Lesson4 The temperature and humidity sensor receives data in real time
Welcome to the Lesson 4 of learning.
This lesson will use the IIC interface and of this series of products to collect data from temperature and humidity sensors. In this lesson, we will use the knowledge of LVGL graphics library from Lesson 3 to create an interactive interface.
1. Introduce product ports
This is the back view of the 3.5-inch V1.0 version.
This is the back view of the 3.5-inch V1.2 / V1.3 / v1.4 version.
1_1
2. UI interface design
The temperature and humidity sensor needs to support IIC communication.
In order to provide everyone with an intuitive observation, I will use LVGL to create an interactive interface.
IMG_258
Create "Espressif" project
image-20260623111826119
Note: For this lesson project, use LVGL v9.1.0 for 2.4-inch and 2.8-inch devices.
For 3.5-inch, 4.3-inch, 5.0-inch, and 7.0-inch devices, use LVGL v8.3.11.
image-20260623111943912
image-20260623112112408
If you are using the 3.5-inch version of the product, you will need to set the display resolution to 480 × 320, according to the size comparison chart shown above.
Please note that this project uses the LVGL 8.3.11 version. Make sure to configure the correct LVGL version to ensure compatibility with the provided code and examples.
IMG_261
image-20260623112449130
IMG_263
Here is the corresponding image asset download link for each screen size:
CrowPanel-Advance-3.5-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-480x320/example/V1.2_and_V1.3_and_V1.4/Arduino_Code/lesson-05/source material at master · Elecrow-RD/CrowPanel-Advance-3.5-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-480x320
image-20260623154939692
IMG_267
IMG_268
IMG_269
IMG_270
IMG_271
IMG_272
IMG_273
IMG_274
IMG_275
IMG_276
How to set the specific export path, please refer to the previous lesson.
IMG_282
Go to the folder path where you selected to output the UI file.
Click the link below and you can access the code for this lesson.
Code Link:
CrowPanel-Advance-3.5-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-480x320/example at master · Elecrow-RD/CrowPanel-Advance-3.5-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-480x320
image-20260623155212544
Next, open the project folder provided for this course using VS Code. Then, copy the .h and .c files generated by LVGL into the corresponding ui folder of the project.
image-20260623155350195
3. Hardware connection
Connect the temperature sensor to the development board and power on the development board.
Note: For the 2.4-inch and 2.8-inch development boards, connect the temperature sensor to UART1-OUT. For other sizes, connect it to I2C-OUT.
IMG_256
IMG_256
Special Reminder:(The following applies only to 2.8-inch and 2.4-inch products)
The IIC address of the 2.8 and 2.4 touch driver ICs is 0x38, and the IIC address of the DHT20 temperature and humidity sensor is also 0x38. When the DHT20 temperature and humidity sensor is connected to the IIC-OUT interface for use, the two addresses conflict, causing abnormal device usage. The DHT20 temperature and humidity sensor will no longer work, but will ensure the driving of the touch IC.
So in order to make the DHT20 temperature and humidity sensor work, we can connect the DHT20 temperature and humidity sensor to UART1-OUT.
Special note: The UART1-OUT interface allows the use of two or fewer IO interfaces, namely 17 and 18 pins, for your convenience. For example, when connecting a light bulb, 18 pins can be used to receive the initiated control signal. For example, doing digital input/output and analog input/output. There are also some infrared receivers, buzzers, and lights that can be connected. The premise is that you should not use more than 2 IO ports, such as SPI, which requires four IO ports to control and cannot be used.
4. Explanation of the code project
This project is developed and run on ESP-IDF version 5.5.4.
First, you need to specify the version of the arduino-esp32 component in the idf_component.yml file under the main folder. In this project, version 3.3.10 is used to ensure compatibility with ESP-IDF 5.5.4. After the configuration is completed, the ESP-IDF build system will automatically download and integrate the specified Arduino framework version during the first compilation.
This setup allows the project to combine the ESP-IDF development environment with the Arduino programming interface, enabling the use of Arduino-style APIs within an ESP-IDF-based project.
image-20260622180616854
This section creates two global instances. The gfx of type LGFX is a global object for screen driver, ensuring that the refresh callback, touch reading, and screen configuration functions can access the screen hardware; dht20 is a DHT20 temperature and humidity sensor object. The global scope allows the setup initialization and loop update functions to directly read the temperature and humidity data, eliminating the need to repeatedly create instances and thus avoiding resource waste.
image-20260623163315711
This section defines the screen resolution as 320 pixels wide and 480 pixels high. At the same time, it creates a double-row local refresh cache for LVGL. The "draw_buf" is the LVGL cache management structure, and "buf_1" and "buf_2" are two static memory blocks serving as drawing buffers. Each block of the cache has a width equal to the full screen width and a height of only 20 lines. It adopts the double-buffer local refresh mechanism to reduce the data transmission volume of the SPI screen and avoid screen tearing. The buffers are stored in the static memory area and do not occupy stack memory, thus preventing overflow.
image-20260623163359655
This section encapsulates the logic for reading and refreshing the LVGL text control with temperature and humidity data, defines a 6-byte character buffer to store the numeric string; reads the integer temperature and humidity values from the DHT20 sensor, converts the numbers to strings using snprintf and assigns them to the temperature label ui_TempLabel1 on the interface; after clearing the buffer using memset, converts the humidity value to a string and assigns it to the humidity label ui_HumiLabel2. Each call will synchronously update the numeric display of temperature and humidity on the screen.
image-20260623163440581
This section describes the standard one-time power-on initialization process for Arduino, which completes all hardware, sensor, and graphics system initialization in a fixed sequence:
  • Open the 115200 baud rate serial port, wait for the serial monitor to open and print the boot log;
  • Initialize the I2C bus with SDA=15, SCL=16, delay 50ms to wait for the I2C peripheral to power up and stabilize, then start the DHT20 temperature and humidity sensor;
  • Configure GPIO38 as the backlight output pin. When powering on, first pull it low to turn off the backlight to avoid screen flickering during the initialization stage;
  • Start the LovyanGFX screen hardware, set the screen rotation angle to 0 and the screen brightness to 128. After initialization is complete, pull up pin 38 to light up the backlight;
  • Initialize the LVGL kernel, bind the double-line drawing buffer;
  • Register the LVGL display driver, associate screen resolution, refresh callback and cache;
  • Load the LVGL visual design interface ui_init, print the log of system initialization completion, and all hardware and GUI environment are ready.
image-20260623163551194
This section is the main body of the program's infinite loop. In each round of the loop, the humidity and temperature update function is called first to read the sensor data and refresh the screen text; then, the lv_timer_handler is executed to handle the internal logic of LVGL, including interface animations, touch detection, screen refresh, and control event responses, which are necessary calls for the normal operation of LVGL; along with a 5ms delay to release the computing power of the MCU and reduce CPU usage.
image-20260623163624404
5. Compile and flash the code
Code Link: CrowPanel-Advance-3.5-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-480x320/example at master · Elecrow-RD/CrowPanel-Advance-3.5-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-480x320
image-20260623163750370
Select the code folder for this lesson, right-click on it, and then choose to open it with VS Code.
Note:
Remember to prepare the hardware environment as per the first point of this course.
Then, following Step 5 “Run the program” from Lesson 1, upload and execute the code in the correct sequence.
Please proceed in the following order: 1 → 2 → 3 → 4 → 5 → 6 → 10
IDF_01_Image_01
You can observe the current temperature and humidity on the screen.
