CrowPi-3
CrowPi 3 is constructed around the newly released Raspberry Pi 5 development board by the Raspberry Pi Foundation. It serves as a powerful tool that integrates learning, design, and programming, offering a new learning platform for coding enthusiasts and developers. CrowPi 3 is compatible with various development boards including Pi 5, Arduino Nano, micro:bit, and Pico series. It integrates a variety of sensors and is equipped with a display, camera, and microphone, facilitating the construction of an AI smart hardware platform. Additionally, it offers abundant course resources, making CrowPi 3 an ideal choice for learning programming.
Model: SER14003P crowpi_3_1_1
Alt text
  • Compatible with multiple development boards
    • Supports 4 mainstream open source development boards including Raspberry Pi 5, Arduino Nano, micro:bit, Pico, etc., covering a wide range of user groups from beginners to professional engineers, meeting the learning and development needs at different stages.
  • Integrated with multiple sensors and modules
    • Built-in 30+ commonly used sensors and electronic modules, with clear layout and clear identification, ready to use after power-on, no complicated wiring required, and easy implementation of various sensor project practices and AI visual development.
  • Rich hardware interfaces
    • Equipped with Ethernet, HDMI, audio interface, DEBUG interface, power input and output, USB 3.0, I2C/UART interface and Raspberry Pi native 40-Pin GPIO interface, it meets the needs of most application scenarios and has strong scalability.
  • Intelligent interactive experience
    • Equipped with a 4.3-inch capacitive touch display, a 2-megapixel camera and a high-sensitivity microphone, it supports AI visual recognition, voice recognition and interaction, providing an intuitive and smooth user experience.
  • Diverse programming support
    • Provides a graphical programming interface, fun examples, mini-game challenges and 100+ course resources, covering program codes, experimental wiring diagrams, etc., suitable for zero-based entry and advanced learning, improving programming learning efficiency.
  • AI development capabilities
    • Combined with the Raspberry Pi 5 processor, it can support AI applications such as OpenCV image processing, object recognition and tracking, face recognition, QR code recognition, pedestrian and car detection, and can explore the LLM large language model and deep learning development framework to help users easily play with artificial intelligence.
  • Dynamic programming lighting effects
    • Built-in a variety of dynamic programming lighting effects to enhance learning fun and visual experience and stimulate user creativity.
  • Portable and easy-to-use design
    • Integrated portable design, ready to use, no complex configuration required, suitable for classroom teaching, personal learning, project development and on-site demonstration and other usage scenarios.
  • Comprehensive learning resource support
    • Equipped with rich learning resources and software tools, it helps users get started quickly and easily achieve programming learning and project development from basic to advanced.
CrowPi 3 integrates learning, design, programming, and AI exploration, and is a portable programming laboratory for the future. Whether you are a student, educator, or professional developer, you can easily step into the world of artificial intelligence and creative development with it.
Specifications
SBC-Raspberry Pi 5
CPU/SoC Broadcom BCM2712, ARM Cortex-A76, up to 2.4GHz, quad-core, 64-bit
GPU VideoCore VII GPU @800MHz, supports OpenGL ES 3.1, Vulkan 1.2(dual micro HDMI ports, supports dual 4K@60fps video output)
RAM 4GB/8GB LPDDR4X-4267 SDRAM
Development Python, C/C++, Java, Node.js, etc.
Development environments (IDE) Thonny, Visual Studio Code, etc. (supports Node-RED)
Support frameworks/libraries TensorFlow, OpenCV, Docker, etc.
Operating systems Official: Raspberry Pi OSOther compatible: Ubuntu Desktop, Manjaro ARM, Kali Linux, LibreELEC (Media Center), OSMC, etc.
Screen
Size 4.3 inch
Resolution 800RGB(H)x480(V)
Active area 95.04(W)×53.858(H) mm
Display panel IPS wide viewing angle
Brightness 300 cd/m² (Typ.)
Color depth 16.7M
Contrast ratio 1200:1
Backlight 10-LED
Touch type Full capacitive touch, single point
Wireless Connection
Wi-Fi Wi-Fi 6 (802.11ax), supports 2.4GHz and 5GHz bands
Bluetooth Bluetooth 5.2, Bluetooth BLE, supports low-power device connection
Interface (Peripheral)
Type-C (IN/OUT) For data transmission and DC power supply. The input rated voltage is 5V/5A, the output is 5V/2A, and it supports PD function.
Type-C (OUT) A USB Type-C interface with output function, used to transmit data to the outside or to power/charge other devices, with an output rated voltage of 5V/2A.
HDMI This interface is the HDMI interface that comes with Pi 5
Headphone jack Used to connect headphones or external speakers, output audio signals, 3.5mm.
Ethernet Gigabit Ethernet interface 10/100/1000 Mbps.
USB 3.0 USB 3.0 port, supports simultaneous 5Gbps operation
USB 2.0 USB 2.0 specification port
DEBUG DEBUG interface is used for debugging of microcontroller modules, allows users to connect devices such as debuggers or logic analyzers.
Button
Power button/(Power) Press and hold the power button for 1 second to turn the device on, and press and hold the power button for 3 seconds to turn the device off.
Volume/Brightness button Used to adjust the volume and screen brightness of the device.
LED Indicator Light
PWR Power indicator light, lights up red after the device is turned on.
CHG Lithium battery status indicator, flashes red when low voltage, lights up red when charging, lights up green when fully charged.
Sensor(Input)
EEPROM Gyroscope/Acceleration Five-way joystick Button*4
Touch Sensing RFID sensing ultrasound Flame sensor
Relay Voltage detection Angle tilt Encoder
PIR sensor Sound detection Infrared receiver Temperature and humidity
Hall sensor Light intensity Camera Microphone
Sensor(Output)
Vibration motor Digital tube Buzzer LED*6 running lights 8*8 RGB matrix LCD 1602
Other Interface
1*40-Pin pin,1*Ambient Lighting, 2* Breadboard, 1* I2C interface,1* UART interface, 1* Servo interface, 1* Stepper motor interface
Mechanical
Size 285*185*38mm
Shell ABS+PC
Installation method Desktop, portable
Operating temperature -10~60 ℃
Relative humidity 10%-95%, @ 40°C (non-condensing)
Power Input 5V/5A, with PD protocol
Power Output 5V/2A
SAFETY WARNING
  • This appliance can be used by children aged from 8 years and above and persons with reduced physical, sensory or mental capabilities or lack of experience and knowledge if they have been given supervision or instruction concerning use of the appliance in a safe way and understand the hazards involved.
  • Children shall not play with the appliance.
  • Cleaning and user maintenance shall not be made by children without supervision.
WARNING: Use the detachable supply unit provided with this appliance only.
Structure
crowpi_3_1_2
1.Type-C port: PD5V/5A Input/5V/2A Output 2.Type-C port: 5V/2A Output 3.HDMI port 4.Battery Status LED
5.Power-On Status LED 6.Power Button 7.Volume and brightness ± 8.3.5mm headphone jack
9.Speakers 10.Cooling hole 11.Handle 12.Storage groove
13.18650 battery holder 14.Function adapter board 15.Raspberry Pi fixed position 16.Camera signal adapter board
17.Raspberry Pi network port 18.Raspberry Pi USB3.0 port 19.Raspberry Pi USB2.0 port 20.Debug port
Battery Status LED: Red flashing at low voltage, solid red while charging, solid green after fully charged.
Power-On Status LED: The device remains red after powering on
Power Button: Short press to power on, long press to power off (release upon completion)
Debug port Used for debugging microcontroller modules such as Arduino Nano and Pico series.
Install Raspberry Pi
Step 1. Insert the SD card (with built-in system) into the Raspberry Pi's SD card slot.
Step 2.Slide to the right to open the back cover of the CrowPi 3 Raspberry Pi enclosure.
crowpi_3_1_4
Step 3.Peel off the masking tape on the function adapter board and the camera signal adapter board.
crowpi_3_1_5
Step 4.Insert the function adapter board into the Raspberry Pi's Micro HDMl port and Type-C port.
crowpi_3_1_6
Step 5.Insert the camera signal adapter board into the outermost USB 2.0 port of the Raspberry Pi 5.
crowpi_3_1_7
Step 6.Verticallyinstall the Raspberry Pi 5 with the inserted TF card into the Raspberry Pienclosure.
crowpi_3_1_8
Step 7. Pace two 18650 batteries in the correct positive and negative direction.
crowpi_3_1_9
Note:
1.The battery is not included in the Basic Kit. lf you need it,please purchaseit separately or opt for the Advanced Kit. 2.Users who do not need built-in batteries can skip this step.
Step 8. Close the cover. crowpi_3_1_10
FAQ:
  1. Unable to boot Make sure you are using the correct charger and that the SD card is inserted into the Raspberry Pi.
  2. The module or sensor on the PCBA board cannot be used Please set the controller board selection switch to the correct position. If connecting to Raspberry Pi 5, set it to position 1. If connecting to Arduino Nano and Pico, set it to position 2.
  3. After setting up the circuit on the breadboard and not getting the expected output Please confirm whether the controller board selection switch has been switched to position 2.
  4. The screen goes black and crashes Please check whether a high-current peripheral is mounted, causing an insufficient power supply.
  5. Camera and microphone do not work Please confirm if the camera signal adapter board is fully connected.
  6. Unable to connect to the network Please turn on the wireless network or connect to the Raspberry Pi Ethernet network port.
Parameters
crowpi_3_1_3
How to use
Hardware:
The gpio call form of the sensor module
Raspberry(3.3v):
Function connector quantities reference voltage Function name for IO
Accelerometer&Gyro I2C 1 3.3V SCL1,SDA1
1602 LCD I2C 1 5V SCL1,SDA1
Digital display I2C 1 5V SCL1,SDA1
LIGHT SENSOR I2C 1 3.3V SCL1,SDA1
EEPROM I2C 1 5V SCL1,SDA1
Temperature & Humidity I2C 1 3.3V SCL1,SDA1
IIC I2C 1 5V SCL1,SDA1
Encoder I2C 2 5V SCL1,SDA1
HALL SENSOR I2C/GPIO 1 5V IO26
STEP MOTOR I2C/GPIO 4 5V IO21,IO22,IO23,IO06(STEP1,2,3,4)
Vibration sensor I2C/GPIO 1 5V IO02
LED*6 IIC-PR2040,IO10 6 5V SCL1,SDA1
8*8 RGB_LED IIC-PR2040,IO6 1 5V SCL1,SDA1
ROCKER SPI-ADC 2 3.3V CE1,SCLK,MISO,MOSI
custom_key*4 SPI-ADC 1 3.3V CE1,SCLK,MISO,MOSI
Voltage Sensor SPI-ADC 1 3.3V CE1,SCLK,MISO,MOSI
RFID SPI 1 3.3V CE0,SCLK,MISO,MOSI
SERVO GPIO 1 5V IO24
Touch Sensor GPIO 1 3.3V IO0
Ultrasonic Sensor GPIO 2 3.3V IO25(EHCO),IO27(TRIG)
Flame GPIO 1 3.3V IO07
Relay GPIO 1 5V IO29
Tilt sensor GPIO 1 3.3V IO03
Motion sensor(PIR) GPIO 1 3.3V IO04
SOUND_SENSOR GPIO 1 3.3V IO05
BUZZER GPIO 1 5V IO01
IR Remote Sensor GPIO 1 3.3V IO28
uart uart 1 3.3V TXD, RXD
burn-in port USB-UART 1 5V TXD, RXD
Arduino Nano(5v):
Note:Before using the 40-pin header, ensure the DIP switch is set to the corresponding host controller: Position 1 is for Raspberry Pi, Position 2 is for Arduino, Microbit, and Pico.
Accelerometer&Gyro I2C 1 3.3V A5,SCL;A4,SDA
1602 LCD I2C 1 5V A5,SCL;A4,SDA
Digital display I2C 1 5V A5,SCL;A4,SDA
LIGHT SENSOR I2C 1 3.3V A5,SCL;A4,SDA
EEPROM I2C 1 5V A5,SCL;A4,SDA
Temperature & Humidity I2C 1 3.3V A5,SCL;A4,SDA
IIC I2C 1 5V A5,SCL;A4,SDA
Encoder I2C 2 5V A5,SCL;A4,SDA
HALL SENSOR I2C/GPIO 1 5V A5,SCL;A4,SDA
STEP MOTOR I2C/GPIO 4 5V A5,SCL;A4,SDA
Vibration sensor I2C/GPIO 1 5V A5,SCL;A4,SDA
LED*6 IIC-PR2040,IO10 6 5V A5,SCL;A4,SDA
8*8 RGB_LED IIC-PR2040,IO6 1 5V A5,SCL;A4,SDA
ROCKER SPI-ADC 2 3.3V A6,A7
custom_key*4 SPI-ADC 1 3.3V D13,D12,D11,D10(CS)
Voltage Sensor SPI-ADC 1 3.3V D13,D12,D11,D10(CS)
RFID SPI 1 3.3V D13,D12,D11,D9(CS)
SERVO GPIO 1 5V D3
Touch Sensor GPIO 1 3.3V A0
Ultrasonic Sensor GPIO 2 3.3V A1(TRIG),D5(EHCO)
Flame GPIO 1 3.3V A2
Relay GPIO 1 5V A3
Tilt sensor GPIO 1 3.3V D7
Motion sensor(PIR) GPIO 1 3.3V D4
SOUND_SENSOR GPIO 1 3.3V D8
BUZZER GPIO 1 5V D6
IR Remote Sensor GPIO 1 3.3V D2
Micro:bit(3.3V):
crowpi_3_1_13
Accelerometer&Gyro I2C 1 3.3V P19,SCL;P20,SDA
1602 LCD I2C 1 5V P19,SCL;P20,SDA
Digital display I2C 1 5V P19,SCL;P20,SDA
LIGHT SENSOR I2C 1 3.3V P19,SCL;P20,SDA
EEPROM I2C 1 5V P19,SCL;P20,SDA
Temperature & Humidity I2C 1 3.3V P19,SCL;P20,SDA
IIC I2C 1 5V P19,SCL;P20,SDA
Encoder I2C 2 5V P19,SCL;P20,SDA
HALL SENSOR I2C/GPIO 1 5V P19,SCL;P20,SDA
STEP MOTOR I2C/GPIO 4 5V P19,SCL;P20,SDA
Vibration sensor I2C/GPIO 1 5V P19,SCL;P20,SDA
LED*6 IIC-PR2040,IO10 6 5V P1
8*8 RGB_LED IIC-PR2040,IO6 1 5V P12
ROCKER SPI-ADC 2 3.3V P13,P14,P15,P16(CS)
custom_key*4 SPI-ADC 1 3.3V P13,P14,P15,P16(CS)
Voltage Sensor SPI-ADC 1 3.3V P13,P14,P15,P16(CS)
RFID SPI 1 3.3V P13,P14,P15,P4(CS)
SERVO GPIO 1 5V P10
Touch Sensor GPIO 1 3.3V P3
Ultrasonic Sensor GPIO 2 3.3V P6(TRIG),P11(EHCO)
Flame GPIO 1 3.3V P9
Relay GPIO 1 5V P2
Tilt sensor GPIO 1 3.3V P7
Motion sensor(PIR) GPIO 1 3.3V P5
SOUND_SENSOR GPIO 1 3.3V NC
BUZZER GPIO 1 5V P0
IR Remote Sensor GPIO 1 3.3V P8
uart uart 1 3.3V NC
burn-in port USB-UART 1 5V NC
PICO(3.3V):
crowpi_3_1_14
Accelerometer&Gyro I2C 1 3.3V P17,SCL;P16,SDA
1602 LCD I2C 1 5V P17,SCL;P16,SDA
Digital display I2C 1 5V P17,SCL;P16,SDA
LIGHT SENSOR I2C 1 3.3V P17,SCL;P16,SDA
EEPROM I2C 1 5V P17,SCL;P16,SDA
Temperature & Humidity I2C 1 3.3V P17,SCL;P16,SDA
IIC I2C 1 5V P17,SCL;P16,SDA
Encoder I2C 2 5V P17,SCL;P16,SDA
HALL SENSOR I2C/GPIO 1 5V P21
STEP MOTOR I2C/GPIO 4 5V P22,P26,P27,P28(STEP1,2,3,4)
Vibration sensor I2C/GPIO 1 5V P10
LED*6 IIC-PR2040,IO10 6 5V P17,SCL;P16,SDA
8*8 RGB_LED IIC-PR2040,IO6 1 5V P17,SCL;P16,SDA
ROCKER SPI-ADC 2 3.3V P14,P12,P15,P13(CS)
custom_key*4 SPI-ADC 1 3.3V P14,P12,P15,P13(CS)
Voltage Sensor SPI-ADC 1 3.3V P14,P12,P15,P13(CS)
RFID SPI 1 3.3V P14,P12,P15,P11(CS)
SERVO GPIO 1 5V P8
Touch Sensor GPIO 1 3.3V P20
Ultrasonic Sensor GPIO 2 3.3V P3(TRIG),P9(EHCO)
Flame GPIO 1 3.3V P7
Relay GPIO 1 5V P18
Tilt sensor GPIO 1 3.3V P4
Motion sensor(PIR) GPIO 1 3.3V P6
SOUND_SENSOR GPIO 1 3.3V p5
BUZZER GPIO 1 5V P19
IR Remote Sensor GPIO 1 3.3V P2
uart uart 1 3.3V P0,TX;P1;RX
Software:
This is software specifically designed for CrowPi 3 users, featuring over 150 meticulously planned learning courses that offer a convenient, ready-to-use experience. The provided electronic components, circuits, and courses cover a wide range of knowledge points, ensuring that users can quickly grasp the basic principles of electronics and programming through practical operations. For the most popular artificial intelligence applications, such as facial and speech recognition, as well as AI interaction, we have also provided some AI courses and built-in model libraries.
Parts
Parts name Function
Learing Python lessons:Let users quickly master the knowledge of python programming and software and hardware interaction
Scratch lessons:Let users quickly master the knowledge of scratch programming and software and hardware interaction
Projects 20 small applications designed for quick familiarity with CrowPi 2 hardware features
Minecraft Use game Minecraft to open the door to python programming world for children, teaching in fun
AI Get the most popular knowledge of AI- face recognition and speech recognition
Python Built-in python programming client
Game Experience the fun of simple Mini Game written by python and develop your child's brain
Micro:bit Makecode entry which is designed for Micro:bit programming
Scratch Built-in Scratch Visual Programming Client
Arduino Built-in Arduino programming IDE
Main page and User Settings
crowpi_3_1_11
1.README Manual:
A brief overview of the main interface and the functions of each section.
2.Ai Chat:
Al Voice Agent, lt can help you access a wide range of information, control various hardware devices, and even chat with you for companionship. lts name is "Crow," and you can wake it up by saying "Hello Crow."
3.Return to the Raspberry Pi desktop.
4.Shutdown Button:
Choose to either shut down or restart the Raspberry Pi.
5.Learning courses:
All the courses on the CrowPi3 include Al, Python, Node-RED, Micro:bit, Pico, Arduino, and Minecraft.
6.Applications:
All the applications on the CrowPi 3 include Projects, Al Computer Vision, Al Generated Content, Al Voice Cloning,Python IDE, Arduino IDE, Micro:bit, Game and Scratch.
Software operations (coming soon)
Resources
FAQ:
Device Binding to AI Server Operation Video
  1. If you find that your Crowpi3 does not display a 6-digit verification code after booting up,
crowpi3-fad1
Unable to bind the “elecrow Ai” server. Or, you have already bound the “elecrow Ai” server using a verification code, but after use, your points remain unchanged, or you are unable to use the service and receive an insufficient points message. Please follow the troubleshooting steps below:
① Exit the learning system: Click the “X” in the upper-right corner, then click “Yes.”
crowpi3-fad2
② Click the file system icon in the upper-left corner.
crowpi3-fad3
③ Enter the following sections respectively:
/home/pi/elecrow_ai/elecrow_ai_big
/home/pi/elecrow_ai/elecrow_ai_samll
/usr/share/.user/Login_Verification/verify
Delete the corresponding “config” files in these three paths to ensure that the “config” files in all three paths are removed.
crowpi3-fad4
crowpi3-fad5
crowpi3-fad6
④ Restart Crowpi
If all three “config” files have been confirmed deleted and the issue persists after restarting Crowpi, open Terminal, enter the “ifconfig” command, capture your device's MAC address, and contact technical support.
crowpi3-fad7
How to buy
Please visit this page to purchase crowpi 3.
Support
