CrowVision 7.0" Touch Screen Capacitive Portable HDMI-compatible 1024*600 IPS LCD Monitor
CrowVision 7-inch touch screen is designed for all-in-one machines. It features a 1024*600 high-resolution screen and IPS panel, providing a superior visual experience. The industrial design-style rear-fixed metal structure is compatible with various SBC single-board computers, with a reasonable layout and neat wiring, making it easy to power up and use with simple operations. It also supports a vertical screen. If you're looking for a high-performance, easy-to-assemble, and feature-rich all-in-one computer, CrowVision is the perfect choice for you.
The screen uses HDMI-compatible communication and supports capacitive multi-touch. It has reserved interfaces and buttons for speakers and other accessories, making it adaptable to different usage scenarios. It can be used with a variety of commonly available single-board computers such as Raspberry Pi, Jetson Nano, and is plug-and-play, while also being fully compatible with the operating systems of single-board computers (such as Raspbian, Ubuntu, Windows, Android, MAC OS, and Chrome OS, etc.). You can also design a unique and exquisite protective shell for the screen and assemble it for a completely distinctive look. You can use our 3D printing service to create a beautiful protective shell.
This screen can be widely used in automation application control system displays, personal DIY projects, secondary screen/second window displays, single-board computer audio-video display equipment, HDMI-compatible communication devices, game console expansion screens, and other scenarios.
Model: CRV00117L
Feature¶
- 7-inch high-resolution screen with 1024*600 resolution, IPS panel, and 178° wide viewing angle provides a better visual experience;
- Unique rear fixing structure with sliding fixing pillars, compatible with most single-board computer models, easy to assemble;
- Wide compatibility, compatible with multiple operating systems (Raspbian, Ubuntu, Windows, Android, MAC OS, and Chrome OS);
- Supports audio, video, and capacitive touch, plug and play;
- Integrates a variety of peripheral interfaces (such as speakers, headphones, keypads, touchscreens) and onboard OSD adjustment keys;
- Mainboard is equipped with power conversion function output 5V/3A, not need to separately connect an external power supply for the single-board computer.
- Size: 7 Inch
- Touch Type: 5-point Capacitive Touch
- Resolution: 1024*600
- Color Depth: 16M
- Vertical Screen: supported
- Viewing angle: 178°Wide Viewing Angle
- Display Type: IPS Panel
- Screen Type: TFT-LCD
- External power supply: 12V-2A
- Digital input: HDMI-compatible interface
- Interface: 1xKeypad interface, 1x Power supply 5V output, 1x Mini HD interface, 1xTouch interface, 1x Speaker interface, 1x Headphone socket,1x Power supply 12V input
- CompatibilitySystem: Raspbian, Ubuntu, Windows, Android, MAC OS, and Chrome OS,etc.
- Active Area: 99.9*167mm(W*L)
- Dimension Size: 110.3*204mm(W*L)
- Net weight: 298g
Compatibility¶
Resources¶
Crowvision_7.0_Display_Specification
CrowVision_7.0_Schematic_Diagram
