Crowtail- Electromagnet
An electromagnet is a type of magnet in which the magnetic field is produced by electric current. An electric current flowing in a wire creates a magnetic field around the wire, due to Ampere's law(see drawing below). To concentrate the magnetic field, in an electromagnet the wire is wound into a coil with many turns of wire lying side by side. The magnetic field of all the turns of wire passes through the center of the coil, creating a strong magnetic field there. Crowtail- Electromagnet can shuck 1KG weight and hold on. it easy to use, to learn electromagnet principle..
Model: CT008617E
- Easy to use
- Crowtail base module
- 1KG peak suction
- Low standby current
Specifications¶
- Working Voltage :DC 5V
- Working Current : 400mA
- Standby current : 200uA
- Load Weight: 1KG
- Dimensions(mm):40.0(L)x20.0(W)x20.8(H)
With Arduino¶
1.Hardware Connection The Crowtail- Electromagnetr is connecting to analog port D2 of Crowtail - Base Shield. A Button is connecting to D5. ![]()
2.Copy the demo code to your sketch, then upload to Arduino or Crowduino board.
int Electromagnet = 2;
int button = 5;
int buttonstate;
pinMode(Electromagnet, OUTPUT);
pinMode(button, INPUT);
buttonstate=digitalRead(button);
if(buttonstate==HIGH)
digitalWrite(Electromagnet, HIGH);
delay(200);
else
digitalWrite(Electromagnet, LOW);
delay(200);
3. Press the Button, you will find that the magnet is magnetic, and it can adsorption something (1 kg), loosen the Button, magnetic disappeared..
