Crowtail-Knock Sensor
The Crowtail-knock sensor is a piezoelectric sensor that contains a piezoelectric sensing crystal and a resister. This crystal creates a small amount of voltage when shaken and takes advantage of this unique property. It will output a pulse when vibration is detected.
Model: CRT00516K
- Digital Crowtail connector
Specifications¶
Item | Value |
Presence sensing | vibration |
Sensor | KY-031 |
Power supply | 5V |
Dimensions(mm) | 20.0(L)x20.0(W)x7.1(H) |
Pin Map¶
Pin Name | Description |
VCC | Supply Voltage |
GND | GND |
SIG | Output a pulse when vibration is detected |
Platforms Supported¶
Arduino |
Hardware¶
Crowduino Uno | Base Shield | Crowtail-Knock Sensor | Crowtail-LED |
Get one now | Get one now | Get one now | Get one now |
STEP3 Plug Crowtail-Knock Sensor into D2 slot on the Crowtail-Base Shield I Port with Crowtail cable;
STEP4 Plug Crowtail-LED into D3 slot on the Crowtail-Base Shield I Port with Crowtail cable;
STEP5 Connect Crowduino Uno to PC via a Mini USB cable.
NOTE |
If we don't have Crowtail Base Shield, We also can directly connect this module to Crowduino Uno as below. |
Crowduino Uno | Crowtail-Knock Sensor | Crowtail-LED |
DIGITAL 2 | SIG | \ |
DIGITAL 3 | \ | SIG |
5V | VCC | VCC |
GND | GND | GND |
Software¶
STEP 1.Download program filesKnock_Sensor.zip
STEP 3 Load the program in the Arduino IDE
const int SensorPin = 2; // the number of the pushbutton pin
const int ledPin = 12; // the number of the LED pin
// variables will change:
int SensorState = 0; // variable for reading the pushbutton status
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(SensorPin, INPUT);
void loop(){
// read the state of the pushbutton value:
SensorState = digitalRead(SensorPin);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (SensorState == HIGH) {
// turn LED on:
digitalWrite(ledPin, HIGH);
STEP4 Click the to upload the code to the Crowduino board
STEP5 After the program is downloaded, knock the sensor you will see the LED lights up.
FAQS¶
