SIM7670_4G_Module_with_Mini_PCIe_Interface
This SIM7670 4G module is a high-performance LTE Cat1 wireless module that uses Simcom's SIM 7670 and A7670 communication modules. Through the Mini PCIe interface, high-speed 4G data transmission and voice communication can be achieved. The module supports multiple frequency band options and is suitable for network requirements in various regions worldwide, ensuring wide application. It supports maximum 10Mbps downlink rate and 5Mbps uplink rate, and supports multiple protocols, including TCP/IP, FTP, IPV4, and GNSS satellite navigation system, providing excellent compatibility. It is compatible with Windows ⅞/10, Linux and Android USB drivers, and supports FOTA remote software upgrades to ensure continuous optimization and updates of the system.
The small size of the module makes it easy to be integrated into various IoT devices, meeting diverse application requirements. Its low-power design and reliable performance have led to its widespread use in fields such as IoT, industrial control, smart homes and automobiles. Whether used for data transmission, voice communication, or navigation positioning, the SIM7670 4G module provides a stable and efficient solution, making it an ideal choice for various smart devices.
Note: Applicable to Pi Terminal, click here to buy together.For customized requirements (based on MOQ), please contact us at service@elecrow.com.
Model CIR12704M
sim7670
  • Integrated ESP32-S3-WROOM-1-N16R8 module, built-in wireless communication 2.4 GHz Wi-Fi (802.11 b/g/n) and Bluetooth 5.0;
  • Support development environment Arduino IDE, Loxin IDF, Micropython and compatible with LVGL graphics library.
  • Built-in LVGL demo interface and Arduino example, plug and play.
  • LCD 800 * 480 7.0-inch IPS screen with driver IC ST7277.
  • Rich peripheral interfaces and wireless expansion capabilities to meet the needs of different areas.
sim7670-1
Option Global NA E
Main chip SIM 7670G SIM 7670NA A7670E
Frequency Band LTE-FDD:B1/B2/B3/B4/B5/B7/B8/B12/B13/B18/B19/B20/B25/B26/B28/B66/B71* LTE-TDD:B34/B38/B39/B40/B41 LTE-FDD: B2/B4/B5/B13/B14/B66/B71* LTE-FDD: B1/B3/B5/B7/B8/B20GSM: 900/1800MHz
Use Area Global North America Europe
GPS/GNSS Support
Network Protocols TCP/IP/IPV4/IPV6/MultiPDP/FTP/FPT5/HTTP/HTTPS/DNS
Data Transfer of LTE (Mbps) 10(DL)/5(UL)
Software Feature Support TLS/WWAN(RNDIS)/ECM Support TLS/WWAN(RNDIS)/ECM Support TLS/LBS/WWAN(RNDIS)/ECM
Firmware Upgrade USB/FOTA
Interface Type IPEX*2(LTE&GPS), PCIe, SIM socket
Operation Voltage 3.4-4.2V (Typical 3.8V)
Operation Temperature -40℃~+85℃
Size 50*30.2*1.6mm
The corresponding IO ports are as shown in the figure::
NO MiniPCIE PIN ELE7670 PIN IO TYPE Fuction
1 WAKE# NC
2 3.3VAUX VBAT Power A7670/SIM7670 Power PIN
3 COEX1 NC
4 GND GND Ground Ground PIN
5 COEX2 NC
6 1.5V NC
7 CLKREQ# NC
8 UIM PWR USIM VDD Power USIM Card VDD PIN
9 GND GND Ground Ground PIN
10 UIM DATA USIM DATA DIO USIM Card DATA PIN
11 REFCLK- NC
12 UIM CLK USIM CLK DI USIM Card CLK PIN
13 REFCLK+ NC
14 UIM RESET USIM RST DI USIM Card CLK PIN
15 GND GND
16 UIM VPP USIM DET DO USIM Card DET PIN
17 Reserved NC
18 GND GND Ground Ground PIN
19 Reserved NC
20 W DISABLE# GPS 1PPS DO A7670/SIM7670 GNSS 1PPS PIN
21 GND GND Ground Ground PIN
22 PERST# P RESET DI A7670/SIM7670 RESRET PIN
23 PERn0 NC
24 3.3VAUX VBAT Power A7670/SIM7670 Power PIN
25 PERp0 NC
26 GND GND Ground Ground PIN
27 GND GND Ground Ground PIN
28 1.5V NC
29 GND GND Ground Ground PIN
30 SMB CLK I2C CLK DI A7670/SIM7670 I2C CLK PIN
31 PETn0 NC
32 SMB DATA I2C SDA DIO A7670/SIM7670 I2C SDA PIN
33 PETp0 VDD 1V8 Power A7670/SIM7670 1.8V Power Output
34 GND GND Ground Ground PIN
35 GND GND Ground Ground PIN
36 USB D- USB D- DIO A7670/SIM7670 USB D- PIN
37 GND GND Ground Ground PIN
38 USB D+ USB D- DIO A7670/SIM7670 USB D+ PIN
39 3.3VAUX VBAT A7670/SIM7670 Power PIN
40 GND GND
41 3.3VAUX VBAT Power A7670/SIM7670 Power PIN
42 LED WWAN# NET LTE DO A7670/SIM7670 NET LTE LED PIN
43 GND GND Ground Ground PIN
44 LED WWAN# NC
45 Reserved NC
46 LED WWAN# P_PWRKEY DI A7670/SIM7670 PWRKEY PIN
47 Reserved NC
48 1.5V NC
49 Reserved NC
50 GND GND Ground Ground PIN
51 Reserved NC
52 3.3VAUX VBAT Power A7670/SIM7670 Power PIN
Applications
The products are widely used in healthcare, smart payment, public network intercom, environmental monitoring, energy monitoring, fleet management, smart industry and smart agriculture to enhance service efficiency and realize intelligent management and remote control.
Usge:
4G usage: plug in a 4G module and have a 4G card plugged in to use 4G internet.
sim7670-2
GNSS AT command:
AT+CGNSSPWR=1 Enabling GNSS +CGNSSPWR: READY!
AT+CGNSSTST=1 Enable GNSS data output OK
How to buy
Please visit this page to purchase ESP32 Display-7.0 inch(Advance_Series).
Support
