Elecrow nRFLRCC68 Wireless Transceiver Module-Integrates Nordic nRF52840 and Semtech LLCC68
The Elecrow nRFLRCC68 module integrates the Nordic nRF52840 microcontroller and the Semtech LLCC68 LoRa transceiver chip. It is a high-performance, low-power medium- and long-range transceiver module. It supports Bluetooth 5.3 and low-power Bluetooth, complies with the A, B, and C classes of the LoRaWAN 1.0.4 specification, and supports LoRa point-to-point (P2P) communication mode. It covers the 850~930MHz (applicable to 868MHz, 915MHz) global ISM band, with a maximum transmit power of +20dBm, a transmission rate range of 1.76~62.5Kbps, and a transmission distance of up to 10 km.
The nRFLR1121 module has built-in AT command firmware, supports SDK customized development, and a rich peripheral interface that provides high flexibility to meet diverse development needs. The nRFLR1121 module retains the advantages of low power consumption, high transmit power and full LoRa frequency band, while optimizing the cost structure, removing the less used "ultra-low rate scenario", achieving significant price advantages, making it more suitable for smart home applications, medium-range indoor and indoor-to-outdoor wireless applications.
Self-developed by Elecrow with exclusive design. Customization can be discussed for bulk orders.
Model CIL13728X
nrflrcc68_wireless_transceiver_module1
  • High performance: Maximum transmit power can reach +20dBm, support 1.76~62.5Kbps transmission rate, -125.5dBm sensitivity SF12/BW=125kHz, 151db link budget;
  • Ultra-low power consumption, sleep current is only 5uA;
  • Support 850~930MHz global LoRa&LoRaWAN ISM frequency, support LoRa point-to-point (P2P) communication; nRF52840 Bluetooth 5.3 SoC, support low-power Bluetooth, Bluetooth mesh network, NFC, Thread and Zigbee;
  • Long-distance communication, the communication distance can reach 10km;
  • Built-in AT command firmware and support the use of SDK for customized product development, and the AT command set can be easily used through the UART interface;
  • Rich peripherals, the module leads to a variety of GPIO interfaces such as UART, I2C, ADC, etc., providing great flexibility;
  • Compact form factor with only 20x 20x 3.5 mm
  • FCC, CE, RoHS certification
Processor nRF52840 processor, dual-core 32-bit, 64MHz main frequency
RF chip Semtech LLCC68 Chip
LoRa Specification
Transmit Power TX +20 dBm@Max
Receiving Sensitivity -125.5dBm
Link Budget Support 151db link budget
Demodulator Support LoRa/(G)FSK signal modulation
LoRa Frequency Range Support 150MHz-960MHz configuration
Spreading Factor SF5~SF11
Data Transfer Rate Supports data transmission rates from 1.76 to 62.5 Kbps
Other
Frequency Covering 850~930MHz (applicable to 868MHz, 915MHz)
Communication Interface SPI(0~10Mbps)
Lead Pin Such as SPI signal, VCC, multiple GND, NRST, ANT, TX control, RX control, BUSY status, NFC, SWD debugging pin, etc.
Antenna Not onboard, via RF pins
Reference Power Consumption 5uA (sleep), 120mA (transmit + MCU), 12mA (receive + MCU)
Communication Distance 5~6km, maximum over 10km
Crystal Type Industrial grade 32MHz TCXO
LoRaWAN Protocol Class A/B/C (compliant with LoRaWAN 1.0.3 specification)
Operating Voltage 1.8~3.7V
Operating Temperature -40℃~+85℃, Industrial standard design
Package Size 20*20*3.5mm, 80-Pin, SMT patch, LGA package;
Weight 3g
Pin Definition:
nrflrcc68_wireless_transceiver_module2
System Diagram:
nrflrcc68_wireless_transceiver_module3
Dimension:
nrflrcc68_wireless_transceiver_module4
Resources
Github link:
AT Command Description:
How to buy
Please visit this page to purchase Elecrow nRFLR1110 Wireless Transceiver Module.
Support
