1.44'' 128x 128 TFT LCD with SPI Interface
Introduction
This Color TFT LCD display has 128 x 128 resolution and 262 color, it uses SPI interface to communicate with controller such Arduino, it is the best upgrading of the Nokia5110.
Model: DL144128TF
Alt text
  • Size: 1.44 inch
  • Interface:SPI
  • Resolution: 128*128
  • Visual area: 1:1 square
  • TFT color screen, the effect is far better than other small CSTN screen
  • Drive IC: ILI9163
  • Fully compatible and alternative 5110 interface
  • Onboard LDO, support 5V/3.3V input voltage, the LED backlight, 3.3V input
Usage
1.Hardware connection
128x 128 TFT LCD with SPI Interface hardware.jpg 128x 128 TFT LCD with SPI Interface hardware1.jpg
3.Download the library TFT_ILI9163C library;Unzip it into the libraries file of Arduino IDE by the path: ..\arduino-1.0.1\libraries.
4.Open the code directly by the path:File -> Example ->TFT_ILI9163C->test.
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <TFT_ILI9163C.h>
// All wiring required, only 3 defines for hardware SPI on 328P
#define __DC 9
#define __CS 10
// MOSI --> (SDA) --> D11
#define __RST 12
// SCLK --> (SCK) --> D13
// Color definitions
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
TFT_ILI9163C tft = TFT_ILI9163C(__CS, __DC, __RST);
  tft.begin();
void loop(){
  testLines(random(0x00ff,0xffff));
  delay(100);
  testText();
  delay(500);
unsigned long testText() {
  tft.fillScreen();
  unsigned long start = micros();
  tft.setCursor(0, 0);
  tft.setTextColor(WHITE);
  tft.setTextSize(1);
  tft.println("Hello World!");
  tft.setTextColor(YELLOW);
  tft.setTextSize(2);
  tft.println(1234.56);
  tft.setTextColor(RED);
  tft.setTextSize(3);
  tft.println(0xDEAD, HEX);
  tft.println();
  tft.setTextColor(GREEN);
  tft.setTextSize(4);
  tft.println("Hello");
  return micros() - start;
unsigned long testLines(uint16_t color) {
  tft.fillScreen();
  unsigned long start, t;
  int           x1, y1, x2, y2,
  w = tft.width(),
  h = tft.height();
  tft.fillScreen();
  x1 = y1 = 0;
  y2    = h - 1;
  start = micros();
  for(x2=0; x2<w; x2+=6) tft.drawLine(x1, y1, x2, y2, color);
  x2    = w - 1;
  for(y2=0; y2<h; y2+=6) tft.drawLine(x1, y1, x2, y2, color);
  t     = micros() - start; // fillScreen doesn't count against timing
  tft.fillScreen();
  x1    = w - 1;
  y1    = 0;
  y2    = h - 1;
  start = micros();
  x2    = 0;
  t    += micros() - start;
  tft.fillScreen();
  x1    = 0;
  y1    = h - 1;
  y2    = 0;
  start = micros();
  x2    = w - 1;
  tft.fillScreen();
  x1    = w - 1;
  y1    = h - 1;
  y2    = 0;
  start = micros();
  x2    = 0;
5.Upload the Code,you shoule see the display of LCD.
Resource
