Crowbits-TPL5111 Timer
TPL5111 Timer is a stand-alone breakout that will turn any electronics into low-power electronics. It can be used to activate or deactivate your electronic device via internal time (The timing time can be up to 1 hour).
- 6 kinds of timing time
 - Timer accuracy: 1% (typical)
 - Timing mode: manual
 - Digital input module
- Operating Voltage: 3.3V DC
1. You also need to prepare a power module, such as Crowbits-Power Supply, and an output module, such as Crowbits-LED.
3. Turn on the power. Toggle a time on the DIP switch (for example, I set it to 10s), press the "Start" button, the LED light behind it will turn on after 10s.
