Lesson4 The temperature and humidity sensor receives data in real time¶
Welcome to the Lesson 4 of learning.
This lesson will use the IIC interface and of this series of products to collect data from temperature and humidity sensors. In this lesson, we will use the knowledge of LVGL graphics library from Lesson 3 to create an interactive interface.
1 Introduce product ports¶
2 UI interface design¶
The temperature and humidity sensor needs to support IIC communication. In order to provide everyone with an intuitive observation, I will use LVGL to create an interactive interface.
Create Espressif project
Note: Use version 9.1.0 for small-sized items, and use version 8.3.11 for large-sized items.
Here is the corresponding image asset download link for each screen size:
- 320*240:https://www.elecrow.com/download/product/CrowPanel/ESP32-HMI/2.4-DIS03024H/Arduino-Tutorial/ESP32-LVGL-Assets-2.4.zip
 - 480*320:https://www.elecrow.com/download/product/CrowPanel/LVGL-Assets-480x320.zip
 - 800*480:https://www.elecrow.com/download/product/CrowPanel/LVGL-Assets-800x480.zip
Go to the folder path where you selected to output the UI file.
Download the files for lesson 4 from https://drive.google.com/drive/folders/1hEXyH14QeDgVdENxUfiYBQVCTbMbI6v9 and extract them, as shown below:
Then use VSCode to open the IDF project folder. Copy the generated .h and .c files into the corresponding folders of the project. (Here, I will use the code for the 3.5-inch version as an example.)
3 Code Explanation¶
Introduce several key points in the code
Screen refresh callback function
Touch coordinate reading function
Function for Displaying Data of DHT20 Temperature Sensor
Initialization function, which initializes each functional module.
Refresh the screen regularly.
4 Hardware connection¶
Connect the temperature sensor to the development board and power on the development board.
Note: For the 2.4-inch and 2.8-inch development boards, connect the temperature sensor to UART1-OUT. For other sizes, connect it to I2C-OUT.
Select version idf v5.1.6. (Note: If you have previously installed other versions of IDF, you need to install version v5.1.6 first and then make the selection.)
Select the COM port to which the development board is connected and the model of the development board.
Click the "Compile" button and wait for the compilation to finish.
Click the "Flash" button after the compilation is completed.
Wait for the flashing process to complete.
You can observe the current temperature and humidity on the screen.
Version 1.2 Key Points.¶
Version 1.2 updated the control of backlight on the basis of the original, the backlight of version 1.2 is controlled by STC8H1K28 microcontroller, and the backlight is lit in the program by sending the value to this microcontroller address (0x30). The values are 0x05, 0x06, 0x07, 0x08, 0x09 and 0x10, where 0x05 switches off the backlight and 0x10 is the maximum brightness.
When the main program is running, you need to query the i2c address all the time to prevent the microcontroller from not starting to adjust the bright screen.
The function code for data transfer is as follows, as well as the code in the main program for how to send the value to light the backlight.
