Crowtail- Magnetic Switch
This is a Crowtail interface compatible Magnetic switch module. It is based on encapsulated dry reed switch MKA14103. MKA14103 is single-pole, single throw (SPST) type, having normally open ruthenium contacts. The sensor is a double-ended type and may be actuated with an electromagnet, a permanent magnet or a combination of both. The magnetic switch is a wonderful tool for designers who would like to turn a circuit on and off based on proximity.
Model: CT009320S
- Crowtail compatible interface
- Minimum external parts
- 10W rating
- Rugged encapsulation
Application Ideas¶
- Proximity Sensor
- Security Alarm Sensor
- Level Sensor
- Flow Sensor
- Pulse Counter
Dimensions(mm):27.8(L)x20.0(W)x6.8(H)
Item | Min | Norm | Max | Unit |
Working Voltage | 4.75 | 5.0 | 5.25 | V |
Switched Power | 10 | 10 | 10 | W |
Switched Voltage AC,RMS value(max) | < 140 | < 140 | < 140 | V |
Switched Current DC | < 500 | < 500 | < 500 | mA |
Carry Current DC | < 0.5 | < 0.5 | < 0.5 | A |
Contact Resistance | <200 | <200 | <200 | mΩ |
Insulation Resistance | >106 | >106 | >106 | MΩ |
Operating Temperature | -40 | - | 125 | ℃ |
Operate Range | 10 | - | 40 | AT |
With Arduino¶
1.The SIG pin of the module output LOW normally. When a magnet approaches the switch, the magnetic switch close and the SIG pin output HIGH. The following sketch demonstrates a simple application of using the Magnetic switch to control the led. When you put a magnet that has enough magnetic power close to the module, the switch is closed .Then the SIG pin out put a high voltage. You can use this to control the led. As the picture on the below indicates, the Magnetic switch is connected to digital port 2 of the Crowtail - Basic Shield and the LED is connected to digital port 5. When there is Magnetic approaches the switch, the SIG pin output a High voltage. Then the LED light. The hardware installation is as follows:
2.Copy and paste code below to a new Arduino sketch.
#define MAGNECTIC_SWITCH 2
#define LED 5//the on board LED of the Arduino or Seeeduino
pinsInit();
if(isNearMagnet())//if the magnetic switch is near the magnet?
turnOnLED();
else
turnOffLED();
void pinsInit()
pinMode(MAGNECTIC_SWITCH, INPUT);
pinMode(LED,OUTPUT);
/*If the magnetic switch is near the magnet, it will return ture, */
/*otherwise it will return false */
boolean isNearMagnet()
int sensorValue = digitalRead(MAGNECTIC_SWITCH);
if(sensorValue == HIGH)//if the sensor value is HIGH?
return true;//yes,return ture
else
return false;//no,return false
void turnOnLED()
digitalWrite(LED,HIGH);
void turnOffLED()
digitalWrite(LED,LOW);
Then the LED light when there is Magnetic approaches the switch. Have a try!
