Crowbits-Protoboard
Protoboard is a module with a breadboard, you can build all kinds of circuits you want, and lead out 16 interfaces.
- Easy to use
 - Breadboard style
- Operating Voltage: 3.3V DC
 - Dimensions: 56(L)*56(W)*13(H) mm
1. You can connect any position on the breadboard to the female connector with a DuPont cable, and you can output the signal to other modules.
2. For example, I want to connect a position on the breadboard to the fourth output port, which can be connected as follows.
