3.5 Inch 480x320 TFT Display with Touch Screen for Raspberry Pi
It is the cutest, little display for the Raspberry Pi. It features a 3.5" display with 480x320 16-bit color pixels and a resistive touch overlay. It's designed to fit nicely not only to the Pi Model A or B but also works perfectly fine with the Model B+.
Model:RPA03510R
- 480x320 resolution
 - Universal 3.5” Display for the Raspberry Pi
 - Compatible with Raspberry Pi A, B, A+, B+, and Pi2 versions
 - Powered not only from your computer, but also from your portable power
 - Adapt for Raspbian system
Specifications¶
- LCD Type:TFT
 - LCD Interface:SPI
 - Touch Screen Type:Resistive
 - Touch Screen Controller:XPT2046
 - Colors:65536
 - Backlight:LED
 - Resolution:480*320 (Pixel)
Interface Function¶
When users connect the Raspberry Pi to use, they need to configure the official system. Or you can also burn the configured system image directly.
 Tips:Basic for Raspbian Jessie with PIXEL (2017-04-10-raspbian-jessie.img)
Step 1:Download the Raspbian IMG https://www.raspberrypi.org/downloads/raspbian/¶
Step 2: Burn the system image If you don't know how to do that,you can refer to the Raspberry Pi office tutorial¶
Step 3: Open terminal and Download the driver on RPI¶
Run:
Step 4: Install driver¶
Run:
Touch screen calibration¶
- This LCD can be calibrated using a program called xinput_calibrator
 - **Install it with the commands: **
 - Click the Men button on the task bar, choose Preference -> Calibrate Touchscreen.
 - Finish the touch calibration following the prompts. Maybe rebooting is required to make calibration active.
 - You can create a 99-calibration.conf file to save the touch parameters (not necessary if file exists).
 - Save the touch parameters (may differ depending on LCD) to 99-calibration.conf, as shown in the picture:
Install Soft Keyboard¶
- Install the reference link:https://github.com/Elecrow-keen/Elecrow-LCD5/wiki/How-to-Install-Soft-Keyboard
