16x16 LED Display Module
This 16x16 Display module uses the 74HC138 and 74HC595 to decode and drive 4 8x8 LED modules to create an even bigger 16x16 LED display module. Detailed Demos based on Arduino help you understanding and learning how to use this module and thus to integrate it to your own applications。
Model:DLD1616LED
- 16x16 LED Display
- Color: Red
- Support the 128x64 LCD Display
- Cascadable
1.Hardware connection
3.Copy the below code to you new skecth,then upload it.
#include <Arduino.h>
//IO
#define LEDARRAY_D 2
#define LEDARRAY_C 3
#define LEDARRAY_B 4
#define LEDARRAY_A 5
#define LEDARRAY_G 6
#define LEDARRAY_DI 7
#define LEDARRAY_CLK 8
#define LEDARRAY_LAT 9
unsigned char Display_Buffer[2];
const unsigned char Word1[1][32] =
0xFF,0xFF,0xFF,0xE1,0xC0,0x80,0x80,0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF,0xFF,
0xFF,0xFF,0xFF,0x87,0x03,0x01,0x01,0x01,0x03,0x07,0x0F,0x1F,0x3F,0x7F,0xFF,0xFF,//heart-shaped
const unsigned char Init_Display[1][32] =
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
pinMode(LEDARRAY_D, OUTPUT);
pinMode(LEDARRAY_C, OUTPUT);
pinMode(LEDARRAY_B, OUTPUT);
pinMode(LEDARRAY_A, OUTPUT);
pinMode(LEDARRAY_G, OUTPUT);
pinMode(LEDARRAY_DI, OUTPUT);
pinMode(LEDARRAY_CLK, OUTPUT);
pinMode(LEDARRAY_LAT, OUTPUT);
Display(Init_Display);
Display(Word1);
//num is number dat[][32] is the name of the font
void Display(const unsigned char dat[][32])
unsigned char i;
for( i = 0 ; i < 16 ; i++ )
digitalWrite(LEDARRAY_G, HIGH);
Display_Buffer[0] = dat[0][i];
Display_Buffer[1] = dat[0][i+16];
Send(Display_Buffer[1]);
Send(Display_Buffer[0]);
digitalWrite(LEDARRAY_LAT, HIGH);
digitalWrite(LEDARRAY_LAT, LOW);
delayMicroseconds(1);
Scan_Line(i);
digitalWrite(LEDARRAY_G, LOW);
delayMicroseconds(100);;
void Scan_Line( unsigned char m)
switch(m)
case 0:
digitalWrite(LEDARRAY_D, LOW);digitalWrite(LEDARRAY_C, LOW);digitalWrite(LEDARRAY_B, LOW);digitalWrite(LEDARRAY_A, LOW);
break;
case 1:
digitalWrite(LEDARRAY_D, LOW);digitalWrite(LEDARRAY_C, LOW);digitalWrite(LEDARRAY_B, LOW);digitalWrite(LEDARRAY_A, HIGH);
break;
case 2:
digitalWrite(LEDARRAY_D, LOW);digitalWrite(LEDARRAY_C, LOW);digitalWrite(LEDARRAY_B, HIGH);digitalWrite(LEDARRAY_A, LOW);
break;
case 3:
digitalWrite(LEDARRAY_D, LOW);digitalWrite(LEDARRAY_C, LOW);digitalWrite(LEDARRAY_B, HIGH);digitalWrite(LEDARRAY_A, HIGH);
break;
case 4:
digitalWrite(LEDARRAY_D, LOW);digitalWrite(LEDARRAY_C, HIGH);digitalWrite(LEDARRAY_B, LOW);digitalWrite(LEDARRAY_A, LOW);
break;
case 5:
digitalWrite(LEDARRAY_D, LOW);digitalWrite(LEDARRAY_C, HIGH);digitalWrite(LEDARRAY_B, LOW);digitalWrite(LEDARRAY_A, HIGH);
break;
case 6:
digitalWrite(LEDARRAY_D, LOW);digitalWrite(LEDARRAY_C, HIGH);digitalWrite(LEDARRAY_B, HIGH);digitalWrite(LEDARRAY_A, LOW);
break;
case 7:
digitalWrite(LEDARRAY_D, LOW);digitalWrite(LEDARRAY_C, HIGH);digitalWrite(LEDARRAY_B, HIGH);digitalWrite(LEDARRAY_A, HIGH);
break;
case 8:
digitalWrite(LEDARRAY_D, HIGH);digitalWrite(LEDARRAY_C, LOW);digitalWrite(LEDARRAY_B, LOW);digitalWrite(LEDARRAY_A, LOW);
break;
case 9:
digitalWrite(LEDARRAY_D, HIGH);digitalWrite(LEDARRAY_C, LOW);digitalWrite(LEDARRAY_B, LOW);digitalWrite(LEDARRAY_A, HIGH);
break;
case 10:
digitalWrite(LEDARRAY_D, HIGH);digitalWrite(LEDARRAY_C, LOW);digitalWrite(LEDARRAY_B, HIGH);digitalWrite(LEDARRAY_A, LOW);
break;
case 11:
digitalWrite(LEDARRAY_D, HIGH);digitalWrite(LEDARRAY_C, LOW);digitalWrite(LEDARRAY_B, HIGH);digitalWrite(LEDARRAY_A, HIGH);
break;
case 12:
digitalWrite(LEDARRAY_D, HIGH);digitalWrite(LEDARRAY_C, HIGH);digitalWrite(LEDARRAY_B, LOW);digitalWrite(LEDARRAY_A, LOW);
break;
case 13:
digitalWrite(LEDARRAY_D, HIGH);digitalWrite(LEDARRAY_C, HIGH);digitalWrite(LEDARRAY_B, LOW);digitalWrite(LEDARRAY_A, HIGH);
break;
case 14:
digitalWrite(LEDARRAY_D, HIGH);digitalWrite(LEDARRAY_C, HIGH);digitalWrite(LEDARRAY_B, HIGH);digitalWrite(LEDARRAY_A, LOW);
break;
case 15:
digitalWrite(LEDARRAY_D, HIGH);digitalWrite(LEDARRAY_C, HIGH);digitalWrite(LEDARRAY_B, HIGH);digitalWrite(LEDARRAY_A, HIGH);
break;
default : break;
void Send( unsigned char dat)
unsigned char i;
digitalWrite(LEDARRAY_CLK, LOW);
delayMicroseconds(1);;
for( i = 0 ; i < 8 ; i++ )
if( dat&0x01 )
digitalWrite(LEDARRAY_DI, HIGH);
else
digitalWrite(LEDARRAY_DI, LOW);
digitalWrite(LEDARRAY_CLK, HIGH);
dat >>= 1;
4.Upload the Code,then you shoule see the 16x16 LED display.
