Lesson4 The temperature and humidity sensor receives data in real time
Welcome to the Lesson 4 of learning.
This lesson will use the IIC interface and of this series of products to collect data from temperature and humidity sensors. In this lesson, we will use the knowledge of LVGL graphics library from Lesson 3 to create an interactive interface.
1 Introduce product ports
2 UI interface design
The temperature and humidity sensor needs to support IIC communication. In order to provide everyone with an intuitive observation, I will use LVGL to create an interactive interface.
IMG_258
Create Espressif project
Note: Use version 9.1.0 for small-sized items, and use version 8.3.11 for large-sized items.
IMG_261
IMG_263
Here is the corresponding image asset download link for each screen size:
IMG_265
IMG_266
IMG_267
IMG_268
IMG_269
IMG_270
IMG_271
IMG_272
IMG_273
IMG_274
IMG_275
IMG_276
IMG_282
Go to the folder path where you selected to output the UI file.
Click the link below and you can access the code for this lesson.
Code Link:
CrowPanel-Advance-5-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-800x480/example/V1.2/IDF_Code/lesson_4_DHT_screen_4.3_5.0_7.0 at master · Elecrow-RD/CrowPanel-Advance-5-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-800x480
Then use VSCode to open the IDF project folder. Copy the generated .h and .c files into the corresponding folders of the project. (Here, I will use the code for the 5.0-inch version as an example.)
3 Hardware connection
Connect the temperature sensor to the development board and power on the development board.
Note: For the 2.4-inch and 2.8-inch development boards, connect the temperature sensor to UART1-OUT. For other sizes, connect it to I2C-OUT.
IMG_256
IMG_256
Select version idf v5.1.1.
(Note: If you have previously installed other versions of IDF, you need to install version v5.1.1 first and then make the selection.)
Select the COM port to which the development board is connected and the model of the development board.
Click the "Compile" button and wait for the compilation to finish.
Click the "Flash" button after the compilation is completed.
Wait for the flashing process to complete.
IMG_256
You can observe the current temperature and humidity on the screen.
Kind Reminder:
You are currently viewing the 7-inch product of CrowPanel Advance HMI, and the version here is V1.3.
(For the 4.3-inch V1.1 version and the 5.0-inch V1.2 version, the following information also applies.)
In terms of hardware, we use a microcontroller (STC8H1K28) to control the screen backlight, speaker on/off, and buzzer.
Explanation:
  • 0x30 is the I2C address of the microcontroller (STC8H1K28).
  • 0x5D is the I2C address of the touch IC (GT911).
  • sendI2CCommand(0) means sending command 0 to the microcontroller (address 0x30) to instruct it to set the screen brightness to maximum.
For 0 mentioned above, you can replace it with the following values:
  • 0 is the brightest backlight.
  • 0 to 245: The screen brightness will gradually increase to the minimum value
  • 245 represents turning off the screen light
Additional notes:
You can also control the following functions by sending other instructions to the microcontroller:
  • It means sending the 248 command to the microcontroller (0x30) to instruct the speaker to turn on.
  • It means sending the 249 command to the microcontroller (0x30) to instruct the speaker to turn off.
  • You can also send command 246 to control the buzzer to turn on, and send command 247 to control the buzzer to turn off.
