Function Powered By nRF52840
ThinkNode M5 Meshtastic (LoRa) Signal Transceiver |ESP32-S3
ThinkNode M6 Outdoor Solar Power for Meshtastic, Powered By nRF52840 Supports GPS
ThinkNode M6 Outdoor Solar Power for LoRa, Powered By nRF52840 Supports GPS-868 MHz
STEAM Education
STEAM Education
All-in-one Starter Common Board Kit for Arduino
All-in-one Starter Kit for Pico 2
All-in-one Starter Kit for Micro:bit with Common Board design:13 Modules and 21 Lessons
All-in-one Starter Kit for ESP32-P4 with Common Board design
AI Camera Development Board Vision Sensor Board Powered By ESP32
AI Panda ChatBot
AI Starter Kit for Jetson
Tutorials
Back to Community
AI Panda ChatBot
