CrowPanel ESP32 1.28-inch Round Display
CrowPanel ESP32 Display1.28 inch round screen uses ESP32-C3 as the main control, equipped with a 32-bit dual-core chip, and the highest clock frequency reaches 160 MHz. Supports 2.4G WiFi and BLE low-power Bluetooth, suitable for IoT, smart home and other fields.
This 1.28-inch round screen has a resolution of 240*240, IPS screen and 178° viewing angle, which can enjoy more vivid and realistic images at any angle. It supports capacitive touch and is responsive; it has custom buttons, REST, and BOOST buttons, and the UART serial port can upgrade the firmware. It supports Arduino IDE, Espressif IDF, Lua RTOS, Home Assistant/PlatformIO/Micro python, and supports the LVGL library. It can design the UI interface by yourself, which is an ideal platform for DIY projects.
Model: DIS12824D
CrowPanel-1.28
Get_one_now
  • Home Assistant/PlatformIO/Micro python also supports LVGL library;
  • ESP32-C3 master control, equipped with 32-bit dual-core chip, the highest clock frequency reaches 160 MHz.
  • IPS screen, 178° visual range, more vivid images.
  • Capacitive touch, fast response.
  • With custom buttons and REST, and BOOT buttons, the UART serial port supports power supply and firmware upgrades.
  • Supports multiple development environments, Arduino IDE, Espressif IDF, Lua RTOS, Home Assistant/PlatformIO/Micro python, and supports LVGL library.
Main Chip ESP32-C3
Processor 32-bit RISC-V single-core processor, up to 160 MHz
Memory 384 KB ROM
400 KB SRAM (16 KB for cache)
8 KB SRAM in RTC
Size 1.28-inch
Resolution 240*240
Signal Interface SPI
Touch Type Capacitive Touch
Panel Type TFT LCD, IPS Panel
Color Depth 262K
Brightness 350 cd/m²
Viewing Angel 178°
Button Rest Butto, Boot Button, Custom Button
Interface Type-C Interface, Battery Interface
Operation Power Module:DC5V
Main Chip:3.3V
Active Area 32.51*32.51mm
Operating temperature -10~60°C
Dimensions 42x42x9.8mm
Net Weight 15g
Pin Out
interface
Interface GPIO Related component
Custom button IO1
Encoder (with button) A_IO19; B_IO18; ENC_IO8 E5A5-23-12-8
CR927 battery holder (RTC) SDA_IO4; SCL_IO5 BM8563EMA
Vibrarion motor MOTOR_P0 (P0 pin from IO expansion chip) PI4IOE5V6408ZTAEX
Buzzer IO3
Battery Socket SH1.0-2Pin socket
Platforms Supported
Arduino IDE MicroPython
Arduino MicroPython-Log
GetStarted GetStarted
Home Assistant Chronos App
HomeAssistant-Logo Chronos-App
FAQS
Resources
Schematic & PCB
Specifications
Certification
Demo Code
MicroPython
