Crowbits-Hall Sensor
The hall sensor is a digital input module that is used to measure the magnitude of a magnetic field, it converts the change of magnetic field into a change in output voltage.
- Digital input module
 - Easy to use
 - High sensitivity
- Operating Voltage: 3.3V DC
1. You also need to prepare a power module, such as Crowbits-Power Supply, and an output module, such as Crowbits-LED.
3. Then, turn on the power. When the sensor detects N polar magnetic field, the LED behind it will light up.
