Crowtail- I2C EEPROM
If you need to do some data storage in Arduino but found that the EEPROM in ATmega chip too limited, then this Crowtail- I2C EEPROM is your best choice. This module is based on the EEPROM chip AT24C256, which has 256k bit capacity. It communicate with Arduino with I2C bus, helps you do much more data storage easily.
Model: CT010021E
- Onboard chip AT24C256 chip
- Onboard the I2C communications required pull-up resistor
- All pins are leads and marked
- Dimensions(mm):20.0(L)x20.0(W)x9.8(H)
1.Hardware connection
You can connect to I port for the Crowtail- Base Shield.
2.Upload the following sample sketch to store data and read data.
#include <Wire.h>
#define EEPROM_ADDR 0x50 // I2C Buss address of 24LC256 256K EEPROM
Wire.begin(); // join I2C bus (address optional for master)
// TESTS FOR EACH FUNCTION BEGIN HERE
Serial.println("Writing Test:");
for (int i=0; i<20; i++){ // loop for first 20 slots
i2c_eeprom_write_byte(EEPROM_ADDR,i,i+65); // write address + 65 A or 97 a
Serial.print(". ");
delay(10); // NEED THIS DELAY!
Serial.println("");
delay(500);
Serial.println("Reading Test:");
Serial.write(i2c_eeprom_read_byte(EEPROM_ADDR, i));
Serial.print(" ");
// setup for page tests . . .
byte PageData[30]; // array that will hold test data for a page
byte PageRead[30]; // array that will hold result of data for a page
for (int i=0; i<30; i++){ // zero both arrays for next test
PageData[i] = 0;
PageRead[i] = 0;
Serial.println("");
for (int i=0; i<30; i++) PageData[i] = i+33; // fill up array for next test char 33 = !
Serial.println("Writing Page Test:");
i2c_eeprom_write_page(EEPROM_ADDR, 100, PageData, 28 ); // 28 bytes/page is max
Serial.println("Reading Page Test:");
i2c_eeprom_read_buffer( EEPROM_ADDR, 100, PageRead, 28);
for (int i=0; i<28; i++){
Serial.write(PageRead[i]); // display the array read
Serial.print(" ");
void i2c_eeprom_write_byte( int deviceaddress, unsigned int eeaddress, byte data )
int rdata = data;
Wire.beginTransmission(deviceaddress);
Wire.write((int)(eeaddress >> 8)); // Address High Byte
Wire.write((int)(eeaddress & 0xFF)); // Address Low Byte
Wire.write(rdata);
Wire.endTransmission();
// Address is a page address, 6-bit (63). More and end will wrap around
// But data can be maximum of 28 bytes, because the Wire library has a buffer of 32 bytes
void i2c_eeprom_write_page
( int deviceaddress, unsigned int eeaddresspage, byte* data, byte length )
Wire.write((int)(eeaddresspage >> 8)); // Address High Byte
Wire.write((int)(eeaddresspage & 0xFF)); // Address Low Byte
byte c;
for ( c = 0; c < length; c++)
Wire.write(data[c]);
delay(10); // need some delay
byte i2c_eeprom_read_byte( int deviceaddress, unsigned int eeaddress )
byte rdata = 0xFF;
Wire.requestFrom(deviceaddress,1);
if (Wire.available()) rdata = Wire.read();
return rdata;
// should not read more than 28 bytes at a time!
void i2c_eeprom_read_buffer( int deviceaddress, unsigned int eeaddress, byte *buffer, int length )
Wire.requestFrom(deviceaddress,length);
//int c = 0;
for ( int c = 0; c < length; c++ )
if (Wire.available()) buffer[c] = Wire.read();
3. When you upload the code complete,you can see the result via the serial port debug window which means the EEPROM could to be used Save and read data.
