Mini PC Case With 1.3” OLED Screen For Raspberry Pi 5/Jetson Orin Nano
Model SEJ00007D
ai_jetson_orin_nano_starter_kit_1
Pin Description:
Module Signal Name Net Equipment
1 D2/I2C1_SDA
D3/I2C1_SCL
IIC BUS:
3.3V BUS
Barometer(ADD:0x77)
Accelerometer&Gyro(ADD:0x68)
Temperature & Humidity(ADD:0x38)
LIGHT Sensor(ADD:0x5C)
5V BUS
LCD (ADD:0x27)
Digital display (ADD:0x70)
I/O Expander (TCA9534APWR IO Expansion chip)(ADD:0x3C)
STCG1K08A(Microcontroller) RP2040(Microcontroller)
J21 and J22 (Reserved for user IIC interface)
2 D4 Tilt sensor
3 D14/UART1_TXD J23 (Reserve for user access via UART interface)
4 D15/UART1_RXD J23 (Reserve for user access via UART interface)
5 D17/UART1_RTS Touch Sensor
6 D27/SPI1_SCK Vibration sensor
7 D23/SPI1_CS1 PIR-Motion sensor
8 D25/SPI1_MISO Photo Electric Counter
9 D10/SPI0_MOSI SPI BUS: NFC Module(RC522 )
10 D9/SPI0_MISO SPI BUS: NFC Module(RC522 )
11 D11/SPI0_SCK SPI BUS: NFC Module(RC522 )
12 D8/SPI0_CS0 RC522 (NFC Chip Chip Select)
13 D6 HALL SENSOR
14 D16/UART1_CTS Ultrasonic Sensor TRIG
15 D26/SPI1_MOSI Ultrasonic Sensor CTS
16 D20/I2S0_SDIN IR Remote Sensor
17 D18/I2S0_SCLK LED(Red LED indicator)
18 D13/PWM J5(Reserve I/O ports for user use)
19 D12/PWM J6(Reserve I/O ports for user use)
Expansion Interface Chip chip pin NET Equipment
STCG1K28A(Microcontroller) Pin1:P1.0 ADC_CH0 Joystick X-axis
Pin2:P1.1 ADC_CH1 Joystick Y-axis
Pin3:P1.2 ADC_CH2 Linear Potentiometer
Pin4:P1.3 ADC_CH3 GAS-MQ2
Pin5:P1.4 ADC_CH4 Custom_key
Pin6:P1.5 ADC_CH5 NTC (Thermistor)
Pin30:P0.1 RELAY Relay
Pin31:P0.2 BUZZER Buzzer Control
Pin13:RXD STC8_RXD Program Download
Pin14:TXD STC8_TXD Program Download
Pin7:SCL D3/I2C1_SCL IIC BUS
Pin8:SDA D2/I2C1_SDA
TCA9534APWR IO Expansion chip Pin4:P0 STEP1 Stepper Motor Driver
Pin5:P1 STEP2
Pin6:P2 STEP3
Pin7:P3 STEP4
Pin12:P7 ENCODER_B Encode
Pin11:P6 ENCODER_A
Pin11:P5 ENCODER_SW
RP2040 Pin47 USB_D+ USB download port
Pin46 USB_D-
Pin39:P27 RP2040_IO27_RGB_POWER_EN 8*8 RGB Power Control
Pin8:P6 RP2040_IO6_RGB 8*8 RGB Signal
Pin16:P13 RP2040_IO13_SERVO_1 Gimbal Servo Interface
Pin17:P14 RP2040_IO13_SERVO_2 Gimbal Servo Interface
Pin21:P32 D2/I2C1_SDA IIC BUS
Pin20:P31 D3/I2C1_SCL
Jetson Nano Module Interface Pin Description
Feature Module Signal Name Pin Pin Module Signal Name Feature
VCC3V3 1 2 VCC5V
D2/I2C1_SDA 3 4 VCC5V
D3/I2C1_SCL 5 6 GND
D4 7 8 D14/UART1_TXD
GND 9 10 D15/UART1_RXD
D17/UART1_RTS 11 12 D18/I2S0_SCLK
D27/SPI1_SCK 13 14 GND
D22/LCD_TE* 15 16 D23/SPI1_CS1
VCC3V3 17 18 D24/SPI1_CS0
D10/SPI0_MOSI 19 20 GND
D9/SPI0_MISO 21 22 D25/SPI1_MISO
D11/SPI0_SCK 23 24 D8/SPI0_CS0
GND 25 26 D7/SPI0_CS1
D0/ID_I2C_SDA 27 28 D1/ID_I2C_SCL
D5/CAM_AF_EN* 29 30 GND
D6 31 32 D12/PWM
D13/PWM 33 34 GND
D19/I2S0_LRCK 35 36 D16/UART1_CTS
D26/SPI1_MOSI 37 38 D20/I2S0_SDIN
GND 39 40 D21/I2S0_SDOUT
Hardware Overview
ai_jetson_orin_nano_starter_kit_2
Sensor Courses
ai_jetson_orin_nano_starter_kit_3
Camera Courses
ai_jetson_orin_nano_starter_kit_4
User guide:
Solid-State Flashing and Boot Methodology and SD Card Flashing Guide:
Github
AI-Starter-Kit-for-Jetson-Orin-Nano-with-Common-Board-design
Guide Video:
Unboxing & Setting Up the AI Starter Kit for Jetson Orin Nano | Beginner's Guide
Master Camera & AI Vision: Hands-On Starter Kit Course for Jetson Orin Nano
Openclaw Column
Jetson OpenClaw Install & Config Guide
How to buy
Please visit this page to purchase AI Starter Kit for Jetson Orin Nano.
Support
