Crowbits-PIR Sensor
The PIR sensor is a digital input module, it's an electronic sensor that measures infrared light radiating from objects in its field of view. It's often used in PIR-based motion detectors.
- Digital input module
- Operating Voltage: 3.3V DC
1. You also need to prepare a power module, such as Crowbits-Power Supply, and an output module, such as Crowbits-LED.
3. Then, turn on the power. When the sensor detects someone moving, the LED behind it lights up.
