All-in-one Starter Common Board Kit for Arduino¶
The All-in-one Starter Kit for Arduino is a perfect kit designed for beginners, aiming to introduce you to the world of Arduino in a fun and easy way. This kit has over 20 interactive tutorials, ranging from easy to hard. They will guide you step by step to master using sensors, improve your logic, and boost your creativity.
The kit has 15 sensors. It includes 14 on-board sensors and 1 Moisture Sensor with a Crowtail interface. Each sensor has unique features and functions. These sensors are perfect for Arduino novices. They are great entry-level tools to inspire logic and innovation.
This kit can quickly start you on basic Arduino programming. It's for students, educators, and hardware fans. With this comprehensive starter kit, you will be able to explore the infinite possibilities of the world of electronics.
Model SEA0004T
- 15 sensors with different functions, more than 20 creative tutorials;
- Common board design for sensors, no need to solder wires, direct use;
- Well-designed packaging, portable suitcase, small and exquisite;
- Reserved 6 Crowtail interfaces, 3x I/O, 2xI2C, 1xUART;
- Visualized silk screen printing, corresponding to the characteristics of each sensor;
- Main Processor IC: ATmega328P
- Interface: Type-C
- Size: 195*170*46mm
- Material: PP
- Weight: 380g
Pin Output:¶
Sensor | pin | *note* |
I2C | A5/SCLA4/SDA | |
UART | D0/RXD1/TX | |
A Sensor3 | A3 | |
A Sensor6 | A6 | |
A Sensor11 | D11 | |
LIGHT SENSOR | A5/SCLA4/SDA | ADDR:0X5C |
LED | D10 | |
BUTTON | D7 | |
SERVO | D9 | |
PIR | A2 | |
MPU-6050 | A5/SCLA4/SDA | Default Address = 0x68 (pin AD0 is logic low) |
Buzeer | D3 | |
Linear Potentiometer | A0 | |
Relay | D4 | |
Sound Sensor | A1 | |
IR Remote Sensor | D2 | |
Temperature & Humidity(DHT20) | A5/SCLA4/SDA | ADDRESS:0X38 |
Ultrasonic Sensor | D5_US_ECHOD6_US_TRIG | |
I2C_LCD | A5/SCLA4/SDA | ADDRESS:0X21 |
Resources¶
Github linkļ¼
How to buy¶
Please visit this page to purchase All-in-one Starter Common Board Kit for Arduino.
Support¶
