ESP32 HMI 4.3-inch Arduino Tutorial¶
Overview¶
This example tutorial is a project for controlling the on and off of an LED. It demonstrates how to create a UI and how to control the on and off of an LED through buttons on the screen.
Hardware Preparation¶
CrowPanel ESP32 4.3'' HMI | Crowtail-DHT20 | Crowtail-LED |
Please click to download the demo for "Example Demonstration" section in "Get Started with SquareLine Studio".
Open the SquareLine Studio and create a project.
A. In the latest version of SLS, select "Elecrow"->"DIS06043H...Arduino-IDE"
B. In the earlier version of SLS, select "Arduino"->"Arduino with TFT_eSPI".
Note:
Set the name of the project, set the screen resolution to 480*272, set the color depth to 16bit, and keep other default settings. After setting, click CREATE to create the project.
Please click
to download the custom images used in this tutorial.
Note:
Add background.
Add events to buttons.
Export UI files.
Then click "APPLY CHANGES".
Please click
to download the main program(and the expert UI is included).
Modify the button event code.
First, define an extern variable in the ui.h file to store the status of the LED. In the main program, the LED light is controlled to turn on and off by judging the status of this variable.
When button 1 (ON button) is pressed, set the LED value to 1.
When button 2 (OFF button) is pressed, set the LED value to 0.
Build the Project with Arduino IDE¶
Get Started with Arduino IDE¶
Install Libraries¶
#include <lvgl.h>
#include <SPI.h>
#include <Arduino_GFX_Library.h>
#include "ui.h"
#include "touch.h"
#include <lvgl.h>
: library for graphical interfaces.#include <Arduino_GFX_Library.h>
: library for screen drivetouch.h
: touch drive.#include "ui.h"
: is a custom header file that contain UI-related functions or definitions.
Please click to download the libraries we modified.
Tips:
- If you install the lvgl libraries by Library Manager, you need to copy the demos folder and examples folder and paste them to src folder. And modify the lv_conf_template.h file and rename it to lv_conf.h, and place it in libraries folder.(Please refer to the library provided)
Code Explanation¶
Basic Definition
Backlight
Create a default Arduino_GFX object lcd
#if defined(DISPLAY_DEV_KIT) Arduino_GFX *lcd = create_default_Arduino_GFX(); #else /* !defined(DISPLAY_DEV_KIT) */ Arduino_ESP32RGBPanel *bus = new Arduino_ESP32RGBPanel( GFX_NOT_DEFINED /* CS */, GFX_NOT_DEFINED /* SCK */, GFX_NOT_DEFINED /* SDA */, 40 /* DE */, 41 /* VSYNC */, 39 /* HSYNC */, 42 /* PCLK */, 45 /* R0 */, 48 /* R1 */, 47 /* R2 */, 21 /* R3 */, 14 /* R4 */, 5 /* G0 */, 6 /* G1 */, 7 /* G2 */, 15 /* G3 */, 16 /* G4 */, 4 /* G5 */, 8 /* B0 */, 3 /* B1 */, 46 /* B2 */, 9 /* B3 */, 1 /* B4 */ ); // option 1: // ILI6485 LCD 480x272 Arduino_RPi_DPI_RGBPanel *lcd = new Arduino_RPi_DPI_RGBPanel( bus, 480 /* width */, 0 /* hsync_polarity */, 8 /* hsync_front_porch */, 4 /* hsync_pulse_width */, 43 /* hsync_back_porch */, 272 /* height */, 0 /* vsync_polarity */, 8 /* vsync_front_porch */, 4 /* vsync_pulse_width */, 12 /* vsync_back_porch */, 1 /* pclk_active_neg */, 7000000 /* prefer_speed */, true /* auto_flush */); #endif /* !defined(DISPLAY_DEV_KIT) */
/*It uses a class called Arduino_ESP32RGBPanel to initialize a display bus object bus. This object is used to control the ESP32-based RGB display panel. Then, according to option 1 in the comments, it uses the Arduino_RPi_DPI_RGBPanel class to initialize a display object called lcd. This object is used to control an ILI6485 LCD with a resolution of 480x272 pixels.*/
Resolution
Define a buffer variable to initialize the display driver of LVGL and prepare a buffer to store pixel data that will be rendered to the screen. The size of this buffer should be around 1/10 of the product of screen pixel values, which can balance the main control performance and the smoothness of screen display. Taking 10 as an example, the display will be smoother.
Define the led variable and the instance of the SPI library
Function
- The
my_disp_flush()
function is used to refresh the display. It receives a display driver pointerdisp
of typelv_disp_drv_t
, alv_area_t
structure pointer area representing the refresharea
, and alv_color_t
pointercolor_p
pointing to the color data. In the function, the widthw
and heighth
of the refresh area are first calculated. Then, depending on whether theLV_COLOR_16_SWAP
macro is defined, different methods are selected to draw the color data to the display device. If theLV_COLOR_16_SWAP
macro is defined, thedraw16bitBeRGBBitmap()
method is used to draw the color data; otherwise, thedraw16bitRGBBitmap()
method is used. Finally, thelv_disp_flush_ready()
function is called to notify LittlevGL that the display has been refreshed.
/* Display Refresh */
/* Display flushing */
void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p)
uint32_t w = (area->x2 - area->x1 + 1);
uint32_t h = (area->y2 - area->y1 + 1);
#if (LV_COLOR_16_SWAP != 0)
lcd->draw16bitBeRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
#else
lcd->draw16bitRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
#endif
lv_disp_flush_ready(disp);
- The
my_touchpad_read()
function is used to process touch input. It receives an input device driver pointerindev_driver
of typelv_indev_drv_t
, and a pointer to thelv_indev_data_t
structure data representing the input data. In the function, first check whether the touch screen has a signal. If there is a signal, further check whether the touch is pressed or released. If the touch is pressed, set the input state toLV_INDEV_STATE_PR
, and set the coordinates of the input point to the coordinates of the last touch of the touch screen. If the touch is released, set the input state toLV_INDEV_STATE_REL
. If there is no signal on the touch screen, set the input state toLV_INDEV_STATE_REL
, indicating that the input device is in the released state.
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
if (touch_has_signal())
if (touch_touched())
/*Set the coordinates*/
data->point.x = touch_last_x;
data->point.y = touch_last_y;
Serial.print( "Data x :" );
Serial.println( touch_last_x );
Serial.print( "Data y :" );
Serial.println( touch_last_y );
else if (touch_released())
else
Set Up Part
Serial.begin( 9600 ); /*Initializing the Serial Port*/
//IO Port Pins
pinMode(38, OUTPUT);
digitalWrite(38, LOW);
pinMode(0, OUTPUT);//TOUCH-CS
lv_init(); // LVGL initialization
// Init Display
lcd->begin();
lcd->setTextSize(2);
lcd->fillScreen(BLACK);
delay(100);
touch_init(); // Touch initialization
//Backlight Pins
pinMode(27, OUTPUT);
digitalWrite(27, HIGH);
lcd.setRotation(1);
/*Screen display initialization, by calling the lv_disp_draw_buf_init function to initialize the drawing buffer. This function accepts three parameters: &draw_buf is a pointer to the lv_disp_draw_buf_t structure, buf1 is a buffer for storing pixel data, and the last parameter is NULL to indicate that no additional buffer is used. The buffer size calculated is screenWidth * screenHeight / 8, and it is associated with the drawing buffer structure.
The size of this buffer affects the smoothness. The larger the buffer, the smoother the display. The size is limited by its own memory.*/
screenWidth = lcd->width();
screenHeight = lcd->height();
lv_disp_draw_buf_init( &draw_buf, buf1, NULL, screenWidth * screenHeight / 8 );
/* Initialize the display */
lv_disp_drv_init(&disp_drv);
/* Change the following line to your display resolution */
/*Initialize the (virtual) input device driver. This code is used to initialize a virtual input device driver and associate it with the LVGL framework to handle the interaction of the input device. It provides the necessary configuration and functions for the input device driver by setting the input device type and defining the read callback function.*/
/* Initialize the (dummy) input device driver */
ui_init();
Main Program Part
if(led == 1)
digitalWrite(38, HIGH);
if(led == 0)
delay( 10 );
Upload the Code¶
After completing the installation of the ESP32 board according to "Get Started with Arduino IDE" and the installation of the library according to "Install Libraries", open the program and connect the ESP32 HMI 4.3-inch to the computer via a USB-C cable.
Select Board: click "Tools" -> "Board" -> "esp32" and select "ESP32S3 Dev Module"
Board Setting: Under the "Tools" menu, see "Flash Size" select 4MB(32Mb); "Partition scheme" and select "Huge APP(3MB No OTA/1MB SPIFFS)"; "PSRAM" select "QSPI PSRAM"
Select Port
Upload the code: click the "Upload" icon to upload the code.
After the program is successfully uploaded, connect the LED to GPIO_D. Click the ON button on the screen and the LED will turn on. Click the OFF button and the LED will turn off.
Example Demo of ESP32 HMI Function¶
Note:
The library used in this section is in the compressed package of the library downloaded above.
Example1: LED blinking.¶
Connect the LED to GPIO_D(IO38) port, and upload the following code to the board. The LED will blinking.
#define D_PIN 38
Serial.begin(115200);
pinMode(D_PIN, OUTPUT);
digitalWrite(D_PIN, HIGH);
delay(500);
digitalWrite(D_PIN, LOW);
delay(500);
Example2: Play music¶
Plug the speaker into SPK port. Please check if you have installed the library ESP32-audioI2S(Copy the ESP32-audioI2S-master folder in the libraries downloaded above to the .../arduino/libraries directory). Upload the following code to the board.
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <FS.h>
#include "Audio.h"
Audio audio;
#define I2S_DOUT 20
#define I2S_BCLK 35
#define I2S_LRC 19
//4.3
#define SD_MOSI 11
#define SD_MISO 13
#define SD_SCK 12
#define SD_CS 10
pinMode(SD_CS, OUTPUT); digitalWrite(SD_CS, HIGH);
SPI.begin(SD_SCK, SD_MISO, SD_MOSI);
SPI.setFrequency(1000000);
SD.begin(SD_CS);
audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
audio.setVolume(21); // 0...21
audio.connecttoFS(SD, "/123.mp3");
audio.loop();
//audio.stopSong();//CLOSE
Example3: Initialize SD Card slot¶
Please install the SD library and FS library. Upload the following code to the board.
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <FS.h>
//4.3
#define SD_MOSI 11
#define SD_MISO 13
#define SD_SCK 12
#define SD_CS 10
//SD卡
delay(100);
if (SD_init() == 1)
Serial.println("Card Mount Failed");
else
Serial.println("Initialize SD Card successfully");
//SD Card initialization
int SD_init()
if (!SD.begin(SD_CS))
return 1;
uint8_t cardType = SD.cardType();
if (cardType == CARD_NONE)
Serial.println("No TF card attached");
return 1;
uint64_t cardSize = SD.cardSize() / (1024 * 1024);
Serial.printf("TF Card Size: %lluMB\n", cardSize);
listDir(SD, "/", 2);
// listDir(SD, "/", 0);
// createDir(SD, "/mydir");
// removeDir(SD, "/mydir");
// listDir(SD, "/", 2);
// writeFile(SD, "/hello.txt", "Hello ");
// appendFile(SD, "/hello.txt", "World!\n");
// readFile(SD, "/hello.txt");
// Serial.printf("Total space: %lluMB\n", SD.totalBytes() / (1024 * 1024));
// Serial.printf("Used space: %lluMB\n", SD.usedBytes() / (1024 * 1024));
// Serial.println("SD init over.");
return 0;
//Traverse the SD card directory
void listDir(fs::FS & fs, const char *dirname, uint8_t levels)
// Serial.printf("Listing directory: %s\n", dirname);
File root = fs.open(dirname);
if (!root)
//Serial.println("Failed to open directory");
return;
if (!root.isDirectory())
Serial.println("Not a directory");
return;
File file = root.openNextFile();
// i = 0;
while (file)
if (file.isDirectory())
// Serial.print(" DIR : ");
// Serial.println(file.name());
if (levels)
listDir(fs, file.name(), levels - 1);
else
Serial.print("FILE: ");
Serial.print(file.name());
// lcd.setCursor(0, 2 * i);
// lcd.printf("FILE:%s", file.name());
Serial.print("SIZE: ");
Serial.println(file.size());
// lcd.setCursor(180, 2 * i);
// lcd.printf("SIZE:%d", file.size());
// i += 16;
Example4: Initialize the touch¶
Please check if you have install the library XPT2046_Touchscreen(Copy the XPT2046_Touchscreen folder in the libraries downloaded above to the .../arduino/libraries directory).
And put the touch.h file in the same directory as the program, as shown below
Upload the following code to the board, and open the serial monitor to check the touch information.
#include "touch.h"
Serial.begin( 9600 ); /*初始化串口*/
touch_init();
Example5: Initialize the interact communication of Bluetooth¶
Please check if you have installed the library BLE(Copy the BLE folder in the libraries downloaded above to the .../arduino/libraries directory). Upload the following code to the board, and use the phone to search the Bluetooth device.
#include "BLEDevice.h" //BLE drive library
#include "BLEServer.h" //BLE server library
#include "BLEUtils.h" //BLE Utility library
#include "BLE2902.h" //Feature Add Descriptor Library
#include <BLECharacteristic.h> //BLE Feature function library
BLEAdvertising* pAdvertising = NULL;
BLEServer* pServer = NULL;
BLEService *pService = NULL;
BLECharacteristic* pCharacteristic = NULL;
#define bleServerName "ESP32SPI-BLE" //BLE Server name
#define SERVICE_UUID "6479571c-2e6d-4b34-abe9-c35116712345" //Server UUID
#define CHARACTERISTIC_UUID "826f072d-f87c-4ae6-a416-6ffdcaa02d73"
bool connected_state = false; //Create device connection identifier
class MyServerCallbacks: public BLEServerCallbacks //Create connection and disconnection calling classes
void onConnect(BLEServer *pServer)//Start connecting function
connected_state = true; //Device is connected correctly
void onDisconnect(BLEServer *pServer)//disconnect function
connected_state = false; //Device connection error
//BLE
BLEDevice::init(bleServerName); //Create BLE and set name
pServer = BLEDevice::createServer(); //Create BLE server
pServer->setCallbacks(new MyServerCallbacks()); //Set up connection and disconnection calling classes
pService = pServer->createService(SERVICE_UUID); //Create BLE service
pCharacteristic = pService->createCharacteristic( //Create ble feature(Characterristic_UUID)
CHARACTERISTIC_UUID,
BLECharacteristic::PROPERTY_READ | BLECharacteristic::PROPERTY_WRITE | BLECharacteristic::PROPERTY_NOTIFY);
pCharacteristic->setValue("ELECROW");
//start broadcast
pAdvertising = BLEDevice::getAdvertising(); //A bleadvertising class pointer padvertising is defined, which points to bledevice:: getadvertising()
pAdvertising->addServiceUUID(SERVICE_UUID);
pAdvertising->start(); //Start broadcasting
pService->start();
// pAdvertising->stop(); //Stop broadcasting
// pService->stop(); //Stop service
Example6: Initialize the WIFI¶
Please check if you have installed the library WiFi(Copy the WiFi folder in the libraries downloaded above to the .../arduino/libraries directory). Upload the following code to the board.
#include <WiFi.h>
const char *ssid = "elecrow888"; //Change to your SSID
const char *password = "elecrow2014"; //Change to your password
WiFi.begin(ssid, password);
WiFi.setAutoReconnect(true);//Set up automatic reconnection
delay(100);
Serial.println("connecting");
Serial.println("WiFi is connected.");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
// WiFi.disconnect();
Example7: Connect Crowtail-GPS module via UART to Get Location¶
Connect the Crowtail-GPS to the UART port.
#define SERIAL_BAUD 9600
HardwareSerial cardSerial(1);//Declare the UART1
unsigned char buffer[256]; // buffer array for data recieve over serial port
int count_1 = 0; // counter for buffer array
void clearBufferArray() // function to clear buffer array
for (int i = 0; i < count_1; i++)
buffer[i] = 0; // clear all index of array with command NULL
Serial.begin( 9600 ); /*Initialize the serial port*/
cardSerial.begin(SERIAL_BAUD, SERIAL_8N1, 18, 17);//4.3 /*初Initialize the serial port1*/18-RX\17-TX
if (cardSerial.available()) // if date is comming from softwareserial port ==> data is comming from SoftSerial shield
while (cardSerial.available()) // reading data into char array
buffer[count_1++] = cardSerial.read(); // writing data into array
if (count_1 == 256)break;
Serial.write(buffer, count_1); // if no data transmission ends, write buffer to hardware serial port
clearBufferArray(); // call clearBufferArray function to clear the storaged data from the array
count_1 = 0; // set counter of while loop to zero
if (Serial.available()) // if data is available on hardwareserial port ==> data is comming from PC or notebook
cardSerial.write(Serial.read()); // write it to the SoftSerial shield
