Lesson4 The temperature and humidity sensor receives data in real time¶
Welcome to the fifth lesson of learning.
This lesson will use the IIC interface and of this series of products to collect data from temperature and humidity sensors. In this lesson, we will use the knowledge of LVGL graphics library from Lesson 3 to create an interactive interface.
1 Introduce product ports¶
2 UI interface design¶
The temperature and humidity sensor needs to support IIC communication. In order to provide everyone with an intuitive observation, I will use LVGL to create an interactive interface.
Create Espressif project
Note: Use version 9.1.0 for small-sized items, and use version 8.3.11 for large-sized items.
Go to the folder path where you selected to output the UI file.
Copy the generated.h and.c files into the corresponding folders of the project (here I will take the code for the 3.5-size as an example).
Then use vscode to open the idf Project folder
3 Code Explanation¶
Introduce several key points in the code
Screen refresh callback function
Touch coordinate reading function
Function for Displaying Data of DHT20 Temperature Sensor
Initialization function, which initializes each functional module.
Refresh the screen regularly.
4 Hardware connection¶
Connect the temperature sensor to the development board and power on the development board.
Note: For the 2.4-inch and 2.8-inch development boards, connect the temperature sensor to UART1-OUT. For other sizes, connect it to I2C-OUT.
Select version idf v5.1.6. (Note: If you have previously installed other versions of IDF, you need to install version v5.1.6 first and then make the selection.)
Select the COM port to which the development board is connected and the model of the development board.
Click the "Compile" button and wait for the compilation to finish.
Click the "Flash" button after the compilation is completed.
Wait for the flashing process to complete.
