Crowbits-Gas Sensor
This module is a converter that converts a gas integral number into a corresponding electrical signal. It mainly uses the chemical potential difference between two electrodes. One electrode measures the gas concentration in the gas, and the other electrode is a fixed reference electrode When the concentration of a certain measured gas exceeds the standard, the concentration value will be higher than the electrical signal of the reference electrode, and the module will output the corresponding concentration value effect.
  • Easy to use
  • Interface Type: Analog input
  • Operating Voltage: 3.3V DC
  • Dimensions: 31.5(L)*24.5(W)*13(H)mm
Usage
2. Connect the module to the I2C interface on the Crowbits-UNO board, as shown in the figure:
3.Upload the following code to the Crowbits-UNO board.
  float sensor_volt;
  float sensorValue;
  sensorValue = analogRead(A2);
  sensor_volt = sensorValue / 1024 * 5.0;
  Serial.print("sensor_volt = ");
  Serial.print(sensor_volt);
  Serial.println("V");
  delay(1000);
4.After the upload is successful, open the serial port monitor, the baud rate is set to 9600.When gas is detected, the voltage value output by the serial port will change.
