Crowbits-Pressure Sensor
The pressure sensor is an analog input module, it is a touch-activated sensor. The pressure sensor controls your circuit by how much pressure you put on it.
- Analog input module
- Operating Voltage: 3.3V DC
- Range of forces: 0.2N to 20N (100g~10KG)
1. You also need to prepare a power module, such as Crowbits-Power Supply, and an output module, such as Crowbits-LED.
3. Turn on the power. Press the sensor slowly and you will see that the LED behind it will gradually light up.
