CrowPanel_1.46_inch-HMI_ESP32_Rotary_Display_360_360_IPS_Round_Touch_Knob_Screen
Model DHR55146D
1.46_round_rotary_display
Schematic Diagram:
CrowPanel1.46inchRotary-2
ESP32-S3 with display and touch schematic diagram
CrowPanel1.46inchRotary-3
LovyanGFX Display Configuration
'''cpp
  LGFX(void) {
      cfg.spi_host = SPI2_HOST;
      cfg.spi_mode = 0;
      cfg.freq_write = 80000000;
      cfg.freq_read = 20000000;
      cfg.spi_3wire = true;
      cfg.use_lock = true;
      cfg.dma_channel = SPI_DMA_CH_AUTO;
      cfg.pin_sclk = 10;
      cfg.pin_mosi = 11;
      cfg.pin_miso = -1;
      cfg.pin_dc = 3;
      _bus_instance.config(cfg);
      cfg.pin_cs = 9;
      cfg.pin_rst = 14;
      cfg.pin_busy = -1;
      cfg.memory_width = 360;
      cfg.memory_height = 360;
      cfg.panel_width = 360;
      cfg.panel_height = 360;
      cfg.offset_x = 0;
      cfg.offset_y = 0;
      cfg.offset_rotation = 0;
      cfg.dummy_read_pixel = 8;
      cfg.dummy_read_bits = 1;
      cfg.readable = false;
      cfg.invert = false;
      cfg.rgb_order = true;
      cfg.dlen_16bit = false;
      cfg.bus_shared = false;
      _panel_instance.config(cfg);
    setPanel(&_panel_instance);
  static TwoWire* wi=&Wire;
  //TP_INT 5;TP_RST  13
  cst816t touch = cst816t(Wire,13,5);
  //TP I2C
  wi->setPins(6,7);
Screen backlight pins:
#define SCREEN_BACKLIGHT_PIN 46
LED and RGB light pins:
/* LED Light define */
#define POWER_LIGHT_PIN 40
#define LED_PIN 48
Encoder pins:
/* ENCODER set*/
#define ENCODER_A_PIN 45
#define ENCODER_B_PIN 42
#define SWITCH_PIN 41
i2c:
/* I2C Define */
//I2C SDA Pin
#define I2C_SDA_PIN     38
//I2C SCL Pin
#define I2C_SCL_PIN     39
FPC:
CrowPanel1.46inchRotary-4
Pin Definition
Function GPIO
LCD SCLK GPIO10
LCD MOSI GPIO11
LCD CS GPIO9
LCD DC GPIO3
LCD RST GPIO14
Touch SDA GPIO6
Touch SCL GPIO7
Touch INT GPIO5
Touch RST GPIO13
Backlight GPIO46
Encoder A GPIO45
Encoder B GPIO42
Encoder Switch GPIO41
Power LED GPIO40
RGB LED GPIO48
I2C_SDA GPIO38
I2C_SCL GPIO39
Use the configuration guide:
Get Started with Arduino IDE
Recommended ESP32 Board Package Version: 2.0.14
Later versions may require code modifications.
CrowPanel1.46inchRotary-1
Platforms Supported
Arduino IDE ESPHome
Arduino ESPHome-Logo
[GetStarted [GetStarted
GitHub Repository
The demo source code and examples are available on GitHub:
CrowPanel-1.46inch-HMI-ESP32-Rotary-Display
Where to Buy
Please visit this page to purchase CrowPanel 1.46 inch-HMI ESP32 Rotary Display.
Support
