Crowtail- Screw Terminal
Crowtail-Screw Terminal has four 3.5mm pitch pins rate up to 125V @ 10A, it can accept 16 to 26AWG wire and be used to connect to external devices.This Crowtail has four ports including GND, VCC and two other ports. It usually be used to interface Crowtail wires(signals) with other external non-Crowtail modules.
Model: CRT00532T
- 3.5mm standard pitch pin
- 3.3V/5V Compatible
- High current/voltage adaptable
Dimensions(mm):20.0(L)x20.0(W)x12.5(H)
Item | Description |
Working Voltage | 5 V/3.3V |
Supply Mode | Crowtail Interface |
