HC-SR505 Mini PIR Motion Sensor
Introduction¶
HC-SR505 Mini PIR Motion Sensor is based on infrared technology and it can automatic control by itself with high sensitivity and high reliability. Because of the minimum size and low-power operation mode, it widely used in various of automatic electronic equipment, especially battery-powered automatic products.
Module:SPS50506S
- Automatic Control
- Minimum size
- Repeatable Trigger
- Wide range of operating voltage
- Low-power
- Output high signal
- Operating voltage range: DC4.5-20V
- Quiescent Current: <60uA
- Trigger: reusable trigger (default)
- Delay Time: The default 8S + -30%
- Board Dimensions: 10 * 23mm
- Induction angle: <100 degrees cone angle
- Sensing distance: 3 meters
- Working temperature: -20 to +80 degrees
- Sensor Lens Dimensions: Diameter: 10mm
Hardware¶
Connect the PIR Motion Sensor to your Arduino/Crowduino power supply pin and digital pins. You can can connect the "s" terminal to any of your arduino Pins,like the "D6" as belows:
Programming¶
1.Copy the following program to Arduino IDE and upload to your Arduino/Crowduino:
pinMode(6,INPUT);
digitalWrite(6,LOW);
if(digitalRead(6)==HIGH) {
Serial.println("Somebody is here.");
else {
Serial.println("Nobody.");
delay(1000);
2.Open the Serial moniter , and set the baudrate to 9600, you will see that When somebody is in front of the sensor , the Serial Monitor will output "Somebody is here.".Or, the Serial Monitor output "Nobody."
