5.Port Introduction
Welcome to Lesson 5 of the CrowPanel ESP32 Advance HMI Series Tutorial, Port Introduction.
This lesson will use the IIC interface and UART1-OUT interface of this series of products to collect data from temperature and humidity sensors. When the temperature exceeds the threshold, the light bulb will automatically light up.
In this lesson, we will use the knowledge of LVGL graphics library from Lesson 3 to create an interactive interface.
1 Introduce product ports
1_2
2 Taking UART1-OUT interface and IIC-OUT as examples
Next, taking the external light bulb connected to the UART1-OUT interface and the temperature and humidity sensor connected to the IIC-OUT interface as an example. The temperature and humidity sensor needs to support IIC communication. The peripherals connected to the IIC interface are all like this.
In order to provide everyone with an intuitive observation, I will use LVGL to create an interactive interface.
1_4
Create Arduino project
1_5
If you are using a 2.8 / 2.4 inch product, please change the resolution to 320*240.
1_3
1_6
1_7
1_7_1
Click the link below to download the supporting images for this lesson.
Resource link:
CrowPanel-Advance-2.8-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-320x240/example/V1.1_and_V1.2/Arduino_Code/lesson-05/source material/320x240 at master · Elecrow-RD/CrowPanel-Advance-2.8-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-320x240
1_11
1_13
1_16
1_14
1_15
1_18
1_20
1_17
1_19
1_22
Click on Project Setting
1_24
Set the file export path and customize the path
1_21
But here, you need to create an Output folder in the path above to receive the exported UI files.
1_23
Fill in lvgl. h and select Flat export.
1_26
Finally confirm the settings
1_28
1_25
Go to the Output folder you just set up and copy the UI files you generated.
1_27
Paste it into the code file you need to open (here I will introduce the 3.5-size code as an example).
1_29
Then use Arduino IDE to open the ino file in the folder
1_30
3 Code Explanation
You can click the link below to download the corresponding version of the code for this lesson. Code link:
2.8-inch / 2.4-inch V1.0
https://github.com/Elecrow-RD/CrowPanel-Advance-2.8-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-320x240/tree/master/example/V1.0/Arduino_Code
2.8-inch / 2.4-inch V1.1/V1.2
https://github.com/Elecrow-RD/CrowPanel-Advance-2.8-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-320x240/tree/master/example/V1.1_and_V1.2/Arduino_Code
Introduce several key points in the code
Initialize UART1-OUT pin, IIC pin, and temperature and humidity sensor
1_33
Turn on the screen backlight to enable the screen to display
1_31
Previously, pin 18 was set as the output mode, and the UART1-OUT interface was connected to the light bulb. By controlling pin 18, the light can be controlled.
The brightness and darkness of bubbles.
1_32
Because the temperature and humidity sensor is connected to the IIC interface, it is necessary to initialize pins 15 and 16 of the IIC and initialize the temperature and humidity sensor.
1_34
And define two variables to receive data collected by temperature and humidity sensors
1_36
And display the value on the label you previously designed
1_38
1_35
1_37
If the temperature value collected by your temperature and humidity sensor exceeds 30 ℃, the light bulb will automatically light up; If the temperature drops below 30 ℃, the light bulb will automatically turn off. (You can modify the temperature threshold yourself, this is only for the convenience of observing the results)
If you are using the 2.4-inch or 2.8-inch model, you do not need to connect the LED to the UART1-OUT port. For these models, the UART1-OUT interface is reserved for the temperature and humidity sensor used in this project, so the LED is not connected. The reason for this hardware arrangement will be explained in the following section.
1_39
Special Reminder:
(The following applies only to 2.8-inch and 2.4-inch products)
If you are using the 2.8-inch or 2.4-inch version of the product, you need to pay special attention to the issue of IIC device address conflicts. The IIC address of the onboard touch driver chip is 0x38, and the default IIC address of the DHT20 temperature and humidity sensor is also 0x38. When you connect the DHT20 temperature and humidity sensor to the IIC-OUT interface, since both devices use the same IIC address, an address conflict will occur, resulting in the devices being unable to communicate normally. In this situation, the system will give priority to ensuring the normal operation of the touch driver chip. Therefore, the touch function will not be affected, but the DHT20 temperature and humidity sensor will be unable to read data properly. To solve this problem, we suggest connecting the DHT20 temperature and humidity sensor to the UART1-OUT interface for use. This will prevent IIC address conflicts and ensure that the temperature and humidity sensor can operate normally. Additionally, it is important to note that the UART1-OUT interface actually provides two GPIO pins (IO17 and IO18) that are available for user use. You can use them as regular GPIOs and connect some peripherals that only require one or two IO pins.
For example, when connecting an LED light, IO18 can be used as the control pin, and the on/off state of the light can be controlled by the program.
It should be noted that the UART1-OUT interface only provides two GPIO pins, namely IO17 and IO18. Therefore, it is only suitable for peripheral devices that occupy a relatively small amount of IO resources. If certain modules require the use of more GPIO pins, such as SPI devices which typically need multiple signal lines including SCK, MOSI, MISO and CS, then they cannot be directly connected and used through the UART1-OUT interface.
2.4" 2.8"
1_40
1_41
And when initializing the temperature and humidity sensor, specify the IIC pin used for initializing the temperature and humidity sensor.
Use Wire1 (GPIO17 for SDA and GPIO18 for SCL).
1_42
4 Hardware connection
For the 2.4-inch and 2.8-inch versions of the product, since there is an IIC address conflict between the onboard touch driver chip and the DHT20 temperature and humidity sensor, this tutorial uses the UART1-OUT interface to connect the DHT20 temperature and humidity sensor.
During actual use, we reconfigured IO17 and IO18 as IIC communication pins, with one serving as SDA (data line) and the other as SCL (clock line), thus enabling communication with the DHT20 temperature and humidity sensor. This not only ensures the normal operation of the touch function but also allows for the normal reading of temperature and humidity data.
image-20260604180051913
5 Configure the environment, upload code, and view phenomena
(Before uploading the code, please replace the relevant library files. Please refer to Lesson 1 for instructions on how to replace them.)
Configure the operating environment according to the guidance.
1_43
Upload code
1_46
Phenomenon display
image-20260604193252961
new-1
Library file link:
CrowPanel-Advance-2.4-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-320x240/example/V1.1_and_V1.2/Arduino_Code/libraries at master · Elecrow-RD/CrowPanel-Advance-2.4-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-320x240
