ESP32 HMI 7.0-inch Arduino Tutorial¶
Overview¶
Hardware Preparation¶
CrowPanel ESP32 7.0'' HMI | Crowtail-DHT20 | Crowtail-LED |
Please click to download the demo for "Example Demonstration" section in "Get Started with SquareLine Studio".
Open the SquareLine Studio and create a project.
A. In the latest version of SLS, select "Elecrow"->"DIS08070H...Arduino-IDE"
B. In the earlier version of SLS, select "Arduino"->"Arduino with TFT_eSPI".
Note:
Set the name of the project, set the screen resolution to 800*480, set the color depth to 16bit, and keep other default settings. After setting, click CREATE to create the project.
Please click
to download the custom images used in this tutorial.
Note:
Add background.
Add events to buttons.
Export UI files.
Then click "APPLY CHANGES".
Please click
to download the main program(and the expert UI is included).
Modify the button event code.
First, define an extern variable in the ui.h file to store the status of the LED. In the main program, the LED light is controlled to turn on and off by judging the status of this variable.
When button 1 (ON button) is pressed, set the LED value to 1.
When button 2 (OFF button) is pressed, set the LED value to 0.
Build the Project with Arduino IDE¶
Get Started with Arduino IDE¶
Install Libraries¶
#include <PCA9557.h>
#include <lvgl.h>
#include <Crowbits_DHT20.h>
#include <LovyanGFX.hpp>
#include <lgfx/v1/platforms/esp32s3/Panel_RGB.hpp>
#include <lgfx/v1/platforms/esp32s3/Bus_RGB.hpp>
#include <SPI.h>
#include <Adafruit_GFX.h>
#include "ui.h"
: This library is designed for the PCA9557 I2C LED driver, which allows you to control the brightness of multiple leds via I2C communication.#include <lvgl.h>
: Library for UI interaction#include <Crowbits_DHT20.h>
: to read data from the DHT20 temperature and humidity sensor.#include <LovyanGFX.hpp>
: The LovyanGFX library is a library for drawing graphics on embedded systems, providing rich graphics functions and APIs.lgfx/v1/platforms/esp32s3/Panel_RGB.hpp
andlgfx/v1/platforms/esp32s3/Bus_RGB.hpp
: These two libraries are part of the LovyanGFX library, specifically for driving RGB color panels on ESP32-S3 microcontrollers. Panel_RGB.hpp provides functions for communicating with RGB panels, while Bus_RGB.hpp provides functions for communicating with RGB buses, which are often used to control devices such as LCD screens.#include <SPI.h>
: Screen driven library.#include <Adafruit_GFX.h>
: The Adafruit_GFX library is a graphics library provided by Adafruit for drawing graphics on various display devices.#include "ui.h"
: is a custom header file that contain UI-related functions or definitions.
Please click to download the libraries we modified.
Tips:
- If you install the lvgl libraries by Library Manager, you need to copy the demos folder and examples folder and paste them to src folder. And modify the lv_conf_template.h file and rename it to lv_conf.h, and place it in libraries folder.(Please refer to the library provided)
Code Explanation¶
Basic Definition
LGFX class, which is a subclass of lgfx::LGFX_Device. The main function is to configure and initialize an RGB color panel, and then connect it to the RGB bus on the ESP32-S3 microcontroller to display graphics on the panel.
class LGFX : public lgfx::LGFX_Device { public: lgfx::Bus_RGB _bus_instance; lgfx::Panel_RGB _panel_instance; LGFX(void) { { auto cfg = _bus_instance.config(); cfg.panel = &_panel_instance; cfg.pin_d0 = GPIO_NUM_15; // B0 cfg.pin_d1 = GPIO_NUM_7; // B1 cfg.pin_d2 = GPIO_NUM_6; // B2 cfg.pin_d3 = GPIO_NUM_5; // B3 cfg.pin_d4 = GPIO_NUM_4; // B4 cfg.pin_d5 = GPIO_NUM_9; // G0 cfg.pin_d6 = GPIO_NUM_46; // G1 cfg.pin_d7 = GPIO_NUM_3; // G2 cfg.pin_d8 = GPIO_NUM_8; // G3 cfg.pin_d9 = GPIO_NUM_16; // G4 cfg.pin_d10 = GPIO_NUM_1; // G5 cfg.pin_d11 = GPIO_NUM_14; // R0 cfg.pin_d12 = GPIO_NUM_21; // R1 cfg.pin_d13 = GPIO_NUM_47; // R2 cfg.pin_d14 = GPIO_NUM_48; // R3 cfg.pin_d15 = GPIO_NUM_45; // R4 cfg.pin_henable = GPIO_NUM_41; cfg.pin_vsync = GPIO_NUM_40; cfg.pin_hsync = GPIO_NUM_39; cfg.pin_pclk = GPIO_NUM_0; cfg.freq_write = 15000000; cfg.hsync_polarity = 0; cfg.hsync_front_porch = 40; cfg.hsync_pulse_width = 48; cfg.hsync_back_porch = 40; cfg.vsync_polarity = 0; cfg.vsync_front_porch = 1; cfg.vsync_pulse_width = 31; cfg.vsync_back_porch = 13; cfg.pclk_active_neg = 1; cfg.de_idle_high = 0; cfg.pclk_idle_high = 0; _bus_instance.config(cfg); } { auto cfg = _panel_instance.config(); cfg.memory_width = 800; cfg.memory_height = 480; cfg.panel_width = 800; cfg.panel_height = 480; cfg.offset_x = 0; cfg.offset_y = 0; _panel_instance.config(cfg); } _panel_instance.setBus(&_bus_instance); setPanel(&_panel_instance); } }; LGFX lcd;//
```c /* (1) The LGFX class inherits from lgfx::LGFX_Device, which means it will inherit the member variables and methods defined in LGFX_Device. (2) In the constructor of the LGFX class, we first create an instance of _bus_instance for lgfx::Bus_RGB and an instance of _panel_instance for lgfx::Panel_RGB. (3) Next, initialize the RGB bus and RGB panel by configuring the parameters of these two instances. In this code, data pins for each color are set, as well as some parameters related to synchronization signals and clocks, to ensure the correct transmission and display of data. (4) The configuration of _bus_instance and _panel_instance is based on their respective configuration objects, which are lgfx::Bus_RGB::config_t and lgfx::Panel_RGB::config_t. (5) Finally, set the bus used by the panel by calling _panel_instance.setBus(&_bus_instance), and then call setPanel(&_panel_instance) to set the panel as the panel of the current device. (6) Finally, a global LGFX object lcd was created for graphical drawing operations using this configured panel elsewhere. */
Define backlight pins, led variables, and screen resolution parameters. And include touch driver.
Define a buffer variable to initialize the display driver of LVGL and prepare a buffer to store pixel data that will be rendered to the screen. The size of this buffer should be around 1/10 of the product of screen pixel values, which can balance the main control performance and the smoothness of screen display. Taking 15 as an example, the display will be smoother.
Initialize temperature and humidity sensors and an instance of SPI library
Function
Screen refresh function, this code is for the refresh function driven by the display in the LittlevGL (LVGL) graphics library. LVGL is an open-source graphics library for embedded systems, used to create graphical user interfaces (GUIs). This function my_disp_flush is a user-defined callback function used to refresh the content of the graphical interface onto the display device.
/* Display flushing */ void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p) { uint32_t w = (area->x2 - area->x1 + 1); uint32_t h = (area->y2 - area->y1 + 1); //lcd.fillScreen(TFT_WHITE); #if (LV_COLOR_16_SWAP != 0) lcd.pushImageDMA(area->x1, area->y1, w, h,(lgfx::rgb565_t*)&color_p->full); #else lcd.pushImageDMA(area->x1, area->y1, w, h,(lgfx::rgb565_t*)&color_p->full);// #endif lv_disp_flush_ready(disp); }
A simple touch input device reading function, which is used to convert touch events into the input device data format required by the LVGL library, and output the coordinate information of touch points through serial communication.
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data) { if (touch_has_signal()) { if (touch_touched()) { data->state = LV_INDEV_STATE_PR; /*Set the coordinates*/ data->point.x = touch_last_x; data->point.y = touch_last_y; Serial.print( "Data x " ); Serial.println( data->point.x ); Serial.print( "Data y " ); Serial.println( data->point.y ); } else if (touch_released()) { data->state = LV_INDEV_STATE_REL; } } else { data->state = LV_INDEV_STATE_REL; } delay(15); }
Set Up Part
Serial.begin( 115200 ); /*Initializing the Serial Port*/
Serial2.begin( 9600 ); /*Initialize Serial Port 2*/
//IO Port Pins
pinMode(38, OUTPUT);
digitalWrite(38, LOW);
//initialization of DHT20 pins(I2C)
Wire.begin(19, 20);
dht20.begin();
lv_init(); // LVGL initialization
lcd.begin();
lcd.fillScreen(TFT_BLACK);
delay(300);
lv_init()
delay(100);
touch_init();// Touch initialization
/*Obtain the width and height of the screen, and initialize the drawing buffer.*/
screenWidth = lcd.width();
screenHeight = lcd.height();
lv_disp_draw_buf_init(&draw_buf, disp_draw_buf, NULL, screenWidth * screenHeight / 15);
// lv_disp_draw_buf_init(&draw_buf, disp_draw_buf, NULL, 480 * 272 / 10);
/* Initialize the display */
lv_disp_drv_init(&disp_drv);
/* Change the following line to your display resolution */
/* Initialize the (dummy) input device driver */
static lv_indev_drv_t indev_drv;//Define the input device driver structure
lv_indev_drv_init( &indev_drv );//Initialize the input device driver
indev_drv.type = LV_INDEV_TYPE_POINTER;//Setting the input device type
indev_drv.read_cb = my_touchpad_read;//Define the read callback function
lv_indev_drv_register( &indev_drv );//Registering Input Device Drivers
//Backlight settings
#ifdef TFT_BL
//digitalWrite(TFT_BL, HIGH);
ledcSetup(1, 300, 8);
ledcAttachPin(TFT_BL, 1);
ledcWrite(1, 255); /* Screen brightness can be modified by adjusting this parameter. (0-255) */
#endif
#ifdef TFT_BL
pinMode(TFT_BL, OUTPUT);
digitalWrite(TFT_BL, LOW);
delay(500);
#endif
// UI initialization
ui_init();
lv_timer_handler();
Main Program Part
/*① obtain temperature and humidity data and store it in a char array. First, use two integer variables a and b to store the obtained temperature and humidity separately*/
char DHT_buffer[6];
int a = (int)dht20.getTemperature();
int b = (int)dht20.getHumidity();
/*Then store the values in the array and display them on the label label through conversion*/
/*To determine the value of the LED, in the ui. c program, press the "ON" button to set the LED to 1, and control the LED light to turn on.*/
if(led == 1)
digitalWrite(38, HIGH);
/*In the ui. c program, press the "OFF" button to set the LED to 0, and at this time, control the LED to turn off.*/
if(led == 0)
lv_timer_handler(); /* let the GUI do its work, only by executing this function can the entire animation run. */
delay( 10 );
Upload the Code¶
After completing the installation of the ESP32 board according to "Get Started with Arduino IDE" and the installation of the library according to "Install Libraries", open the program and connect the ESP32 HMI 5.0-inch to the computer via a USB-C cable.
Select Board: click "Tools" -> "Board" -> "esp32" and select "ESP32S3 Dev Module"
Board Setting: Under the "Tools" menu, see "Flash Size" select 4MB(32Mb); "Partition scheme" and select "Huge APP(3MB No OTA/1MB SPIFFS)"; "PSRAM" select "OPI PSRAM"
Select Port
Upload the code: click the "Upload" icon to upload the code.
After the program is successfully uploaded, connect the DHT20 sensor to the IIC port and the LED to GPIO_D (IO38), the temperature and humidity values will be displayed on the screen. Click the ON button on the screen and the LED will turn on. Click the OFF button and the LED will turn off.
Example Demo of ESP32 HMI Function¶
Note:
The library used in this section is in the compressed package of the library downloaded above.
Example1: LED blinking.¶
Connect the LED to GPIO_D(IO38) port, and upload the following code to the board. The LED will blinking.
#define D_PIN 38
Serial.begin(115200);
pinMode(D_PIN, OUTPUT);
digitalWrite(D_PIN, HIGH);
delay(500);
digitalWrite(D_PIN, LOW);
delay(500);
Example2: Play music¶
Plug the speaker into SPK port. Please check if you have installed the library ESP32-audioI2S(Copy the ESP32-audioI2S-master folder in the libraries downloaded above to the .../arduino/libraries directory). Upload the following code to the board.
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <FS.h>
#include "Audio.h"
Audio audio;
#define I2S_DOUT 17
#define I2S_BCLK 42
#define I2S_LRC 18
//7.0
#define SD_MOSI 11
#define SD_MISO 13
#define SD_SCK 12
#define SD_CS 10
Serial.begin( 9600 ); /*Initialize the serial port*/
pinMode(SD_CS, OUTPUT); digitalWrite(SD_CS, HIGH);
SPI.begin(SD_SCK, SD_MISO, SD_MOSI);
SPI.setFrequency(1000000);
SD.begin(SD_CS);
audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
audio.setVolume(21); // 0...21
audio.connecttoFS(SD, "/123.mp3");
audio.loop();
//audio.stopSong();//close
Example3: Initialize SD Card slot¶
Please install the SD library and FS library. Upload the following code to the board.
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <FS.h>
//7.0
#define SD_MOSI 11
#define SD_MISO 13
#define SD_SCK 12
#define SD_CS 10
//SD card
delay(100);
if (SD_init() == 1)
Serial.println("Card Mount Failed");
else
Serial.println("initialize SD Card successfully");
//Initialize the SD Card
int SD_init()
if (!SD.begin(SD_CS))
return 1;
uint8_t cardType = SD.cardType();
if (cardType == CARD_NONE)
Serial.println("No TF card attached");
return 1;
uint64_t cardSize = SD.cardSize() / (1024 * 1024);
Serial.printf("TF Card Size: %lluMB\n", cardSize);
listDir(SD, "/", 2);
// listDir(SD, "/", 0);
// createDir(SD, "/mydir");
// removeDir(SD, "/mydir");
// listDir(SD, "/", 2);
// writeFile(SD, "/hello.txt", "Hello ");
// appendFile(SD, "/hello.txt", "World!\n");
// readFile(SD, "/hello.txt");
// Serial.printf("Total space: %lluMB\n", SD.totalBytes() / (1024 * 1024));
// Serial.printf("Used space: %lluMB\n", SD.usedBytes() / (1024 * 1024));
// Serial.println("SD init over.");
return 0;
//Traverse the SD card directory
void listDir(fs::FS & fs, const char *dirname, uint8_t levels)
// Serial.printf("Listing directory: %s\n", dirname);
File root = fs.open(dirname);
if (!root)
//Serial.println("Failed to open directory");
return;
if (!root.isDirectory())
Serial.println("Not a directory");
return;
File file = root.openNextFile();
// i = 0;
while (file)
if (file.isDirectory())
Serial.print(" DIR : ");
Serial.println(file.name());
if (levels)
listDir(fs, file.name(), levels - 1);
else
Serial.print("FILE: ");
Serial.print(file.name());
// lcd.setCursor(0, 2 * i);
// lcd.printf("FILE:%s", file.name());
Serial.print("SIZE: ");
Serial.println(file.size());
// lcd.setCursor(180, 2 * i);
// lcd.printf("SIZE:%d", file.size());
// i += 16;
Example4: Initialize the touch¶
Please check if you have install the library GT911(Copy the gt911 folder in the libraries downloaded above to the .../arduino/libraries directory).
And put the touch.h file in the same directory as the program, as shown below
Upload the following code to the board, and open the serial monitor to check the touch information.
#include "touch.h"
touch_init();
Serial.print( "Data x :" );
Serial.println( touch_last_x );
Serial.print( "Data y :" );
Serial.println( touch_last_y );
Example5: Initialize the interact communication of Bluetooth¶
Please check if you have installed the library BLE(Copy the BLE folder in the libraries downloaded above to the .../arduino/libraries directory). Upload the following code to the board, and use the phone to search the Bluetooth device.
#include "BLEDevice.h" //BLE drive library
#include "BLEServer.h" //BLE server library
#include "BLEUtils.h" //BLE Utility library
#include "BLE2902.h" //Feature Add Descriptor Library
#include <BLECharacteristic.h> //BLE Feature function library
BLEAdvertising* pAdvertising = NULL;
BLEServer* pServer = NULL;
BLEService *pService = NULL;
BLECharacteristic* pCharacteristic = NULL;
#define bleServerName "ESP32SPI-BLE" //BLE Server name
#define SERVICE_UUID "6479571c-2e6d-4b34-abe9-c35116712345" //Server UUID
#define CHARACTERISTIC_UUID "826f072d-f87c-4ae6-a416-6ffdcaa02d73"
bool connected_state = false; //Create device connection identifier
class MyServerCallbacks: public BLEServerCallbacks //Create connection and disconnection calling classes
void onConnect(BLEServer *pServer)//Start connecting function
connected_state = true; //Device is connected correctly
void onDisconnect(BLEServer *pServer)//disconnect function
connected_state = false; //Device connection error
//BLE
BLEDevice::init(bleServerName); //Create BLE and set name
pServer = BLEDevice::createServer(); //Create BLE server
pServer->setCallbacks(new MyServerCallbacks()); //Set up connection and disconnection calling classes
pService = pServer->createService(SERVICE_UUID); //Create BLE service
pCharacteristic = pService->createCharacteristic( //Create ble feature(Characterristic_UUID)
CHARACTERISTIC_UUID,
BLECharacteristic::PROPERTY_READ | BLECharacteristic::PROPERTY_WRITE | BLECharacteristic::PROPERTY_NOTIFY);
pCharacteristic->setValue("ELECROW");
//start broadcast
pAdvertising = BLEDevice::getAdvertising(); //A bleadvertising class pointer padvertising is defined, which points to bledevice:: getadvertising()
pAdvertising->addServiceUUID(SERVICE_UUID);
pAdvertising->start(); //Start broadcasting
pService->start();
// pAdvertising->stop(); //Stop broadcasting
// pService->stop(); //Stop service
Example6: Initialize the WIFI¶
Please check if you have installed the library WiFi(Copy the WiFi folder in the libraries downloaded above to the .../arduino/libraries directory). Upload the following code to the board.
#include <WiFi.h>
const char *ssid = "elecrow888"; //Change to your SSID
const char *password = "elecrow2014"; //Change to your password
WiFi.begin(ssid, password);
WiFi.setAutoReconnect(true);//Set up automatic reconnection
delay(100);
Serial.println("connecting");
Serial.println("WiFi is connected.");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
// WiFi.disconnect();
Example7: Connect Crowtail-GPS module via UART to Get Location¶
Connect the Crowtail-GPS to the UART port.
//at 9600 bps 8-N-1
#include <SoftwareSerial.h>
SoftwareSerial SoftSerial(44, 43);
unsigned char buffer[256]; // buffer array for data recieve over serial port
int count=0; // counter for buffer array
SoftSerial.begin(9600); // the SoftSerial baud rate
Serial.begin(9600); // the Serial port of Arduino baud rate.
if (SoftSerial.available()) // if date is comming from softwareserial port ==> data is comming from SoftSerial shield
while(SoftSerial.available()) // reading data into char array
buffer[count++]=SoftSerial.read(); // writing data into array
if(count == 256)break;
Serial.write(buffer,count); // if no data transmission ends, write buffer to hardware serial port
clearBufferArray(); // call clearBufferArray function to clear the storaged data from the array
count = 0; // set counter of while loop to zero
if (Serial.available()) // if data is available on hardwareserial port ==> data is comming from PC or notebook
SoftSerial.write(Serial.read()); // write it to the SoftSerial shield
void clearBufferArray() // function to clear buffer array
for (int i=0; i<count;i++)
{ buffer[i]=NULL;} // clear all index of array with command NULL
