Crowbits-Logic NOT
The logic NOT is a logic gate that uses one input signal to control one output signal, it creates rules for your circuit. The interface of the logic NOT is a digital interface, it will output a logic-high or low (1 or 0) signal.The logic NOT has one input and one output, the output does a reverse operation on the input, which means if you send a logic-high signal to the input, the logic NOT will output a logic-low signal.
  • Single input port.
  • Single output port.
  • Output indicator.
  • Operating Voltage: 3.3V DC
Usage
1)You also need a power module, such as Crowbits-Power Supply; An input module, such as Crowbits-Touch Sensor and Crowbits-Logic NOT; An extension module, such as Crowbits-LED.
2)The connection mode is shown in the figure, but the signal feet of the input module and the output module must be connected.
3)Then, turn on the power. the LED light.
4)When you press the Touch Sensor, the LED lights off.
