CrowPanel Advance 7.0-HMI ESP32 AI Display
The ESP32 Display-7.0 inch (Advance_Series) display module is a powerful HMI touchscreen with an 800*480 resolution IPS display. It utilizes the ESP32-S3-WROOM-1-N16R8 module as the main control processor, with a built-in dual-core 32-bit LX7 microprocessor up to 240MHz, 512KB SRAM, 8M PSRAM, and extended 16M Flash to ensure powerful data processing. The integrated 2.4GHz Wi-Fi and Bluetooth 5 (LE) functions, together with the module's own RF antenna, provide users with a stable and reliable wireless connection. In addition, a wide range of peripheral interfaces and excellent low-power performance make this series of products ideal for HMI application scenarios with stringent requirements for wireless connectivity.
A distinctive feature of the Advance version is its advanced AI functionality. Utilizing the microphone and speaker equipped on the motherboard, users can achieve voice command interaction, voice recognition, voice synthesis, and deep communication with intelligent assistants to easily access the information they need. Diversified wireless communication options are also provided through a modular design that allows users to change different modules as needed, supporting a variety of communication protocols including Zigbee, LoRa, NF2401, Matter, Thread, and Wi-Fi 6.
The module includes a 7.0-inch IPS display and driver board. The display utilizes capacitive touch technology and is equipped with a resistive stylus for more flexible use. In addition, the motherboard has a TF card slot, multiple peripheral ports, USB ports, speaker ports, battery ports, and wireless extensions, providing more expansion possibilities.
It supports development environments such as Arduino IDE, Espressif IDF and Micro Python, and is compatible with the LVGL graphics library and supports openHASP, which helps developers to easily customize the UI interface, quickly develop interesting projects, and significantly shorten the development cycle.
ESP32 Display-7.0-inch display module is suitable for many scenarios, such as automotive HMI, medical equipment, industrial control, electric power, civil electronics, automation, GPS, new energy and IoT applications. Its rich interfaces and expansion functions can meet the needs of different industries and provide users with more comprehensive solutions.
Model DIS02170A
advance-7.0
  • Integrated ESP32-S3-WROOM-1-N16R8 module, built-in wireless communication 2.4 GHz Wi-Fi (802.11 b/g/n) and Bluetooth 5.0;
  • Support development environment Arduino IDE, Loxin IDF, Micropython and compatible with LVGL graphics library.
  • Built-in LVGL demo interface and Arduino example, plug and play.
  • LCD 800 * 480 7.0-inch IPS screen with driver IC SC7277.
  • Rich peripheral interfaces and wireless expansion capabilities to meet the needs of different areas.
  • Integrated ESP32-S3-WROOM-1-N16R8 module with WiFi and Bluetooth 5.0 support;
  • Compatible with LVGL graphics library, and built-in LVGL Demo interface and Arduino sample program, plug and play;
  • Support for multiple development environments (Arduino IDE, Espressif IDF, PlatformIO and Micro Python);
  • 7.0-inch 800*480 resolution IPS with SC7277 driver IC;
  • Rich interfaces and expansion functions to meet the needs of different industries.
  • External power supply: DC 5V-2A;
  • Interface: 2 * UART0,1 * UART1,1 * I2C,1 * Battery,1 * SPK,1 * Wireless modue;
  • Operating temperature:-20~70 °C;
  • Storage temperature:-30~80 °C;
  • Active Area:156mm(L)*87mm(W);
  • Appearance Dimensions:181.26(L)*108.36(W)*16mm(H).
Pin Output:
advance-7.0
SPK Output audio signals to connect to speakers. The main board comes with a power amplifier chip circuit. PH2.0-2P
PWR Power LED.
boot
UART0-OUT Builds communication between Logic modules, including the serial communication module and the print module. HY2.0-4P
UART1-OUT Builds communication between Logic modules, including the serial communication module and the print module. HY2.0-4P
UART0-IN 32 KB (ATmega328) of which 0.5 KB used by bootloader XH2.54-4P
I2C-OUT Establish communication between the microcontroller and peripheral devices. HY2.0-4P
BAT Connect the lithium battery. (with battery charging circuit) PH2.0-2P
7.0-inch HMI port pin number Electrical Characteristics
UART0-OUT RX(IO44); TX(IO43) RX; Output voltage: 3.3V Output current: 1A max. Use: Power supply output and communication.
UART1-OUT RX(IO19); TX(IO20) RX; Output voltage: 3.3V Output current: 1A max. Use: Power supply output and communication.
UART0-IN RX(IO44); TX(IO43) RX; Input voltage: 5V ± 5%. 5.5V max. Input current: 2A max. Purpose: Power supply input and communication.
I2C SDA(IO15); SCL(IO16) ; Output voltage: 3.3V Output current: 1A max. Use: Power supply output and communication.
SPK I2S_LRCLK(IO6);I2S_BCLK(IO5);I2S_SDIN(IO4); Maximum output current: 20mA Signal type: 3.3V logic level, digital control signal
SD Card Slot MOSI(IO6); MISO(IO4); CLK(IO5); CS(GND) Maximum output current: 20mA Signal type: 3.3V logic level, digital control signal
LCD Backlight P3.5(STC8H1K28) Maximum output current: 20mA Signal type: 3.3V logic level, digital control signal
Backlight Adjustment P1.1(STC8H1K28)
I2S MIC MIC_SD(IO20);MIC_WS(IO2);MIC_CLK(IO19) Maximum output current: 20mA Signal type: 3.3V logic level, digital control signal
BUZZER P2.7(STC8H1K28) Maximum output current: 20mA Signal type: 3.3V logic level, digital control signal
TP_RST P1.7(STC8H1K28)
power amplifier MUTE P3.7(STC8H1K28)
power amplifier SHUT P3.6(STC8H1K28)
Switching Function Keys:
S1 S0 effective function
0 0 MIC&SPK
0 1 WM(wireless module)
1 0 TF Card
1 1 MIC&TF Card
Schematic:
ESP32-S3 and ISP Display Wiring Pins:
advance-7.0
ESP32-S3 and Touch Driver Wiring:
i2c address: 0x5D.
advance-7.0
ESP32-S3 and wireless module wiring pins:
wireless module
Schematic diagram of function selection:
function wireless module1
0 0 MIC&SPK
1 0 TF Card
1 1 MIC&TF Card
Platforms Supported
Arduino IDE ESP-IDF platformIO
Arduino ESP-IDF-Logo.png platformIO
GetStarted GetStarted GetStarted
ESPHome SquareLine Studio
ESPHome SquareLineStudio-Logo
Resources
Github link:
Code lib link:
Wireless link:
How to buy
Please visit this page to purchase ESP32 Display-7.0 inch(Advance_Series).
Support
