ThinkNode M3 Meshtastic Tracker With GPS/WiFi/BLE function For Indoor and Outdoor Positioning¶
ThinkNode-M3 Meshtastic Tracker - High-precision Positioning Device¶
The ThinkNode-M3 Meshtastic tracker is a high-performance device designed specifically for Meshtastic users. Integrating the LR1110, nRF52840, and GPS modules, it provides a high-precision, low-power positioning and communication solution. Its lightweight design makes it easy to carry and install, ensuring accurate location tracking whether worn on the body, mounted on a vehicle, or discreetly placed anywhere.
The Meshtastic Tracker can be linked to the Meshtastic app on your phone, enabling communication and positioning even in environments without cell phone signals or network coverage. It's perfect for outdoor activities like hiking, camping, or emergency rescue.
The ThinkNode-M3 LoRaWAN Tracker uses a magnetic charging design, sends a message once a minute, and can work for up to 18 hours. It also monitors ambient temperature, humidity, and movement. A one-touch alert function allows for quick distress signals in emeThe message is sent once every minute and can work for up to 18 hours. rgencies. The IP66 rating ensures durability and reliability in a variety of harsh environments, making it an ideal choice for outdoor adventures and emergencies.
Model ILO13903D
Hardware Overview¶
| Main control IC | nRF52840 |
| LoRa Chip | LR1110 |
| L****ORA Frequency | EU868/US915 |
| Sensitivity requirement | -140 dBm or above |
| Maximum transmission power | +20 dBm |
| Transmission rate range | 1.76~62.5Kbps |
| LoRa frequency range | 860MHz-960MHz |
| Communication distance | 5~6 kilometers |
| Bluetooth | Bluetooth 5.0 |
| GNSS Location | Support GPS/GLONASS/GALILEO/BDS |
| GNSS Sensitivity | -148dbm (cold start) -156dbm (hot start)-160dbm (recapture) -162dbm (tracking) |
| GNSS Positioning accuracy | <1.5m(CEP50) |
| Sensors | Temperature Sensor, humidity Sensor, accelerometer |
| Indicator | One Red/Green/Blue three-color indicator light |
| Button | Power On/Off/SOS Trigger |
| Battery Capacity | 760mAh, lithium battery |
| IP Rating | IP66 |
| Operating temperature | -20℃-+60℃ |
| Charging method | Magnetic charging |
| Antenna | Internal onboard antenna (GNSS/LORA/WIFI/BLE) |
| Power Supply | 5V DC |
| Size | L/W/H: 64*64*10 (mm)Fixed Base: 68*68*10.2 (mm) |
| Material | PC+ABS |
| Certificate | CE / FCC |
| Net Weight | 40g |
Button Function Guide:¶
Press and hold for 3 seconds to power on. Upon startup, the red indicator light illuminates for 5 seconds while the buzzer sounds for 2 seconds before stopping. After 3 seconds, the blue light flashes continuously, indicating readiness for connection (searching for Bluetooth).
Press and hold for 5 seconds to enter sleep mode. The red light flashes rapidly for 3 seconds while the buzzer sounds for 3 seconds.
Press and hold continuously for 10 seconds to reset, forcing the device to restart.
USB Instructions:¶
Enter programming mode by holding the reset button for 20 seconds. The computer will display an ‘ELECROWBOOT drive’; select the firmware to be programmed and drag it into the drive.
Hold the reset button for 10 seconds to exit programming mode, then press it for 3 seconds to power on the device.
Should the device become bricked, connect it to a computer via USB to restart it.
Before use, please ensure the firmware has been downloaded. (The corresponding firmware is also provided prior to shipment.)¶
Burning Firmware¶
ClickMeshtastic firmware
1,Select the corresponding firmware.
2, follow the steps to download the firmware.
M3 firmware will be released shortly.¶
example 1:¶
Conducting hiking expeditions and scientific sampling activities in remote mountain valleys. The team utilised nodes equipped with ThinkNode M4 devices as Meshtastic relays to facilitate information transmission and location sharing. The extended battery life provided by the large-capacity batteries ensured reliable communication support for the team.¶
The following outlines the procedure for transmitting signals to the designated relay point.¶
How to obtain the app:
1: Visit the Google Play Store (https://play.google.com/), search for ‘meshtastic’, locate the app, and download it for installation.
2: Visit the official Meshtastic website (https://meshtastic.org/downloads/) and download the software.
Before use, press and hold the power button for three seconds to switch on:
Prepare two mobile phones with Meshtastic APP installed and two thinknode M5\M1\M2 devices.
Android App(Version 2.6.30)¶
First go to the app store to download and install the Meshtastic APP
Meshtastic APP Usage:¶
Same settings on the receiving side as on the transmitting side¶
After opening the application, tap ‘Scan’ and select the corresponding Meshtastic device to connect.
When the Meshtastic_xxxx device is searched, tap to enter pairing mode.
Enter this code(123456) on your cell phone(The default code for the ThinkNode M6 is 123456.).
Set LoRa frequency: Tap the settings icon, select ‘Radio Configuration’, then tap the ‘LoRa’ option. Scroll down to the “Add” column and enter the required value in the ‘Coverage Frequency (MHz)’ field corresponding to the desired frequency.
If two devices want to communicate, they need to join to the same channel, this time you need to select the fourth of the five options above, the other end of the phone needs to join to the same channel by scanning the code or entering the link, the channel can be customized name and so on.¶
After joining, the two devices can now chat in the first screen by selecting Group Chat.
iOS App:¶
1)Open the app, tap Bluetooth on the home page and see the device you want to connect. Click on Pairing.
2)When the Meshtastic_xxxx device is searched, tap to enter pairing mode.
3)After successful Bluetooth pairing, You need to go to Settings and click on Lora Settings.
4) Set lora Region. and then scroll down to set the frequency. consistent with the previous settings for the region. Finally, check ignore MQTT and save.
5)Go to the information page, select a channel and a QR code will appear, use another device to scan this QR code to enter.
6)Join and start sending or receiving messages.
Video effect demonstration:(coming song)¶
How to buy¶
Please visit this page to purchase ThinkNode M3 Meshtastic Tracker.
Support¶
_Power_By_nRF52840/ios-1.webp)
_Power_By_nRF52840/ios-2.webp)
_Power_By_nRF52840/ios-3.webp)
_Power_By_nRF52840/ios-4.webp)
_Power_By_nRF52840/ios-7.webp)
_Power_By_nRF52840/ios-6.webp)
_Power_By_nRF52840/ios-8.webp)
_Power_By_nRF52840/ios-9.webp)
_Power_By_nRF52840/ios-10.webp)
_Power_By_nRF52840/ios-11.webp)
_Power_By_nRF52840/ios-12.webp)
