Crowbits-IR Emitter
The Crowbits-IR Emitter is an LED make from gallium arsenide, with its color centered around 940nm. It's used to transmit infrared signals through an infrared LED, while there is an Infrared receiver to get the signals on the other side. We can not only use the emitter to transmit data or commands, but also to emulate remotes to control your home appliance using an Arduino.
- Remote controller system
 - Easy to use
- Operating Voltage: 3.3V DC
 - Dimensions: 31.5(L)*24.5(W)*13(H)mm
1. You need to prepare two Crowbits motherboards, such as Crowbits-UNO board. And a Crowbits-IR Receiver board.
2. Connect the Crowbits-IR Receiver board to the D2 interface of the Crowbits-UNO board. Connect the Crowbits-IR Emitter board to the D9 interface of another Crowbits-UNO board.
3. Download the library “IRSendRev”. Unzip and put it in the libraries file, for example C:\Program Files (x86)\Arduino\libraries.
4.Open the code directly by the path:File -> Example ->IRSendRev->sendTest. Download this program to the motherboard connected to the Crowbits-IR Emitter module.
//IR sent demo v1.0
//Connect the IR sent pins to D3 for this demo
#include <IRSendRev.h>
    //enableIROut(38);
//unsigned char d[] = {9, 90, 91, 11, 31, 4, 1, 2, 3, 4};
unsigned char d[] = {15, 70, 70, 20, 60, 10, 1, 2, 3, 4,5,6,7,8,9,10};
//Very Important:
//the first parameter(15): the data that needs to be sent;
//the next 2 parameter(70,70): the logic high and low duration of "Start";
//the next 2 parameter(20,60): the logic "short" and "long"duration in the communication
//                             that to say:  if "0", the high duration is 20ms and  low is 20 ms; while logic "1",
//                              the high duration is 20 ms and low is 60 ms;
//the next 2 parameter(10): number of data you will sent;
//the next parameter(1, 2, 3, 4,5,6,7,8,9,10): data you will sent ;
    IR.Send(d, 38);//sent the data via 38Kz IR
    delay(1000);
5.Open the code directly by the path:File -> Example ->IRSendRev->revTest. Download this program to the motherboard connected to the Crowbits-IR Receiver module.
//IR receive demo v1.0
//Connect the IR sent pins to D2 for this demo
//#include <IRSendRevInt.h>
    IR.Init(2);
    Serial.println("init over");
unsigned char dta[20];
    if(IR.IsDta())
       // IR.Recv(dta);
        int length= IR.Recv(dta);
        for (int i =0;i<length;i++)
          Serial.print(dta[i]);
          Serial.print("\t");
        Serial.println();
// Very Important:
// the received data is comprised of the trsmission parameters , please refer to
// the sendTest.ino in the library ;
6. After downloading the two programs, open the serial port of the motherboard connected to the Crowbits of the Crowbits-IR Receiver module, the baud rate is set to 9600, and then you will receive the information sent by the transmitter module, as shown in the figure:
