Lesson4 The temperature and humidity sensor receives data in real time
Welcome to the Lesson 4 of learning.
This lesson will use the IIC interface and of this series of products to collect data from temperature and humidity sensors. In this lesson, we will use the knowledge of LVGL graphics library from Lesson 3 to create an interactive interface.
1 Introduce product ports
2 UI interface design
The temperature and humidity sensor needs to support IIC communication. In order to provide everyone with an intuitive observation, I will use LVGL to create an interactive interface.
IMG_258
Create Espressif project
Note: Use version 9.1.0 for small-sized items, and use version 8.3.11 for large-sized items.
IMG_261
IMG_263
Here is the corresponding image asset download link for each screen size:
IMG_265
IMG_266
IMG_267
IMG_268
IMG_269
IMG_270
IMG_271
IMG_272
IMG_273
IMG_274
IMG_275
IMG_276
IMG_282
Go to the folder path where you selected to output the UI file.
Click the link below and you can access the code for this lesson.
Code link:
2.8-inch / 2.4-inch V1.0
https://github.com/Elecrow-RD/CrowPanel-Advance-2.8-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-320x240/tree/master/example/V1.0/ESP_IDF
2.8-inch / 2.4-inch V1.1/V1.2
https://github.com/Elecrow-RD/CrowPanel-Advance-2.8-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-320x240/tree/master/example/V1.1_and_V1.2/ESP_IDF
Then use VSCode to open the IDF project folder. Copy the generated .h and .c files into the corresponding folders of the project. (Here, I will use the code for the 3.5-inch version as an example.)
3 Hardware connection
Connect the temperature sensor to the development board and power on the development board.
Note: For the 2.4-inch and 2.8-inch development boards, connect the temperature sensor to UART1-OUT. For other sizes, connect it to I2C-OUT.
IMG_256
IMG_256
Select version idf v5.1.1.
(Note: If you have previously installed other versions of IDF, you need to install version v5.1.1 first and then make the selection.)
Select the COM port to which the development board is connected and the model of the development board.
Click the "Compile" button and wait for the compilation to finish.
Click the "Flash" button after the compilation is completed.
Wait for the flashing process to complete.
IMG_256
You can observe the current temperature and humidity on the screen.
Kind Reminder:
Version 1.1/1.2 has been upgraded, optimizing the amplifier circuit for better sound quality and using only IO21 to control muting.
The i2s_mic is now controlled by two pins, IO9 and IO10.
