2.8inch TFT Screen 320*240 Touch Display for Arduino, Mega|ILI9341 Driver|Plug & Play
This is a 2.8-inch Arduino TFT color screen with 320 * 240 resolution.
Plug and play, strong compatibility. Supports plug and play use of development boards such as Arduino UNO and Mega2560, without additional wiring.
High-definition display, touch experience. Equipped with a 320x240 resolution display, supporting touch function and a touch pen, users can interact with the device through intuitive touch operation.
Supports 16-bit RGB 65K color display, which can present rich colors and meet various visual needs.
Efficient data transmission. Using an 8-bit parallel bus, the data refresh speed is faster than the traditional serial port SPI.
Onboard 5V/3.3V level conversion IC, compatible with 5V and 3.3V operating voltages, ensuring seamless docking with various development boards.
Onboard SD card slot, convenient for users to expand storage, and provides more flexibility and convenience for experiments and project development.
Rich development support. Provide Arduino libraries and rich sample programs to help users get started quickly and easily find development resources suitable for them.
No matter you are a beginner or an experienced developer, this Arduino display will be a great helper in your project, helping you realize more creativity and functions.
Customized requests can be discussed(based on MOQ), you can contact us at service@elecrow.com
Model DLA35028B
2.8_inch_arduino_touch_display -123
Screen Size 2.8(inch)
Display Color RGB 65K color
Screen Type TFT
Resolution 320x240(pixels)
Touch Screen Type Resistive touch screen
Driver IC ILI9341
Module Interface 8-bit parallel interface
Operating Voltage 5V/3.3V
IO Voltage 3.3V
Operating Temperature -20℃~60℃
Storage Temperature -30℃~70℃
Active Area 43.2*57.6(mm)
Module PCB Size 52.70*78.22(mm)
Interface Definition
pin_of_2.8inch_Arduino_display(1)
Number Pin Label Pin Description
1 LCD_RST LCD bus reset signal, low level reset
2 LCD_CS LCD bus chip select signal, low level enable
3 LCD_RS LCD bus command / data selection signal,low level: command, high level: data
4 LCD_WR LCD bus write signal
5 LCD_RD LCD bus read signal
6 GND Power ground
7 5V 5V power input
8 3V3 3.3V power input, this pin can be disconnected
9 LCD_D0 LCD 8-bit data Bit0
10 LCD_D1 LCD 8-bit data Bit1
11 LCD_D2 LCD 8-bit data Bit2
12 LCD_D3 LCD 8-bit data Bit3
13 LCD_D4 LCD 8-bit data Bit4
14 LCD_D5 LCD 8-bit data Bit5
15 LCD_D6 LCD 8-bit data Bit6
16 LCD_D7 LCD 8-bit data Bit7
17 SD_SS SD card SPI bus chip select signal, low level enable
18 SD_DI SD card SPI bus MOSI signal
19 SD_DO SD card SPI bus MISO signal
20 SD_SCK SD card SPI bus clock signal
Resources
How to buy
Please visit this page to purchase 2.8inch TFT Screen 320*240 Touch Display for Arduino.
Support
