ThinkNode M9 MeshCore Communication Terminal with Full Keyboard
Document version: 2026-08-13
Applicable device: Elecrow ThinkNode M9 V1.0
Applicable software: MeshCore Ripple v12.0 as shown in the device photos; menus may change with firmware updates.
Table of Contents
1. Product Introduction
1.1 Product Overview
The MeshCore version of the ThinkNode M9 is a standalone MeshCore communication terminal with a display, full keyboard, and battery. The device integrates an ESP32-S3, LR1110 LoRa, GNSS, 2.4-inch LCD, dual-MCU keyboard, microSD, RTC, magnetic sensor, motion sensor, buzzer, Wi-Fi, and Bluetooth. It can handle text communication, contact management, channel chats, and location viewing without relying on a phone.
In MeshCore, the M9 operates as a Standalone/Client terminal by default. It can send and receive multihop messages through a Repeater, but ordinary handheld terminals do not automatically forward messages for other nodes.
Typical uses:
  • Offline text communication in areas without cellular coverage;
  • Hiking, camping, event coordination, and emergency communication;
  • Public channels, private channels, and private chats with contacts;
  • GNSS positioning, location sharing, and offline map viewing;
  • MeshCore network inspection and Repeater path diagnostics.
1.2 Safety Information and Unboxing
1.2.1 Safety Information
  1. Before powering on or transmitting, install a LoRa antenna that matches the hardware frequency band.
  2. Frequency, BW, SF, CR, and TX Power must comply with local regulations and the target network plan.
  3. Do not disclose the device's private key, private channel keys, administrative password, or precise home location.
  4. Ensure that the battery has sufficient charge during firmware updates. Do not power off the device, disconnect cables, or remove the card.
  5. Use only firmware explicitly intended for the ThinkNode M9.
  6. The LCD, TF card, and LR1110 share the same SPI bus. When developing custom firmware, manage each CS correctly and never select multiple peripherals simultaneously.
1.2.2 Package Contents
  • ThinkNode M9 unit;
  • USB-C data/charging cable;
  • ThinkNode M9 Starter Card;
1.3 Hardware Architecture and Specifications
1.3.1 Key Specifications
Item ThinkNode M9 V1.0
Main controller ESP32-S3-R8
Keyboard controller ESP32-S2
LoRa Semtech LR1110
GNSS ATGM336H-5NR32 / BM72A
Display 2.4-inch color LCD, 320 × 240
RTC PCF8563
Magnetic sensor QMC6309
Motion sensor QMI8658B
Flash ZD25Q128CSIGT
USB-UART CH340K
Storage microSD/TF
Wireless connectivity 2.4 GHz Wi-Fi, Bluetooth, LoRa
Battery 2300 mAh rechargeable lithium battery
Charging/data USB-C
1.3.2 Hardware Block Diagram
USB-C -- CH340K ------>|                   |<------ Wi-Fi / Bluetooth
                       |   ESP32-S3-R8 U9   |
GNSS UART/PPS -------->|                   |<-- I2C --> RTC
                       |                   |<-- I2C --> QMC6309 + QMI8658B
                  shared SPI: SCK/MOSI/MISO
                 LR1110        LCD          microSD
                 own NSS       own CS       own CS
ESP32-S2 U10 <---- SDA/SCL + WAKEUP ----> ESP32-S3 U9
      +---- keyboard matrix, shortcut keys and keyboard LED
1.4 Official and Reference Resources
2. Product Pinout
2.1 Main ESP32-S3 GPIO Summary
Multiplexed pins such as MTCK/MTDO/MTDI/MTMS in the ESP32-S3 symbols correspond to GPIO39/GPIO40/GPIO41/GPIO42, respectively; SPICLK_P/SPICLK_N correspond to GPIO47/GPIO48, respectively; and XTAL_32K_P/XTAL_32K_N correspond to GPIO15/GPIO16, respectively.
Schematic Net ESP32-S3 GPIO Purpose
IO0_BOOT GPIO0 Main controller BOOT
5V_TEST GPIO1 5 V detection/test net
GPS_TX GPIO2 Main controller receives GNSS TX
GPS_RX GPIO3 Main controller transmits to GNSS RX
1PPS_TEST GPIO4 GNSS 1PPS
GPS_RST1 GPIO5 GNSS reset control
SCL GPIO6 RTC I2C SCL, isolated through a resistor
SDA GPIO7 RTC I2C SDA, isolated through a resistor
DONE GPIO8 Power/charging status net
BUZZER_EN GPIO9 Buzzer enable
GPS_ON/OFF GPIO10 GNSS on/off control
GPS_EN GPIO11 GNSS power enable
ESP32_WAKEUP GPIO12 Keyboard coprocessor wakes the main controller
BAT_ADC GPIO13 Battery-voltage ADC
LCD_RESET GPIO14 LCD reset
LCD_RS GPIO15 LCD RS/DC
LCD_CS GPIO16 LCD chip select
BL_EN GPIO17 LCD backlight enable
VDD_PERIPH_EN GPIO18 Peripheral power enable
LCD_TE GPIO19 LCD tearing-effect signal
ESP32-2_SDA GPIO20 Data line between the main controller and keyboard coprocessor
ESP32-2_SCL GPIO21 Clock line between the main controller and keyboard coprocessor
ESP32_MISO GPIO38 Shared SPI MISO
LR_NSS GPIO39 LR1110 chip select/NSS
ESP32_SCK GPIO40 Shared SPI SCK
LR_BUSY GPIO41 LR1110 BUSY
INTERRUPT GPIO42 LR1110 DIO9/interrupt
LR_NRESET GPIO45 LR1110 reset
KEY_LED GPIO46 Keyboard light control net
ESP32_MOSI GPIO47 Shared SPI MOSI
SD_CS GPIO48 microSD chip select
2.2 LR1110 LoRa
LR1110 Signal ESP32-S3 GPIO Description
LR_NSS / DIO1 GPIO39 SPI chip select; the LR1110 SPI signals are labeled DIO1-DIO4 in the schematic
ESP32_SCK / DIO2 GPIO40 SPI clock
ESP32_MOSI / DIO3 GPIO47 SPI controller out/peripheral in
ESP32_MISO / DIO4 GPIO38 SPI controller in/peripheral out
LR_BUSY / DIO0 GPIO41 Busy status
INTERRUPT / DIO9 GPIO42 Interrupt
LR_NRESET / NRESET GPIO45 Reset
DIO7, DIO8 Not connected to main controller GPIO Nets reserved in the schematic
2.3 LCD
LCD Signal ESP32-S3 GPIO FPC J6
LCD_RESET GPIO14 1
LCD_RS GPIO15 2
ESP32_SCK GPIO40 3
LCD_CS GPIO16 5
DISPLAY_VDD Power 6, 7
LCD_TE GPIO19 8
ESP32_MOSI GPIO47 9
GND - 10, 13, 14
LCD_A / LCD_K Backlight circuit 11, 12
BL_EN GPIO17 Backlight MOS control; not used directly as a logic signal on the FPC
2.4 microSD/TF Card
TF Signal ESP32-S3 GPIO Description
SD_CS / CD-DAT3 GPIO48 Chip select
ESP32_SCK / CLK GPIO40 Shared SPI clock
ESP32_MOSI / CMD GPIO47 Shared SPI MOSI
ESP32_MISO / DAT0 GPIO38 Shared SPI MISO
SD_3V3 - Card power
SPI usage rule: Before initializing or accessing a peripheral, ensure that only the target peripheral's CS is low among LR1110 NSS, LCD CS, and SD CS, and keep all others high.
2.5 GNSS
GNSS Signal ESP32-S3 GPIO Description
GPS_TX GPIO2 GNSS TX → ESP32 RX
GPS_RX GPIO3 ESP32 TX → GNSS RX
1PPS_TEST GPIO4 Pulse per second
GPS_RST1 GPIO5 Reset control
GPS_ON/OFF GPIO10 Module ON/OFF
GPS_EN GPIO11 Power enable
GPS_BAT Backup power Preserves ephemeris/RTC state
2.6 RTC and Sensors
Module Bus/Signal ESP32-S3 GPIO Notes
PCF8563 RTC SCL GPIO6 Dedicated RTC I2C net
PCF8563 RTC SDA GPIO7 Dedicated RTC I2C net
QMC6309 3D_SCL GPIO6, through R44 Shares the sensor I2C bus with the QMI8658B
QMC6309 3D_SDA GPIO7, through R47 Magnetometer
QMI8658B 3D_SCL GPIO6, through R44 Motion sensor
QMI8658B 3D_SDA GPIO7, through R47 CS connected high and SDO/SA0 grounded; operates in I2C mode
Peripheral power VDD_PERIPH_EN GPIO18 Enables power to sensors/LCD-related peripherals
2.7 Keyboard Subsystem (ESP32-S2 U10)
The keyboard matrix is scanned by a separate ESP32-S2, which communicates with the main controller through ESP32-2_SDA/SCL and uses GPIO12 to wake the main controller.
Function ESP32-S2 GPIO
ROW1 / ROW2 / ROW3 / ROW4 / ROW5 GPIO40 / GPIO42 / GPIO45 / GPIO9 / GPIO19
COL1-COL5 GPIO36 / GPIO37 / GPIO20 / GPIO21 / GPIO11
COL6-COL10 GPIO1 / GPIO2 / GPIO3 / GPIO4 / GPIO5
KEY_INT GPIO12
Main controller communication SDA / SCL GPIO7 / GPIO6
Wake line GPIO8
Keyboard light GPIO41
Coprocessor BOOT GPIO0
Dedicated keys are also connected individually to GPIO18, GPIO10, GPIO39, GPIO38, GPIO33, and GPIO34. During development, refer to the keyboard firmware and the switch identifiers in the schematic; do not assume that key values correspond to main controller GPIO numbers.
2.8 Other Hardware Signals
Function GPIO/Device Description
Buzzer GPIO9 BUZZER_EN Controlled through a driver transistor
Battery monitoring GPIO13 BAT_ADC Routed to the ADC through a voltage divider and filter
USB-UART CH340K U3 Used for serial communication/maintenance; USB D+/D- are also connected to the USB interface net
RTC backup PCF8563 + RTC_3V3 Powered by the backup power net
Charging LGS4056HDA-4.35 U6 The schematic specifies the charging-current formula as I=1000/R
3. Software Operation
3.1 Power-On, Creating a New Network, and Basic Controls
3.1.1 Power-On
After installing the antenna and charging the device, power it on. The device first displays Elecrow, followed by MeshCore Ripple.
Elecrow startup screen
MeshCore Ripple startup screen
On first startup, an online user guide QR code is displayed. Scan the code to read the guide, or select OK to continue.
Online user guide QR code
3.1.2 Built-In Control Tutorial
HELP : Selection means: Use the Up/Down directional buttons to move the selection bar to SELECT THIS, then press the center button.
Selection tutorial
In the menu tutorial, first press the menu button to open the menu in the upper-right corner, then move to SELECT THIS and press the center button to confirm.
Menu tutorial
Press and hold the center button for approximately 1 second to turn off the screen. Press it once to turn the screen back on. Continue pressing the center button to advance to the next help page.
Screen on/off tutorial
3.1.3 Basic Controls
Button Function
D-pad Up/Down/Left/Right Move focus, scroll through lists, or pan the map
D-pad center button Confirm/open; on some pages, press and hold to turn off the screen
Home Return to the Home page
Back Return to the previous page
Menu button Open the menu in the upper-right corner
Chat shortcut Open the chat/message page
Map shortcut Open the map
Location button Positioning/location functions
QWERTY keyboard Enter names and messages
3.1.4 Creating a New MeshCore Network
  1. Under New Network → Select Type, select MeshCore.
Select MeshCore
  1. Under Select Preset, select a preset that complies with local regulations and the community network plan. The example shown in the photo uses EU/UK (Long Range), which is suitable only in regions where this configuration is permitted; do not duplicate it in other regions.
Select EU UK Long Range
  1. Enter a Network Name and confirm. The name is used to identify the network locally and does not replace the radio parameters or channel key.
Set the network name
  1. After saving, the Home page appears. For two devices to communicate, their Frequency, BW, SF, CR, channel key, and any required Scope settings must be compatible.
3.2 Home and Extra Pages
3.2.1 Home Page Information
M9 Home page
Screen Area/Item Description
Name at the top Current device/network display name; NONAME is shown in the image
Time Current device time; an incorrect time can affect the evaluation of discovery records
Battery icon and voltage Battery status and measured voltage
L / M Left-side page/mode labels; their exact meanings vary by firmware version
Circular status icon LoRa/node status indicator
MeshCore Current network configuration; the Wi-Fi icon on the right indicates the relevant status and does not necessarily mean that the device is connected to a network
Discover Discover nodes, send an ID, and scan for directly reachable nodes
Public Default public channel
Channel #1... Enabled private channels
Lower-left menu Open the function menu/additional items
3.2.2 Extra Page
From the Home page, open preset information/Extra. The photos show three sections of the same scrollable list.
Top of Extra page
Middle of Extra page
Bottom of Extra page
Item Function
GPS Info View satellites, Fix, latitude/longitude, accuracy, and time
Sound Message/key sound mode
Vib/LED Vibration and LED notification mode
Timestamps Toggle message timestamps
Brightness Screen brightness/day and night mode
Display Display and sleep settings
Wi-Fi Wi-Fi on/off, scanning, and connection; official unlocking may be required
Security Security, keys, and related permission settings
LR1110 LoRa chip/RF-related information or settings
Networks Network configuration list and Profile Details
Unlock Official license-unlocking entry point
Storage microSD, storage space, and file functions
Snake Game Built-in mini-game
GPS Config GNSS operating mode and configuration
Timezone Time zone settings
Waypoints Waypoint management
Canned Preset/quick messages
Help Built-in operating instructions
3.3 Network and Radio Settings
Path: Extra → Networks → Select Profile → Profile Details.
Profile Details
Item Meaning Interoperability Requirements
Name Profile name Display name only; does not determine interoperability
Frequency Center frequency, MHz Must match and comply with regulations
SF Spreading factor Must match; higher values are generally slower but provide better weak-signal performance
CR Coding rate Must match; greater redundancy increases airtime
BW Bandwidth, kHz Must match; wider bandwidth generally provides higher speeds
The example shown in the photo is 869. 525 MHz / SF11 / CR5 / BW250. It is only an EU/UK Long Range example, not a globally applicable setting. Prefer a complete Preset provided by the manufacturer or local community instead of changing only the Frequency.
For a read-only check in Terminal, use:
get radio
The returned values are typically ordered as follows:
frequency,bw,sf,cr
Do not use set radio or set TX Power to the maximum unless you understand the hardware frequency band, applicable regulations, and network parameters.
3.4 Channel Communication
3.4.1 Public Channel
Public uses a publicly shared key. It is suitable for testing, announcements, and public communication, but not for passwords, private locations, or other sensitive information.
3.4.1.1 Sending
  1. Select Public on the Home screen.
  2. After entering MeshCore.Public, type a message in the input field at the bottom.
  3. Press the Send/Confirm key, then wait for the message to appear in the list and for wireless retries to complete.
Sending a message in Public
3.4.1.2 Receiving and Interpreting Messages
Received messages are displayed as "node name: content." In the photo, NONAME: 2 means that the node named NONAME sent the content 2.
Sending and receiving messages in Public
  • Channel messages typically use Flood; do not rapidly resend the same content.
  • A local message appearing on the Public page does not necessarily mean that all remote nodes have received it.
  • If messages are not received, check the four Radio parameters, channel key, time, antenna, and Scope.
3.4.2 Private Channels
The confidentiality of a private channel comes from its channel key, not its channel name. All members must use the same channel name/slot configuration, an identical key, compatible Radio parameters, and the same Scope.
3.4.2.1 Creating and Enabling a Channel
  1. From the Home screen, open MeshCore settings.
  2. Scroll down to Channel #1 and open it.
Channel 1 in MeshCore settings
  1. Set the name under Channel Details. A name beginning with # can be used as an automatic channel name. The photo shows the Hex format and displays the channel key.
Private channel details
  1. Use the menu/preset information button in the upper-right corner of the page to enable and save the channel.
  2. Configure the same channel name and key on the other device. Transfer the key through a trusted end-to-end channel; never post it to Public.
3.4.2.2 Sending and Receiving Messages
After the channel is saved and enabled, a channel entry appears on the Home screen (#1 in this example).
Private channel on the Home screen
Open the channel, enter a message, and send it. Received channel messages are also displayed as "node name: content."
Private channel messages
If the key is compromised or a member leaves, create a new channel with a new random key and migrate the members to it. Changing only the name does not prevent anyone with the old key from receiving messages.
3.5 Discover, Contacts, and Private Chats
3.5.1 Discovering Each Other
  1. Configure both M9 devices with the same Radio Preset, install their antennas, place them close together, and turn them on.
  2. From the Home screen, open Discover.
Opening Discover
  1. On device A, open the menu in the upper-right corner and select Send ID Local to send the device identity only within direct communication range.
Sending the local ID
  1. On device B, select Scan Local... to scan for directly connected zero-hop nodes.
Scanning for directly connected nodes
  1. Reverse the process so that both devices can see each other. Use Send ID Broadcast only when propagation through a Repeater is required; do not broadcast frequently.
3.5.2 Adding a Contact and Starting a Private Chat
  1. Open the target node in the Discover results.
  2. Verify its name, public key/identity information, and last-heard time.
  3. Select Add to Contacts or Save Contact.
  4. Open the contact conversation from Contacts or Chats, enter text, and send it.
  5. The first message may use Flood for route discovery; subsequent messages typically use a learned directed route.
  6. If delivery repeatedly fails, check whether the other device is online and verify the Radio, Scope, and Repeater settings. Use Trace/Optimise to rebuild the route if necessary.
Heard only indicates that a broadcast or packet from the target was received. It does not mean that the other party received or read a private message.
3.6 GPS and Maps
3.6.1 Acquiring a GPS Fix
  1. Go to an open outdoor area away from tall buildings, metal structures, and obstructions inside vehicles.
  2. Open Extra → GPS Info or use the location shortcut, and confirm that GPS is enabled.
  3. Keep the device stationary and wait for the status to change from Searching to Fix/Valid.
  4. Check the satellite count, latitude, longitude, UTC time, and accuracy.
  5. Use the coordinates for navigation or location sharing only after obtaining a new valid Fix. Without a Fix, the device may display the last cached location.
GPS is not required for LoRa chat, but it is used for automatic time synchronization, current location, distance, direction, and location sharing.
gps
3.6.2 Viewing the Map
  1. Prepare a reliable FAT32 microSD card and load offline map data onto it as required by the current firmware.
  2. Press the map shortcut or Space key to open Map.
  3. Press the location/position key to center the map on the current GPS Fix.
  4. Use the D-pad to pan and the keys indicated on the page to zoom.
  5. Open a location card received from a contact or channel and select Show on Map to view the other party's location.
You can still browse existing offline maps without a GPS Fix, but "my location," distance, and direction will be unavailable or inaccurate. If the map is blank, check whether the microSD card is recognized, as well as the map directory/tile format, zoom level, and coverage area.
map
3.6.3 Location Privacy
  • none: Advert does not include a location;
  • share: Shares the current GPS Fix;
  • prefs: Shares a saved static location.
Assess personal safety and privacy risks before sharing your precise location in Public or in a broadcast identity.
3.7 Wi-Fi and Official Unlocking
Wi-Fi is used for online time synchronization, Internet Link, CoreBrowser, OTA, and certain Companion features. It is not required for basic LoRa communication.
The M9/firmware may lock Wi-Fi or network connectivity features. You must contact the manufacturer or seller to obtain the required device license and unlock these features: Unlock URL: register.rippleradios.com.
  1. Open Extra → Unlock or Settings → About/Activate/License.
  2. Record the order number, device serial number/public key, firmware version, and error message.
  3. Follow the official Elecrow/MeshCore support process to obtain a device-specific unlock code or license file.
  4. Import the license under Unlock/Activate/Import License, then restart the device.
  5. Open Extra → Wi-Fi, enable Wi-Fi, then scan for and select a 2.4 GHz SSID.
  6. Enter the password, confirm that Connected and an IP address appear, then test online time synchronization or Internet Link.
Do not use third-party cracking patches, shared online licenses, or firmware not intended for the M9. Licenses are typically bound to a device identity and cannot be reused on another M9.
3.8 Repeater, Regions, and Scope
3.8.1 Node Roles
Role Function
Standalone/Client Default M9 role for chats, contacts, and location; does not automatically forward packets
Repeater Forwards matching MeshCore packets to extend coverage
Room Server Provides room/BBS services and may participate in forwarding depending on its configuration
Sensor Sends telemetry or alert data
3.8.2 Regions and Scope
Regions are logical propagation areas, not 433/868/915 MHz RF regions.
└─ China
   └─ Guangdong
      └─ Shenzhen
  • Set as Home: Specifies the Region to which the local device belongs;
  • Set Default Scope: Specifies the message Scope used when none is explicitly selected;
  • A larger Scope may increase the Flood range and airtime usage;
  • Keep the default settings when there is no unified community plan; do not arbitrarily create an incompatible Region tree.
3.8.3 Repeater Usage Guidelines
By default, an M9 handheld terminal is not a dedicated Repeater. To extend coverage, deploy a compatible device running Repeater firmware, configure it with the same Radio parameters as the M9, and assign it a unique name, location, and strong administrative password. Use Trace, Heard, RSSI, and SNR to inspect the route.
3.9 Firmware, Storage, and Maintenance
3.9.1 microSD
A microSD card can be used for offline maps, license files, logs, and firmware updates. A reliable FAT32 card is recommended. Directory and tile formats vary by firmware version; always follow the release notes for the current M9 firmware.
3.9.2 Firmware Updates
Before updating:
  • Ensure that the battery is sufficiently charged;
  • Back up channel names, channel keys, and important settings;
  • Confirm that the filename/release page explicitly identifies the firmware as being for the M9;
  • Read the release notes and verify the SHA-256 checksum, if provided.
Firmware update URL: https://meshcore.io/flasher
3.10 Troubleshooting
3.10.1 Discover Cannot Find a Node
  1. Confirm that Frequency, BW, SF, and CR are identical on both devices.
  2. Check the antennas and hardware frequency bands.
  3. Place the devices close together. Run Send ID Local on device A and Scan Local on device B, then reverse the process.
  4. Check the device time and Scope.
  5. Check whether RX, RSSI, and SNR values change in the diagnostics.
3.10.2 A Node Is Visible, but Messages Are Not Received
  • Public/private channels: Check the channel key, Radio, and Scope;
  • Private chats: Check the contact identity, route, Repeater, and whether the other party is online;
  • Do not treat a message appearing in the local device's list as proof that it was delivered to the remote device.
3.10.3 The Wi-Fi Icon Is On, but the Device Cannot Access the Internet
The icon may only indicate that Wi-Fi is enabled. Check whether the device has been officially unlocked, whether the SSID uses 2.4 GHz, the password, the Connected status, the IP address, and any router access restrictions.
3.10.4 GPS Does Not Acquire a Fix for an Extended Period
Go to an open outdoor area and remain stationary while waiting. Check GPS Config, power, and antenna status. A cold start may take several minutes. The absence of a Fix does not affect basic LoRa chat.
3.10.5 The Map Is Blank
Check the microSD card, FAT32 formatting, directory/tile format, zoom level, and map coverage area. The absence of a GPS Fix only affects positioning and should not prevent you from browsing existing offline tiles.
For initial acceptance testing, complete the following steps in order: confirm the antenna and frequency band → create the correct Preset → run Send ID Local/Scan Local on the two devices → send and receive messages in Public → send and receive messages in a private channel using the same key → test private messaging with a contact → acquire an outdoor GPS Fix → verify map positioning → connect to Wi-Fi after completing the official unlock process.
How to buy
Please visit this page to purchase thinknode-m9-meshcore.
Support
