Crowbits-Recorder
The recording module can record your voice, and is easy to store and read.
- Low power consumption
- User-friendly operation
- Operating Voltage: 3.3V DC
1. You also need a power module, such as Crowbits-Power Supply; A 2 Pin interface speaker.
2. Connect the speaker to the seat, the connection mode is shown in the figure.
3. Turn on the power.
When you record, you need to press the “Record” button, the LED on the board will light up until you finish recording.
You could press the “Play2” button to play your recording.
You could press the “Play1” button to pause your recording
