Crowbits-Photo Electric Counter
The Photo Electric Counter is a digital input module, it converts the optical signal into the electric signal. Due to the U-shaped design of the photoelectric sensor, it can be used as a mini door with a counting function for your circuit.
- Digital input module
- Easy to use
- High sensitivity
- Operating Voltage: 3.3V DC
1. You also need to prepare a power module, such as Crowbits-Power Supply, and an output module, such as Crowbits-LED.
3. Then, turn on the power. When an object is detected in the U-shaped slot, the LED behind it will light up.
