Crowbits-DHT20
DHT20 is an intelligent temperature and humidity sensor module that can convert temperature and humidity into electrical signals to easily measure temperature and humidity. The module is equipped with a newly designed ASIC dedicated chip, an improved MEMS semiconductor capacitive humidity sensor element and a standard temperature sensor element. After comprehensive improvement, DHT20 reduces power consumption and cost, while greatly improving measurement accuracy, power supply voltage, measurement range, response time, stability, etc.; it has the characteristics of no calibration, low power consumption, high accuracy, and high stability. Using fully calibrated digital I2C communication interface, it has fast response, strong anti-interference ability and high cost performance.
Technical specifications
Working voltage: DC2.2V+5.5V
Measuring range
  • Humidity: 0%-100% RH
  • Temperature: -40~80°C
Error range
  • Humidity: ±3% RH
  • Temperature: ±0.5°C
Resolution
  • Humidity: ±0.024% RH
  • Temperature: 0.01°C
Response time
  • Humidity: τ63% condition is less than 8 seconds
  • Temperature: τ63% condition mini5 seconds, max30 seconds
Interface type: I2C
Size: 31.5 (L)*24.5(W)*13(H)mm
Application scenarios
Test environment temperature and humidity information
Usage
The following sketch demonstrates a simple application
2. Connect the module to the A4 and A5 interface on the Crowbits-UNO board, as shown in the figure below:
3. Download the Crowbit-DHT20 software file and unzip it and place it in the libraries folder of the Arduino IDE. Run Arduino.exe, Open path: Crowtail-DHT20 --> examples --> DHT20 --> DHT20.ino
#include <DHT20.h>
 * @brief Construct the function
 * @param pWire IC bus pointer object and construction device, can both pass or not pass parameters, Wire in default.
 * @param address Chip IIC address, 0x38 in default.
DHT20  dht20;
  Serial.begin(115200);
  //Initialize sensor
  while(dht20.begin())
    Serial.println("Initialize sensor failed");
    delay(1000);
  //Get ambient temperature
  Serial.print("temperature:"); Serial.print(dht20.getTemperature());Serial.print("℃");
  //Get relative humidity
  Serial.print("  humidity:"); Serial.print(dht20.getHumidity()*100);Serial.println(" %RH");
    delay(1000);
4. Upload it to your Crowbits-UNO board, open the COM serial port, select 115200 for the baud rate at the bottom right, and the monitor displays the current environmental temperature and relative humidity information.
