CrowPanel ESP32 E-Paper 4.2-inch Arduino Tutorial¶
Overall¶
This tutorial will demonstrate how to use ESP32 E-Paper Display as a price tags and update price images through WiFi and Bluetooth. And how to obtain weather information and display it on ESP32 E-paper display. In addition, there are simple examples to illustrate how to use the various interfaces on the board.
Get Started with Arduino IDE¶
Demo 1 Update Pictures Wireless¶
This demo will introduce how to wireless update a single price tag through WiFi and Bluetooth.
Update via WiFi¶
Convert the image format¶
First, let's take a look at the price tag we design in this example, which is divided into three parts(all are images). The top bar is a fixed. The description and the price is variable. The parts we need to update are the description and price.
For the fixed top bar, we can convert it to C array and put them in the code.
For the variable description and price, we need to convert them to bin file and upload them to the board through WiFi.
Click open and select top-bar.bmp, convert it to array format.
- Open file
 - Output date type: C language array by default
 - The biggest width and height: Consistent with the width and height of the image. Note that it must be a multiple of 8, otherwise it cannot be displayed properly
 - Save and output
You can put this array in a suitable header file, and I have placed it in Ap_29demo. h here.
Convert the description pictures and price tag pictures to bin files. These bin files will be used to update prices over WiFi.
- Open the file
 - The output type select .bin file
 - The width and height should consistent with the width and height of the image. Note that it must be a multiple of 8, otherwise it cannot be displayed properly
 - Save the file
Code Explanation¶
Please click
 to download the code file WIFI_refresh.zip for this demo.
Add necessary libraries
#include <Arduino.h>           // Include the Arduino core library
#include "EPD.h"               // Include the EPD library for controlling the electronic ink screen (E-Paper Display)
#include "EPD_GUI.h"           // Include the EPD_GUI library for graphical user interface (GUI) operations
#include "Ap_29demo.h"         // Include the Ap_29demo library, which may be a custom application library
#include <WiFi.h>              // Include the WiFi library for Wi-Fi functionality
#include <Ticker.h>            // Include the Ticker library for timer tasks
#include <WebServer.h>         // Include the WebServer library for creating a web server
#include "FS.h"                // Include the file system library for file operations
#include "SPIFFS.h"            // Include the SPIFFS library for the SPIFFS file system
Define the file variable fsUploadFile Used for accessing files, txt_size and pre_size correspond to the size of the BIN file(Exported in the above steps) for the text label and price label to be transmitted. The image resolution requirement is smaller than the screen resolution and both width and height are multiples of 8.
Note: The size here can be defined based on the size of the images to be transmitted later, otherwise it will cause image transfer failure
UI_price() Function
Check if the file system has saved UI images, and if so, display them.
// UI_price function: Update the price display interface
void UI_price() {
  clear_all();  // Clear all display content
  EPD_ShowPicture(0, 0, EPD_W, 40, background_top, WHITE); // Display the top background image on the screen, with the background color as white
  if (SPIFFS.exists("/txt.bin")) {
    // If the file exists, read the file content
    File file = SPIFFS.open("/txt.bin", FILE_READ);
    if (!file) {
      Serial.println("Failed to open file for reading");
      return;
    // Read data from the file into the array
    size_t bytesRead = file.read(txt_formerly, txt_size);
    Serial.println("File content:");
    while (file.available()) {
      Serial.write(file.read()); // Print the file content
    file.close();
    EPD_ShowPicture(20, 60, 272, 112, txt_formerly, WHITE); // Display the read image on the screen, with the background color as white
    flag_txt = 1; // Set the flag
  if (SPIFFS.exists("/pre.bin")) {
    File file = SPIFFS.open("/pre.bin", FILE_READ);
    if (!file) {
      return;
    size_t bytesRead = file.read(price_formerly, pre_size);
    file.close();
    EPD_ShowPicture(20, 190, 352, 104, price_formerly, WHITE); // Display the read image on the screen, with the background color as white
    flag_pre = 1; // Set the flag
  // Display the image stored in the Image_BW array
  EPD_Display_Part(0, 0, EPD_W, EPD_H, ImageBW);
  EPD_Sleep(); // Enter sleep mode to conserve energy
okPage() Function
Receive the bin file sent and determine if it matches the pre-set file size. If it matches, store it in the file system and update the display icon.
// Function to handle file upload requests
void okPage()
  server.send(200, "text/html", HTML_OK); // Return the page indicating successful upload
  HTTPUpload &upload = server.upload(); // Get the uploaded file
  // Note: The default size of upload.buf may not be sufficient to handle large files
  // Please refer to the definition of HTTP_UPLOAD_BUFLEN in WebServer.h, adjust the initial size to support large file transfers
  if (upload.status == UPLOAD_FILE_END) // If file upload is complete
    Serial.println("draw file"); // Print debug information: file upload complete
    Serial.println(upload.filename); // Print the uploaded filename
    Serial.println(upload.totalSize); // Print the size of the uploaded file
    if (upload.totalSize == txt_size) // Check if the uploaded file size matches the predefined txt_size
      filename = "txt.bin"; // Set the filename to txt.bin
    else
      filename = "pre.bin"; // Otherwise, set the filename to pre.bin
    if (!filename.startsWith("/")) filename = "/" + filename; // If the filename does not start with '/', add '/' prefix
    fsUploadFile = SPIFFS.open(filename, FILE_WRITE); // Open the file for writing
    fsUploadFile.write(upload.buf, upload.totalSize); // Write the uploaded file data to the file
    fsUploadFile.close(); // Close the file
    Serial.println("Saved successfully"); // Print the message that the save was successful
    Serial.printf("Saved: "); // Print the saved filename
    Serial.println(filename);
    // Copy the uploaded file data to the corresponding buffer array
      for (int i = 0; i < txt_size; i++) {
        txt_formerly[i] = upload.buf[i]; // Copy data to txt_formerly
      Serial.println("txt_formerly OK"); // Print the message that txt_formerly has been successfully updated
      flag_txt = 1; // Set the flag_txt to 1
    } else
      for (int i = 0; i < pre_size; i++) {
        price_formerly[i] = upload.buf[i]; // Copy data to price_formerly
      Serial.println(" price_formerly OK"); // Print the message that price_formerly has been successfully updated
      flag_pre = 1; // Set the flag_pre to 1
    clear_all();  // Clear all content on the display
    // Display the background image
    EPD_ShowPicture(0, 0, EPD_W, 40, background_top, WHITE); // Display the background image on the screen, with the background color as white
    if (upload.totalSize != txt_size) // If the uploaded file size does not match txt_size
      if (flag_txt == 1) // If flag_txt is 1
        // Display images from txt_formerly and price_formerly
        EPD_ShowPicture(20, 60, 272, 112, txt_formerly, WHITE); // Display the txt_formerly image
        EPD_ShowPicture(20, 190, 352, 104, price_formerly, WHITE); // Display the price_formerly image
      } else
        // Display only the price_formerly image
    } else
      // When the uploaded file size equals txt_size, process different display content
      if (flag_pre == 1) // If flag_pre is 1
        // Display images from price_formerly and txt_formerly
      } else
        // Display only the txt_formerly image
    // Quickly display the image stored in the Image_BW array
Image Refresh Process
Initialization
EPD_GPIOInit(); // Initialize the screen GPIO EPD_Clear(); // Clear the screen Paint_NewImage(ImageBW, EPD_W, EPD_H, 0, WHITE); // Create a new canvas, set the canvas to white EPD_Full(WHITE); // Clear the canvas, fill with white EPD_Display_Part(0, 0, EPD_W, EPD_H, ImageBW); // Display the blank canvas EPD_Init_Fast(Fast_Seconds_1_5s); // Initialize the screen, set update speed to 1.5 seconds -
Clear screen
Select the data to refresh
Update the image to the screen
Upload the Code¶
Open the WIFI_refresh.ino
Click "Tools"->"Board"->"esp32"->"ESP32S3 Dev Module", and the "Partition Scheme" select "Huge APP (3MB No OTA/1MB SPIFFS)", "PSRAM" select "OPI PSRAM".
Connect CorwPanel to the computer, click on "Tool" and select the corresponding "port".
Click "Upload" to upload the code to the board. There will be an image show on the screen.
Update the price tag with WiFi¶
Connect a laptop to the hotspot of the ESP32 E-PAPER display.
Enter the IP address 192.168.4.1 in the browser.
Select the bin file of the picture you need to show, then click submit.
Note: The size of the images you transfer must be consistent with the size defined in the code, otherwise it will cause image transfer failure
After successful transmission, the price and text will be replaced, and the data will be saved in flash.
Update via Bluetooth¶
The same as the method in the "Update via WiFi".
Code Explanation¶
Please click
 to download the code file ble_refresh.zip for this demo.
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
#include "EPD.h"
#include "FS.h"           // File system library
#include "SPIFFS.h"       // SPIFFS file system library, for file read/write
ble_pic function
Process the bin file sent and determine if it matches the pre-set file size. If it does, store it in the file system and update the display icon.
// Function: Handle Bluetooth data
void ble_pic()
  // Check if data has been received
  if (dataReceived) {
    // If the data buffer is not empty
    if (!dataBuffer.empty()) {
      // Get the size of the data buffer
      size_t bufferSize = dataBuffer.size();
      Serial.println(bufferSize);
      // Determine the filename based on the size of the data buffer
      if (dataBuffer.size() == txt_size) // If the data size equals txt_size
        filename = "txt.bin"; // Filename is txt.bin
      else
        filename = "pre.bin"; // Otherwise, filename is pre.bin
      // Ensure the filename starts with "/"
      fsUploadFile.write(dataBuffer.data(), dataBuffer.size()); // Write the data
      // Update flag_txt or flag_pre based on the size of the data buffer
      if (bufferSize == txt_size) {
          txt_formerly[i] = dataBuffer[i]; // Copy the data to txt_formerly
        flag_txt = 1; // Set the flag_txt flag
      } else {
          price_formerly[i] = dataBuffer[i]; // Copy the data to price_formerly
        Serial.println("price_formerly OK");
        flag_pre = 1; // Set the flag_pre flag
      clear_all();
      EPD_ShowPicture(0, 0, EPD_W, 40, wifi_background_top, WHITE);
      // Determine the display content based on the size of the data buffer and the flags
      if (bufferSize != txt_size) {
        if (flag_txt == 1) {
          EPD_ShowPicture(20, 60, 272, 112, txt_formerly, WHITE); // Display txt_formerly
          EPD_ShowPicture(20, 190, 352, 104, price_formerly, WHITE); // Display price_formerly
        } else {
      } else {
        // If the data size equals txt_size, determine the display content based on flag_pre
        if (flag_pre == 1) {
        } else {
          EPD_ShowPicture(0, 80, 152, 160, txt_formerly, WHITE); // Display txt_formerly
      // Enter sleep mode
      EPD_Sleep();
      // Clear the data buffer after writing the data
      dataBuffer.clear();
      // Reset the total number of bytes received
      totalReceivedBytes = 0;
      // Reset the data received flag after processing the data
      dataReceived = false;
class MyCallbacks : public BLECharacteristicCallbacks
Receive the data sent and integrate it together. Receiving the "OK" character indicates that the transmission is complete.
// BLE characteristic callback class
class MyCallbacks : public BLECharacteristicCallbacks {
    void onWrite(BLECharacteristic *pCharacteristic) {
        std::string value = pCharacteristic->getValue(); // Get the characteristic value
        if (value.length() > 0) {
            Serial.printf("."); // Output a dot for each data block received
            // Check if the complete data has been received
            if (value == "OK") {
                dataReceived = true; // Set the data received flag
                return;
            // Append the received data to the buffer
            size_t len = value.length(); // Get the data length
            if (len > 0) {
                dataBuffer.insert(dataBuffer.end(), value.begin(), value.end()); // Add data to the buffer
                totalReceivedBytes += len; // Update the total number of bytes received
UI_price
// Function: Update the price interface
void UI_price()
  clear_all();
  // If the txt.bin file exists, read its content
    if (!file) {
      return;
    file.close();
    // Display txt_formerly on the screen
  // If the pre.bin file exists, read its content
    if (!file) {
      return;
    file.close();
    // Display price_formerly on the screen
  // Enter sleep mode
  EPD_Sleep();
Initialization
EPD_GPIOInit(); // Initialize the EPD (electronic paper display) interface EPD_Clear(); // Clear the EPD screen Paint_NewImage(ImageBW, EPD_W, EPD_H, 0, WHITE); // Create a new image buffer EPD_Full(WHITE); // Clear the canvas EPD_Display_Part(0, 0, EPD_W, EPD_H, ImageBW); // Display a blank image EPD_Init_Fast(Fast_Seconds_1_5s); // Initialize the EPD display speed setting -
Clear screen
Upload the Code¶
Open the ble_refresh.ino.
Update the images via bluetooth¶
Download a BLE debugging assistant to your phone, and connect it your phone to the screen device BLE.
Upload the bin file(Save the bin file to your phone in advance).
Demo 2 Weather Station¶
Obtain weather information through OpenWeather and display the information on the CrowPanel.
First, let's take a look at the weather information panel we design in this example, which is divided into 6 parts(all are images).
- weather icon
 - city
 - humidity
 - wind
 - temperature
visibility
We need to convert the images of these 6 parts into C arrays and put them in the code, and combine them to form the UI interface above.
Click open and select the images, convert them to array format.
- Open file
 - Save and output
You can put this array in a suitable header file, and I have placed it in pic. h here.
Register an OpenWeather account¶
Enter https://openweathermap.org/ and click "Sing in" to register an OpenWeather account.
Log in your account.
Click your user name -> "My API Keys" to find your API key.
Code Explanation¶
Please click
 to download the code file wifi_http_openweather.zip for this demo.
Add libraries¶
#include <WiFi.h>
#include <HTTPClient.h>
#include <Arduino_JSON.h>
#include "pic.h"
Modify your information¶
const char* ssid = " ";       // Enter your ssid
const char* password = " ";     // Enter your WiFi password
// OpenWeatherMap API key
String openWeatherMapApiKey = "You-API"; //Enter your API key
// For example: String openWeatherMapApiKey = "bd939aa3d23ff33d3c8f5dd1dd435";
// Replace with city and country code you're in
String city = "London";                    // City Name
String countryCode = "2643743";            // Country Code
Country Code
You can find the country code at: http://bulk.openweathermap.org/sample/
Function Explanation¶
js_analysis
This function is mainly used to parse the received JSON data, process these data separately, and save them in variables.
// Function js_analysis is used to parse weather data and update weather information
void js_analysis()
  // Check if WiFi is connected successfully
  if (WiFi.status() == WL_CONNECTED) {
    // Build the OpenWeatherMap API request URL
    String serverPath = "http://api.openweathermap.org/data/2.5/weather?q=" + city + "," + countryCode + "&APPID=" + openWeatherMapApiKey + "&units=metric";
    // Loop until a successful HTTP response code of 200 is received
    while (httpResponseCode != 200)
      // Send an HTTP GET request and get JSON data
      jsonBuffer = httpGETRequest(serverPath.c_str());
      Serial.println(jsonBuffer); // Print the retrieved JSON data
      myObject = JSON.parse(jsonBuffer); // Parse the JSON data
      // Check if the JSON data was parsed successfully
      if (JSON.typeof(myObject) == "undefined") {
        Serial.println("Parsing input failed!"); // If parsing fails, print error message and exit
        return;
      delay(2000); // Wait 2 seconds
    // Extract weather information from the JSON data
    weather = JSON.stringify(myObject["weather"][0]["main"]); // Get the main weather description
    temperature = JSON.stringify(myObject["main"]["temp"]); // Get the temperature
    humidity = JSON.stringify(myObject["main"]["humidity"]); // Get the humidity
    sea_level = JSON.stringify(myObject["main"]["sea_level"]); // Get the sea level pressure
    wind_speed = JSON.stringify(myObject["wind"]["speed"]); // Get the wind speed
    city_js = JSON.stringify(myObject["name"]); // Get the city name
    // Print the extracted weather information
    Serial.print("String weather: ");
    Serial.println(weather);
    Serial.print("String Temperature: ");
    Serial.println(temperature);
    Serial.print("String humidity: ");
    Serial.println(humidity);
    Serial.print("String sea_level: ");
    Serial.println(sea_level);
    Serial.print("String wind_speed: ");
    Serial.println(wind_speed);
    Serial.print("String city_js: ");
    Serial.println(city_js);
    // Set the weather flag based on the weather description
    if (weather.indexOf("clouds") != -1 || weather.indexOf("Clouds") != -1 ) {
      weather_flag = 1; // Cloudy weather
    } else if (weather.indexOf("clear sky") != -1 || weather.indexOf("Clear sky") != -1) {
      weather_flag = 3; // Clear sky
    } else if (weather.indexOf("rain") != -1 || weather.indexOf("Rain") != -1) {
      weather_flag = 5; // Rainy weather
    } else if (weather.indexOf("thunderstorm") != -1 || weather.indexOf("Thunderstorm") != -1) {
      weather_flag = 2; // Thunderstorm weather
    } else if (weather.indexOf("snow") != -1 || weather.indexOf("Snow") != -1) {
      weather_flag = 4; // Snowy weather
    } else if (weather.indexOf("mist") != -1 || weather.indexOf("Mist") != -1) {
      weather_flag = 0; // Mist
  else {
    Serial.println("WiFi Disconnected"); // If WiFi is not connected, print error message
// Function httpGETRequest sends an HTTP GET request and returns the response content
String httpGETRequest(const char* serverName) {
  WiFiClient client; // Create a WiFi client object
  HTTPClient http; // Create an HTTP client object
  // Initialize the HTTP request with the specified URL
  http.begin(client, serverName);
  // Send the HTTP GET request
  httpResponseCode = http.GET(); // Get the HTTP response code
  String payload = "{}"; // Default response content is an empty JSON object
  // Check if the HTTP response code is greater than 0 (indicating success)
  if (httpResponseCode > 0) {
    Serial.print("HTTP Response code: ");
    Serial.println(httpResponseCode); // Print the HTTP response code
    payload = http.getString(); // Get the response content
  else {
    Serial.print("Error code: ");
    Serial.println(httpResponseCode); // Print the error code
  // Free the HTTP client resources
  http.end();
  return payload; // Return the response content
UI_weather_forecast
Display the processed data saved in the variable on the screen.
// Display weather forecast information
void UI_weather_forecast()
  // Create character arrays to store information
  char buffer[40];
  EPD_Display_Part(0, 0, EPD_W, EPD_H, ImageBW);  // Display a blank canvas
  // Display weather-related icons and information
  EPD_ShowPicture(7, 10, 184, 208, Weather_Num[weather_flag], WHITE);
  EPD_ShowPicture(205, 22, 184, 88, gImage_city, WHITE);
  EPD_ShowPicture(6, 238, 96, 40, gImage_wind, WHITE);
  EPD_ShowPicture(205, 120, 184, 88, gImage_hum, WHITE);
  EPD_ShowPicture(112, 238, 144, 40, gImage_tem, WHITE);
  EPD_ShowPicture(265, 238, 128, 40, gImage_visi, WHITE);
  // Draw partition lines
  EPD_DrawLine(0, 230, 400, 230, BLACK); // Draw horizontal line
  EPD_DrawLine(200, 0, 200, 230, BLACK); // Draw vertical line
  EPD_DrawLine(200, 115, 400, 115, BLACK); // Draw horizontal line
  // Display city name
  memset(buffer, 0, sizeof(buffer));
  snprintf(buffer, sizeof(buffer), "%s ", city_js); // Format the updated city as a string
  EPD_ShowString(290, 74, buffer, 24, BLACK); // Display city name
  // Display temperature
  snprintf(buffer, sizeof(buffer), "%s C", temperature); // Format the updated temperature as a string
  EPD_ShowString(160, 273, buffer, 16, BLACK); // Display temperature
  // Display humidity
  snprintf(buffer, sizeof(buffer), "%s ", humidity); // Format the humidity as a string
  EPD_ShowString(290, 171, buffer, 16, BLACK); // Display humidity
  // Display wind speed
  snprintf(buffer, sizeof(buffer), "%s m/s", wind_speed); // Format the wind speed as a string
  EPD_ShowString(54, 273, buffer, 16, BLACK); // Display wind speed
  // Display sea level pressure
  snprintf(buffer, sizeof(buffer), "%s ", sea_level); // Format the sea level pressure as a string
  EPD_ShowString(316, 273, buffer, 16, BLACK); // Display sea level pressure
  // Update the e-ink display content
  EPD_Display_Part(0, 0, EPD_W, EPD_H, ImageBW); // Refresh the screen display
  EPD_Sleep(); // Enter sleep mode to save energy
Upload the Code¶
Double click the wifi_http_openweather.ino.
After downloading, the weather information for the city you have selected will be displayed on CrowPanel.
Examples for the CrowPanel Interfaces¶
Please click
 to download the code file for the examples.
Example 1 Control the GPIO¶
Open the GPIO.ino.
Connect the LED to the GPIO pins.
Upload the code to the CrowPanel. The LEDs will turn on, and the status of the GPIO will show on the screen.
Example 2 Count the times of pressing the keys¶
Example 3 Control PWR LED with menu Key¶
Open the PWR.ino
Press the menu key and the PWR LED will turn on/off.
Example 4 Initialize SD card¶
Open TF.ino
Insert the TF card to the card slot.
The size of the TF card will show on the screen.
Example 5 Connect Bluetooth¶
Open BLE.ino
After the blutooth is connected, the screen will show:
Example 6 Connect WiFi¶
Open wifi.ino
Modify your ssid and password
After the WiFi is connected, the screen will show:
Example 7 Refresh image¶
This example will demonstrate two scenarios: refreshing full screen images and non full screen images.
- Full screen image: The resolution of the image is the same as the screen
 - Non full screen image: The image resolution is lower than the screen resolution
