Lesson3 Use SquareLine Studio and LVGL libraries to create a UI interface to light the lights¶
Welcome to the third lesson of learning. I believe that after completing the last two lessons, everyone has gained a deeper understanding of our product. Next, I will lead you to the second application case of the Advance series products - Display the interface by calling LVGL technology and control the on - off state of the small light bulb.
1. Using previous preparations¶
For the 4.3-inch, 5.0-inch, and 7.0-inch development boards, connect the small light bulb to the UART1-OUT port.
For the development versions with screen sizes of 4.3-inch, 5.0-inch, and 7.0-inch, the function select keys should be set to 0 1.
2. Introduce LVGL¶
3. Install SquareLine Studio¶
3.1 Installation Guide¶
Download the version 1.4.0
Click install.
Wait for installation.
Installation finish.
3.2 Software Function Introduction¶
Open the software
Note:Please select the corresponding resolution and color depth according to the screen specifications.
①Toolbar, including File, Export, and Help. Basic file operation bar, create or open files, export UI files and other operations. Click help and there are related introductory documents.
②Screen bar, the project screen will be listed here.
③Widget area, all widgets are here and can be selected and used according to project needs.
④Hierarchy area, it will show every widget used in each screen.
⑤This area shows the actual display effect, you can adjust the widgets or screen here.
⑥Material column, the added materials are displayed here.
⑦Setting bar, where you can make basic settings for each part, including the basic attributes and trigger operations of the part.
⑧Theme bar, different themes can be set.
4. Use SquareLine Studio to create UI control interfaces¶
4.1 Create a new SquareLine Studio project.¶
Here, I take a 2.8-inch screen as an example. After determining the resolution, I fill it in.
If you are using the 4.3-inch, 5.0-inch, or 7.0-inch version of the product, you will need to set the display resolution to 800 × 480, according to the size comparison chart shown above.
Please note that this project uses the LVGL 8.3.11 version. Make sure to configure the correct LVGL version to ensure compatibility with the provided code and examples.
The images can be found at the following location:
Just use the pictures here.
The lamp-svg image size is available for both 2.4-inch and 2.8-inch screens.
The table_lamp image sizes are available for 3.5-inch, 4.3-inch, 5.0-inch, and 7-inch screens.
4.2 Add functions to the buttons to enable them to turn on and off lights¶
Select 'event' to add in the right sidebar.
After selecting, click ADD.
After adding, run
4.3 UI interface design completed, exporting UI files for easy use in subsequent code¶
Click on Project Setting
Set export path.
Complete the setup and export file.
Next, open the project folder provided for this course using VS Code. Then, copy the .h and .c files generated by LVGL into the corresponding ui folder of the project. You can download the complete project code from the link provided below.
5. Explanation of the code project¶
This project is developed and run on ESP-IDF version 5.5.4.
First, configure the required framework versions in the idf_component.yml file located in the main folder. This project is developed using ESP-IDF 5.5.4 and LVGL 8.3.11, so make sure the version settings in the file match these requirements or fall within the specified compatibility range. Doing so ensures that all dependencies are installed correctly and helps prevent compilation or compatibility errors.
This section uses macros to uniformly manage the hardware parameters and peripheral addresses of the I2C bus. The comments have masked the I2C channel number and bus frequency. These can be enabled by removing the comments later. Specifically, the I2C data line SDA pin 15 and the clock line SCL pin 16 have been clearly specified. The built-in I2C transceiver buffers have been disabled to reduce memory usage. Two fixed I2C slave device addresses 0x30 (touch / power amplifier control chip) and 0x5D (screen driver chip) have been defined. Through the use of macros to uniformly manage the hardware parameters, changing the wiring and changing the chip address only requires modifying this section, without the need to traverse the entire code.
This section completes the complete initialization of the ESP32 hardware I2C host. Firstly, the I2C configuration structure is defined, the working mode is set as the host, the preset SDA/SCL pins are bound, the internal pull-up resistors of the pins are enabled to ensure the stability of I2C levels, and the bus clock frequency is filled in. The i2c_param_config function is called to write the configuration to the specified I2C hardware channel, and then the i2c_driver_install function is called to install the I2C driver and close the receive and transmit buffers. The ESP_ERROR_CHECK function will catch initialization errors. In case of hardware exceptions, the program will directly trigger an error and restart to ensure that the I2C bus can communicate normally with the 0x30 and 0x5D peripherals.
This section encapsulates the native ESP-IDF I2C scanning logic, receives the address of the device to be detected, first creates an I2C instruction list, and successively adds the start signal, the device address with read/write bits, and the stop signal; execute the entire I2C instruction and set a 100-millisecond timeout; upon completion of the execution, release the instruction list; the function returns a boolean value. If the I2C receives an external device response and there is no error during execution, it returns true, indicating that the corresponding address chip exists. This is used for power-on self-check to determine whether the touch and screen chips are properly mounted.
This section encapsulates a general interface for sending a single-byte control command to the specified I2C peripheral. The input parameters are the target device address and the control data to be sent. An I2C command queue is created, and the start signal, device write address, single-byte control command, and stop signal are sent sequentially. A 100ms communication timeout is added to prevent the bus from getting stuck. After the communication is completed, the command memory is released, and the communication error code is returned for the upper layer to judge whether the command transmission was successful. The screen backlight switch, touch enable, and power amplifier switch are all issued I2C commands through this function.
This section is the sole entry point for the ESP-IDF standard program. After power-on, it completes the initialization of the entire hardware and the graphical interface in a fixed sequence: Firstly, it initializes the hardware I2C master and waits for 50ms for the peripherals to power up and stabilize; it then issues the 0xFA (250) command to the 0x30 chip to enable the touch function, and then issues 0 to turn on the screen backlight; changing the value to 245 will turn off the backlight; it resets the GPIO19 pin and configures it as an output mode for screen power / backlight auxiliary control; it calls the dedicated RGB screen initialization function of Microchip to complete the screen hardware driver, memory, and refresh timing configuration; it prints log messages via serial port to prompt the entry into the LVGL graphical interface process. The LVGL functions are not thread-safe, so it locks the graphic resources with a mutex lock, calls ui_init to load the custom UI interface generated in advance using the LVGL editor, and comments out the official music demo. After initialization is complete, the mutex lock is released, and the entire process is completed, allowing the custom GUI interface to be displayed on the screen.
Finally, if you want to control the LED connected to the UART1-OUT interface by tapping the On and Off buttons on the screen, you need to implement the callback functions defined in SquareLine Studio inside the ui_events.c file located in the ui folder under the main directory.
6. Compile and flash the code¶
Click the link below and you can access the code for this lesson.
Select the code folder for this lesson, right-click on it, and then choose to open it with VS Code.
Note:
Remember to prepare the hardware environment as per the first point of this course.
Then, following Step 5 “Run the program” from Lesson 1, upload and execute the code in the correct sequence.
Please proceed in the following order: 1 → 2 → 3 → 4 → 5 → 6 → 10
After completing Step 10, you will be able to see your LVGL interface displayed on the screen. In addition, tapping On will turn on the LED, while tapping Off will turn it off.
Kind Reminder:¶
You are currently viewing the 7-inch product of CrowPanel Advance HMI AI Display, and the version here is V1.3 / V1.4 / V1.5.
(For the 4.3-inch V1.1 / V1.2 / v1.3 version and the 5.0-inch V1.2 / v1.3 version, the following information also applies.)
In terms of hardware, we use a microcontroller (STC8H1K28) to control the screen backlight, speaker on/off, and buzzer.
Explanation:
0x30 is the I2C address of the microcontroller (STC8H1K28).
0x5D is the I2C address of the touch IC (GT911).
sendI2CCommand(0) means sending command 0 to the microcontroller (address 0x30) to instruct it to set the screen brightness to maximum.
For 0 mentioned above, you can replace it with the following values:
- 0 is the brightest backlight.
- 0 to 245: The screen brightness will gradually increase to the minimum value
- 245 represents turning off the screen light
Additional notes:
You can also control the following functions by sending other instructions to the microcontroller:
- It means sending the 248 command to the microcontroller (0x30) to instruct the speaker to turn on.
- It means sending the 249 command to the microcontroller (0x30) to instruct the speaker to turn off.
- You can also send command 246 to control the buzzer to turn on, and send command 247 to control the buzzer to turn off.
By writing the instruction 0x10 to the address 0x30 of the microcontroller, it is used to control the microcontroller.
