7.0” 800*480 IPS Display 16BIT Parallel LCD Module| SSD1963 Driver |Capacitive Touch
This 7.0-inch module is equipped with an IPS screen, provides a high resolution of 800x480, supports 16BIT RGB 65K color display, and can present colorful and delicate images and text.
This display has a capacitive touchscreen that provides accurate and flexible touch response.
Its 16-bit parallel bus design ensures the high speed and stability of data transmission, improving system response and operation efficiency.
The module supports SPI FLASH and SD card expansion, providing users with a flexible storage solution to meet the requirements of different projects.
It also supports two backlight control methods: GPIO and PWM control. Users can choose according to specific requirements to balance energy efficiency and functionality.
No matter you are a beginner or an experienced developer, you can quickly get started and easily start your project development journey.
We provide rich example learning programs, covering a variety of mainstream development platforms such as STM32 and C51.
We also provide underlying driver technology support, making it ideal for applications in intelligent hardware development and industrial automation applications.
This 7.0-inch module offers a stable, efficient, and convenient display solution, perfect for your development needs.
Customized requests can be discussed(based on MOQ), you can contact us at service@elecrow.com
Model DLP34070B
feature_of_7.0inch_capacitive_parallel_display
  • 7.0-inch color screen, supporting 16-bit RGB 65K color with rich display colors
  • IPS screen with 800x480 resolution
  • Capacitive touch supports a sensitive response
  • Using 16-bit parallel bus transmission with a fast transfer speed
  • Support SPI flash
  • With SD card slot for easy storage expansion
  • Support two backlight control modes (GPIO control, PWM control)
  • Provides a rich sample program for STM32 and C51 platforms
  • Provide underlying driver technical support
Screen Size 7.0(inch)
Display Color 16BIT RGB 65K color
Screen Type IPS TFT
Resolution 800x480(pixels)
Touch Screen Type Capacitive touch screen
Driver IC SSD1963
Touch IC GT911
Module Interface 16Bit parallel interface
Operating Voltage 5V
IO Voltage 3.3V
Operating Temperature -10℃~60℃
Storage Temperature -20℃~70℃
Active Area 154.08x85.92(mm)
Module PCB Size 181.00x108.00(mm)
size_of_7.0inch_capacitive_parallel_display
ESP32 Pin Assignment
Number Pin Name Pin Name
1 GND power ground pin
2 EX_3.3V Power input pin (connected to 3.3V), not used
3 NC Undefined, reserved
4 RS LCD register / data selection control pin (high level: register, low level: data)
5 WR LCD write control pin
6 RD LCD read control pin
7~14 DB8 ~ DB15 LCD data bus high 8-bit pin
15 CS LCD reset control pin( low level enable)
16 F_CS SPI FLASH chip select control pin( low level enable)
17 REST LCD reset control pin( low level reset)
18 5V Power input pin (connected to 5V)
19 LED_A LCD backlight control pin(it needs to be used according to the selection)
20 NC/INT Used as interrupt pin
21~28 DB0~DB7 LCD data bus low 8-bit pin
29 T_CLK No definition
30 T_CS No definition
31 T_DIN No definition
32 NC/CRT Used as reset pin when connected to capacitive touch screen (low level reset)
33 T_DO No definition
34 T_IRQ No definition
35 SD_DO SD card SDIO bus read data pin
36 SD_CLK SD card SDIO bus clock pin
37 SD_DIN SD card SDIO bus write data pin
38 SD_CS SD card pin selection (low level enable)
39 NC/SDA Used as IIC bus data pin
40 NC/SCL Used as IIC bus clock pin
Resources
How to buy
Please visit this page to purchase 7.0” 800*480 IPS Display 16BIT Parallel LCD Module.
Support
