Crowbits-IR Reflective Sensor
The IR reflective sensor is a digital input module, it acts like a pair of eyes inside your circuit, it senses objects around it and takes action. In real life, the IR reflective sensor is often used as car tracking devices.
  • Easy to use
  • Digital input module
Application
  • Obstacle Detection
  • Compact disk players, Copiers, Game machines
  • Operating Voltage: 3.3V DC
Usage
1. You also need to prepare a power module, such as Crowbits-Power Supply, and an output module, such as Crowbits-LED.
3. Then, turn on the power. When the sensor detects an object, the LED behind it will light up.
