Crowtail- Hall Sensor
The Crowtail- Hall Sensor uses the Allegro™ A1101 Hall-effect switches are next generation replacements for the popular Allegro312x and 314x lines of unipolar switches.It measures the Hall Effect, which is a production of a voltage difference across an electrical conductor, transverse to an electric current in the conductor as well as a magnetic field perpendicular to the current. The output of the continuous-time switch Hall sensor switches low(turns on) when a magnetic field (south polarity) perpendicular to the Hall sensor exceeds the BOP threshold, and it switches high( turn off) when the magnetic field disappears.
Model: CT0024HS
- Crowtail Compatible Interface
- 400ns transition period for rise and fall.
- Continuous-time hall effect sensor
- Reverse battery protection
Dimensions(mm):20.0(L)x20.0(W)x6.8(H)
Item | Min | Typical | Max | Unit |
Voltage | 3.8 | 5.0 | 24 | V |
Current | 4.1 | - | 24 | mA |
Operating Temperature | -40 | - | 85 | ºC |
1.Hardware Connection
Connect the Hall Sensor to Digital port 4 of the Crowtail - Basic Shield using a 3 pin cable and connect Crowtail-LED to Digital Port 5.Then connect Arduino to PC by using a USB cable.
2.Upload the following sample sketch:
const int hall= 4;//PIN 4
const int led= 5;//PIN 5
pinMode(hall,INPUT);
pinMode(led,OUTPUT);
if(digitalRead(hall)==LOW){
digitalWrite(led,HIGH);
else{
digitalWrite(led,LOW);
delay(500);
3.When the magnet near the hall sensor, the LED will light up.
